03-02-2019, 03:00 PM | #1 |
Rep 182
Best place/price to get a remote key
Hey guys,
I am in need of a 2nd key for my car as it did not come with one. I have a new owner thread, and was told it's around 300 dollars from a dealer. I understand the key comes specific to your vehicle and is 'programmed' to your car once you get it. That being said, I called 2 dealers near me and was told $693 Called another dealer little further away and was quoted $460. before I pull the trigger and get it from them, is there a forum friendly dealer that will let me order a key at a more affordable price? I understand I'll have to scan/email my reg and DL which is fine... FWIW, I do have comfort access. I searched here, but didn't see any dealer recommendations for it. any suggestion is greatly appreciated! |
03-02-2019, 09:56 PM | #2 |
Rep 2,511
Well, key fobs are not reusable and keys are made by BMW, not even the dealership.So $460 from the dealership is no that bad. The cheapest I've seen was from BimmerTech, $425. https://www.bimmer-tech.net/shop/bmw...f-and-g-series
03-02-2019, 09:57 PM | #3 | |
Rep 182
I saw that 425, but the key is 85 extra. this was 460 key included. |
03-02-2019, 11:44 PM | #4 |
Rep 1,340
Check with bmw of fairfax, I got my key for my 2-series for $235.
http://www.realoem.com/bmw/enUS/show...diagId=41_2751 Last edited by bmwx5er; 03-03-2019 at 12:13 AM.. |
03-03-2019, 09:08 AM | #5 |
1150
Rep 2,426
I was charged around $300 plus tax for the key after CCA discount but it’s possible that’s only for the transponder part not the physical key part which would be extra. This was ordered for my remote engine start retrofit. This was also around two years ago and prices do go up. Perhaps that $450-ish is a good price for the whole key. I’ll try to pull up my paperwork when I get home.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
03-03-2019, 09:17 AM | #6 |
Rep 714
Drives: BMW X5 M Sport - G05
$460 sucks, but that's the way it is. Lose or damage your current key and then it gets complicated and even more expensive.
03-03-2019, 11:32 AM | #7 |
88
Rep 366
We had to get a new key for our F15. It ended up being $336 for the fob, and $120 for the key. Then because we had comfort access, it was an hour of labor to code it. From our local dealer.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
03-03-2019, 03:40 PM | #8 |
Rep 182
03-03-2019, 03:42 PM | #9 |
Rep 182
I have thar as well. They told me they have to program it when the key comes in but they'll just take care of it outside. You shouldn't pay any labor for that
03-03-2019, 04:42 PM | #10 |
88
Rep 366
They had ours inside for over an hour.
If you DONT have comfort access, I am told you don't need dealer programming, but if you DO have it, its required.
03-04-2019, 09:07 AM | #12 |
Self-Deprecating Narcissist
7266
Rep 6,561
I have a couple of ///M key fobs that have already been programmed. Are these now worthless paperweights? Can they be reprogrammed for my current X5M or sold to someone else?
03-04-2019, 09:57 AM | #13 | |
Rep 1,168
03-04-2019, 11:57 AM | #14 |
Rep 1,340
I did it remotely, had to send car registration and a copy of my DL via email. This was in late 2016. Several other dealers I contacted turned me down because they needed in-person verification. It’s worth a try, IMO, as they had the best price.
03-04-2019, 02:21 PM | #15 | |
Rep 7,488
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-04-2019 at 02:28 PM.. |
iconoclast7265.50 |
03-04-2019, 03:23 PM | #16 | |
Rep 182
Place local to me said they'll just take care of the coding for me. I don't know if they know what is involved but didn't sound like they were going ot charage me. Last edited by taseal; 03-04-2019 at 04:08 PM.. |
03-04-2019, 04:39 PM | #17 | |
7266
Rep 6,561
03-04-2019, 10:49 PM | #18 |
Rep 2,511
I don't think so, once activated/attached to the car key fob is done. Can't be wiped or re-programmed, that's why they are so expensive, BMW explains it as thief prevention measure,so someone in the dealership can't program the key and help get your car stolen.
iconoclast7265.50 |
03-05-2019, 07:15 AM | #19 |
7266
Rep 6,561
Gotcha. Makes sense. Thank you for the explanation.
03-05-2019, 08:53 AM | #20 |
Rep 1,168
I'm not an expert, but I think technically any fob can be wiped clean, at the chip level, i.e. involving some level of disassembly. Whether it can be later programmed to a car, by dealer or elsewhere - no clue
03-05-2019, 09:33 AM | #21 | ||
Rep 7,488
One would have to retrieve the specific 128-bit code (already written to the cars CAS & DME)...then write that to the remote fob in order for that fob to work with the car and enable it to start. This also means that a used CAS or DME from another vehicle also won't work in another BMW unless they had some type of hardware/software to "virginize" the module and write the (VIN) specific 128-encrypted code to that module that matches the vehicle's other EWS coded modules/components. Quote:
iconoclast7265.50 |
03-05-2019, 09:46 AM | #22 | |
Rep 7,488
The name is the AK90...which is software/hardware that allows you to retrieve the EWS's ISN (individual serial number)...which is the forerunner of the 128-bit encryption used on the newer gen BMWs. Once the ISN is retrieved...it is then written to a new transponder chip that is inside the new/used aftermarket remote key. But the other side of this scenario (for the old style remote keys) is that the replacement remote needs the correct key blade type (there were multiple types used)...and the key blade also needs to be cut correctly to fit the ignition cylinder. And depending on if you have the 1st iteration or 2nd iteration...the key needs to be powered to transmit the FZV/DWA (central locking/ain't-theft alarm siren system) signal. The early versions used a replaceable 2016 battery or two 1220 batteries...whereas the latter remote was sealed and used a rechargeable battery. The latter (diamond-shaped) remote is kept charged thru induction by the Ring Antenna located around the ignition cylinder. So this wrinkle also needed to be considered when going with a used or aftermarket remote...how is it going to be powered.
iconoclast7265.50 |
