02-03-2019, 11:00 AM | #45 | ||||
Rep 114
2016 X5 50i MSport in White
Dinan Powered AC Schnitzer Springs 22" Varro VD01 Wheels iND Black Emblems and Badge |
02-03-2019, 11:36 AM | #46 | |
Rep 18,715
Flash Tune is not ALWAYS be the "safer" choice. Flash Tune is great, since you are remapping the whole engine AFR, timing, and spark timing. But, it is not ALWAYS be the "safer" choice. Greed is your enemy. Flash Tune will always be the safer choice if you are following the guideline and keeping the OEM safety or max limit parameters (those are what a lot of tuners removed to max out the output power of the engine). By keeping those safety or max limit parameters or in general they call it Stage 1 tune, usually are neck to neck with a piggyback tuning. Besides, BMW Engineer spent years to build the engine, they are the one who knows the limitation of the engine for reliability and longevity. That's why they set those safety limit in the ECU, even though sometime they do that for marketing purposes to be able to sell their MPPK. Another reason why Flash Tune is not ALWAYS be the "safer" choice. It leaves digital footprint, even though the tuners said that it will reset the counter, etc. to make it invisible for BMW to see if the DME has been tampered. If you are not worrying about warranty at all and building this car for track use daily, then Flash Tune is what I will pick personally and what I will suggest to you. Because track car gets full engine rebuild every season. So, full stress to the components is not a question. While, piggy back tune. Yes, it does trick out the sensor reading and letting the stock ECU to adjust all of the rest of the parameters, such as; AFR, Timing, Spark, etc. That's where the piggy back tuning limitation comes. But, that limitation also a good thing. It is a good thing because piggy back tuning will not go over the stress limitation or safety limitation that set by BMW. If piggy back tuning tries to go over the limit and the DME doesn't like it, it will disable everything before causing any damage to the engine. So, when you are running piggies and getting CEL or Drivetrain Malfunction, it is not necessarily meant that the piggies is bad. It can also mean that the ECU/DME doesn't like that is going on with the engine. It could be the coil is going bad, spark plug, fuel pump, etc. I don't and will every say that Piggy back is ALWAYS be the "safer" choice, because all modification are not safe unless it is done properly with great engineering and R&D. Anyone can do great marketing, because it is all just about the amount of money spent. But great engineering and R&D is about time spent to testing and testing and more testing. If you are worry about warranty and just want to have fun on your daily commute, that's where I suggest a piggy back. Easy and simple to install. If you guys think that I am biased since I sell RaceChip. Here what I can tell you. My 2006 Porsche C4S is running Flash Tune since I track the car from time to time. It even have track/street setup coilover, R-Compound tires. My 2017 BMW 540 is running RaceChip since it is for my daily commute and I just want to have fun from redlight to redlight. It is running street setup coilover, with street tires.
02-03-2019, 11:49 AM | #47 | |||||
Rep 844
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
02-03-2019, 11:52 AM | #48 | |
Rep 844
02-13-2019, 04:50 PM | #49 |
Rep 252
Drives: '06 M3, '20 X3MC, '03 540i MSp
These debates are always fun to read, thanks fellas.
I have been genuinely (and pleasantly) surprised by how fast and powerful my 50i is, just stock. It's nailing me in my seat. The only minor down side is the slight turbo lag. For the time being, I think I'll leave it stock while it's still under the CPO warranty so that if anything at all goes wrong mechanically, BMW can't pull some BS and blame the tune and refuse to fix my car under warranty. However, once the warranty runs out, I'll have a lot of thinking to do if I go with RS GTS or ESS or BPC. I am, however, throwing in the stock X5M air filters in there for now.
2020 Dark Graphite X3M Competition
2021 Audi e-tron 2006 Mystic Blue M3 2003 540i MSport 1991 Red 318i (M50B25 engine swap) |
02-13-2019, 10:46 PM | #50 | |
Rep 18,715
It is not a tune to the engine, just a trick to the gas pedal.
02-14-2019, 11:42 AM | #51 | |
Rep 252
02-27-2019, 12:11 PM | #52 | |
Rep 35
2008 BMW 335xi Dinan Stage 2 (sold)
2010 BMW 535xi JB4 (sold) 2012 Audi A6 3.0T APR Stage 2+ (sold) 2016 BMW X5 50i BPC or ESS |
02-27-2019, 12:49 PM | #53 | |
Rep 1,975
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
02-27-2019, 01:45 PM | #54 |
Rep 182
I want to get the BM3 for my i35... I was told a 70hp gain off their stage 1 and doesn't even compare to the MPPK... It sounds awesome, but slightly worried as that's a huge gain with just a tune which really is mainly achieved by upping boost which is never good for the car.
Honestly, this car stock for an SUV feels plenty powerful to me, but 600 bucks for 70 hp does sound good... Just worried it's little much for a stock drivetrain with 60K miles. |
BimmerTy192.50 |
02-27-2019, 05:17 PM | #55 | |
Rep 1,975
CT335xi684.00 |
02-27-2019, 08:50 PM | #56 | |
Rep 648
Drives: 2016 F15, 2015 F83
However, I would drive the vehicle a bit first and get used to it's performance, characteristics and quirks. Then tune it. I promise you'll be happy with the gains. You can also shop around a bit for the BM3 license. Other forum sponsors are authorized BM3 sellers and offer deals from time to time. Head on over to the F30 section, specifically the N55 Turbo Engine / Drivetrain / Exhaust Modifications section. There you'll find some threads and a lot more info about BM3 for the N55 engine. There are a lot more 3 & 4 series N55 owners with tunes than X5 owners.
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 02-27-2019 at 08:57 PM.. |
02-27-2019, 10:31 PM | #57 | |
Rep 182
That being said, I understand it's just not boost, but host of other things. I've done turbo tuning myself with american V8s back in the day, some of that stuff is still in my head as far as maps go. just amazing to pull 70hp from a tune s1 93 octane tune |
02-28-2019, 09:21 AM | #59 | |
Rep 182
tune will be next. |
02-28-2019, 10:54 AM | #60 |
Rep 276
Of BM3, JB4, ESS, etc, which has proven to be the fastest tune? Not dyno numbers and not smoothest, etc, but fastest time on Dragy or at the track? I'm ready to purchase for my 50i and I have access to E85 as well Thanks!
02-28-2019, 02:12 PM | #61 |
Rep 134
The fastest time I recall seeing posted on Dragy was from RonJon- 3.54 sec. 0-60 on a basically stock 50i with X5M air filters and NGK plugs. His 1/4 mile times are high 11’s. He’s a member here and hopefully will jump in with more details than I remember. His tune is a 93 octane flash tune from Active Autowerke.
UPDATE: just found his 1/4 mile time- 11.918 @ 115.41 mph.
That’ll buff out
02-28-2019, 02:44 PM | #62 | |
Rep 182
stock with a tune running high 11s!? wow... slightly regretting getting a s35i now LOL |
tvincent5.50 |
02-28-2019, 03:07 PM | #63 | |
Rep 1,434
2022 x5 m50i - Dravit grey
02-28-2019, 03:12 PM | #64 | |
Rep 182
not doubting. just hard to believe |
02-28-2019, 03:22 PM | #65 |
Rep 1,434
My #s are on a mustang dyno would probably be like at least 400 whp to low 400 on dyno jet. The guys name is Doberman16 , he ran a 11.87 @ 116 , I think he’s running Bm3 tune? He is making low 500 whp on a dynojet and close to 600 wheel torque. Look him up even has some videos posted.
02-28-2019, 03:34 PM | #66 | |
Rep 182
that's insane to be running 11s with just a tune. I keep saying I regret not getting the x50i, but then drive home in the ecopro mde |
