01-18-2016, 09:45 AM | #23 |
Rep 422
How did you do it ? our cars valve is electric
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
01-18-2016, 12:57 PM | #24 |
Rep 18,716
My method is remove the module and the spring, then turn the flap to open.
This solution is temporary, since after certain amount of driving, with the vibration, somehow the flap closes by itself. I have yet to figure out the other way to do this, but since it is my wife's car, I rarely able to mess around with it.
01-18-2016, 04:42 PM | #26 |
Rep 188
Am I alone in wondering why you would even think about doing this?
BMW pays good money to bright people who have come up with a sophisticated solution to stop this being an open pipe. As that solution is inevitably expensive to implement it can only be down to efficiency, emissions or economy - so why do armchair mechanics think they have a better solutions? |
01-20-2016, 08:29 AM | #27 | |
Rep 659
Drives: '22 M5CS, '00 M5, '06 Z4M
Garage List 2022 M5CS [0.00]
2001 BMW 740i [0.00] 2006 BMW M Roadster [0.00] 2012 BMW X6 3.5i [0.00] 2006 BMW 325xi [0.00] 2017 BMW 540xi [0.00] 2000 BMW M5 [0.00] 2001 BMW X5 4.4i [0.00] |
Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
01-23-2016, 11:26 PM | #28 | |
Rep 422
Well I did what you mentioned RG and I used a zip tie to hold the valve open...so far is holding and love the growl of the engine. I actually feel it more responsive , specially from the mid to top end...but not sure if it is because of the tune (Jb4) .. :-) ..i guess for tuned cars having a flap open it is required for the higher boost levels but I can see with the stock ECU that the computer will auto compensate and loose power in the low end.
my understanding for the flap valve is to allow the engine to warm up faster and to keep noises down. Also to improve some back pressure for better gas mileage, but is you look at the Mperformance Exhaust, both sides are open..the literature actually says to lower back pressure Quote:
01-24-2016, 02:11 AM | #30 |
1150
Rep 2,426
01-24-2016, 07:19 AM | #31 |
Rep 422
Exhaust alone does not produce any power if any 1hp and reduction of weight. But if it is put together with a tune and other performance parts (ie : Down Pipe) the gains are big. My understanding is that the extra boost and new electronic mappings of a tune requires all that buildup of exhaust fumes to get out fast. The stock exhaust will prevent that of happening.
01-24-2016, 10:10 AM | #32 | |
Rep 659
Chris
01-24-2016, 08:05 PM | #33 |
Rep 18,716
On the turbo engine, the easier / non restrictive exhaust , will let the turbo to spools up faster, in return higher boost. With higher boost, you gain more hp.
But, too much flow also not good. On the normal aspirated engine, also apply the same principal, but can't have too much flow since the engine will loose the low end torque. That also do apply on the turbo engine with a smaller capacity motor. In result of too much good flow, the low end torque is gone. So you need to drive the engine at higher rpm before it start producing powers.
01-24-2016, 08:20 PM | #34 | |
Rep 710
01-25-2016, 05:14 PM | #35 |
Rep 1,168
Just had ECS tips installed on my 2015 X line 35
It came with the valence and plug and play exhaust tips that mimic look of rectangular 50. It actually keeps the right exhaust open even at idle and in non sport mode at any rpm without the need of the MPE. I have MPPK installed. It is plugged in the valve on the right exhaust. Nice surprise AND it now even sounds throatier with both exhausts open. |
