      12-22-2017, 12:36 AM   #23
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Eek. Glad I got my full extended warranty to 84k miles. At 25k now!
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      01-06-2019, 11:09 AM   #24
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Went into the garage today and found the back end slammed. As soon as I opened the door it started filling back up. Once out of the garage, it was at normal ride height again. Do I need to be concerned?
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      01-06-2019, 11:44 AM   #25
alphaod
alphaod's Avatar
Sounds like the airbags are leaking slowly. I would have them checked out and replaced if necessary.
When your car is on, the compressor will be working continuously. It is not designed to do this. You will shorten the live expectancy of the air compressor significantly and when it fails you'll be looking at a much more expensive repair. The compressor is almost $1000 plus labor.
2015 BMW X5 xDrive50i
BMW CCA 509766
Russmov1328.00
      01-06-2019, 11:53 AM   #26
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Hmm alright I will have my buddy take a look for me. Thanks
      01-06-2019, 11:57 AM   #27
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Would it set off any codes if it was leaking or tell me there's a malfunction?
      01-06-2019, 12:10 PM   #28
alphaod
alphaod's Avatar
If it's leaking slowly there won't be any codes, it'll just be the visual tells like you said found your airbags deflated overnight. If you park the car for say a month or two, then it's normal for the airbags to be deflated slightly. If it totally deflates overnight that is abnormal.
If the air compressor fails you'll get a drivetrain malfunction. Might get lucky and it'll just be a blown fuse. Unlucky will mean compressor motor failure.
BMW CCA 509766
Russmov1328.00
      01-06-2019, 12:16 PM   #29
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Hopefully if any of that happens it will be covered under my extended warranty. 🤞🏻 it was just a one off fluke. If it's down again Tomorrow I'll take it in.
Thanks
      01-06-2019, 04:49 PM   #30
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Don't hold your breath. Suspension components aren't covered under extended warranty as they're considered wear parts. But idk what warranty you have. I know none of the bmw ones do.
Also arnott makes replacement bags and sells on eBay for like $120 a pop. BMW wants $300 a piece and that's discounted on wholesale. There's a thread showing how to do yourself. Not hard and maybe 2-3 hours of work.
'06 C55 AMG (sold)
      01-06-2019, 04:56 PM   #31
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Thanks
I have a third party one, I should get out my paper work and take a look
      01-06-2019, 06:06 PM   #32
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Bet it's arnott. 🤘
If I bought them again I'd probably go with the X5M ones as I'm lowered and this would allow me lower rear without being too bouncy. Basically just a smaller bladder that when full and stiff sits lower.
'06 C55 AMG (sold)
Russmov1328.00
      01-06-2019, 06:08 PM   #33
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Thanks
Bet it's arnott. 🤘
Do they fit the same? Or only if you are lowered?
      01-06-2019, 08:05 PM   #34
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Bet it's arnott. 🤘
They will fit the same but they will lower the rear m just like the M.
Arnott is direct replacement for F15
'06 C55 AMG (sold)
      01-06-2019, 08:09 PM   #35
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Thanks
Bet it's arnott. 🤘
I'll take a look at them. If I buy the regular ones locally they are 245 Canadian a piece. I looked at rock auto, even with shipping comes out to 370 for both. I may go that route if I need them.
      01-07-2019, 03:20 PM   #36
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Bet it's arnott. 🤘
Arnott is currently $280 for both on Prime.
'06 C55 AMG (sold)
      01-07-2019, 04:28 PM   #37
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Thanks
Bet it's arnott. 🤘
I just looked, not finding them on the Canadian site. Must only be for the U.S
      01-07-2019, 04:28 PM   #38
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Bet it's arnott. 🤘
Try from arnott directly.
Arnott A-2642 Set of 2 Rear Left and Right Air Springs for BMW X5 & X6 https://www.amazon.com/dp/B07FKP2VP4..._Ak9mCbT74STK0
https://www.arnottindustries.com/air...-left-or-right
'06 C55 AMG (sold)
      01-07-2019, 04:36 PM   #39
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Thanks
Bet it's arnott. 🤘
Are they the same from the E70 to the F15?
      01-07-2019, 04:42 PM   #40
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Looks like rock auto is still significantly cheaper for me.
      01-07-2019, 07:04 PM   #41
Sedoy
Drives: F10
Yes they are regardless that oem have different part numbers
Russmov1328.00
      01-07-2019, 07:19 PM   #42
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks
Bet it's arnott. 🤘
Yup
'06 C55 AMG (sold)
Russmov1328.00
      01-07-2019, 09:04 PM   #43
alphaod
alphaod's Avatar
Do they really have a lifetime warranty?
BMW CCA 509766
      01-07-2019, 09:32 PM   #44
Localbrew
Localbrew's Avatar
145
Drives: 2015 X5
Looks like mine is failing as well, it's on the driver side and it's hit or miss. Seems to be only when parked on uneven surfaces or dirt terrain. I'm taking it in on Monday, I just don't know how they will see if it's bad if it only does it randomly.
Any thoughts?
