03-28-2021, 08:56 PM | #67 |
232
Rep 337
Just finished retrofitting NBT EVO/ATM into my 2015 x5. Happy with the results, CarPlay full screen works! Thanks OP sj22 for answering my questions. Changed the unit, atm, upgraded to touch screen and newer controller. Chinese wi fi antenna works but gives an error in ista, so ordered oem one. Everything coded to my vin, will be resoldering the sim from tcb to new atm for connected drive services.
04-06-2021, 11:19 PM | #68 |
Semper Fidelis
14
Rep 65
I'm so at a loss here, I have a 2015 X5 F15 date is Feb 2015. I want to do this retrofit with touchscreen and don't even know where to start. everything I'm reading seems way out of my league. I've looked at some of the. Bimmertech stuff and it seems pretty straight forward. just not sure if the MMI or the other retrofit is the way to go. any advise from those if you who have done it?
04-06-2021, 11:45 PM | #69 | |
Rep 51
Also let us know how the ATT 3G phase out affects you. Will it tell you that you are not eligible for service because it checks your vin and thinks your car is 3g even though now it is actually 4g? |
04-07-2021, 07:26 AM | #70 | |
Rep 885
https://f30.bimmerpost.com/forums/sh....php?t=1675929 https://www.android-car-dvd.com/prod...32066140471432 |
06-10-2021, 12:42 PM | #71 | |
Rep 10,256
If a donor ATM with an active subscription but coded to the vehicle's VIN instead, BMW Connected Drive will allow renewal even after the donor subscription expires? |
06-10-2021, 12:47 PM | #72 | ||
Rep 2,511
06-10-2021, 12:53 PM | #73 | |||
Rep 10,256
My 2015 X5 will not longer receive Connected Drive services in Feb 2022. Let's assume donor ATM has an active subscription until 2024. Will BMW deactivate Connected Services in Feb 2022 assuming the vehicle still has 3G hardware? Or - Connected Drive services will work until 2024? Will renewal be possible after 2024? |
06-10-2021, 01:02 PM | #74 | |
Rep 2,511
cfm56d7b5886.00 |
06-10-2021, 01:10 PM | #75 | ||
Rep 10,256
What's a good source to obtain a donor ATM? This seems like a key component. I am making a list of all required parts starting with NBT Evo head unit. |
06-10-2021, 01:22 PM | #76 |
Rep 2,511
Ebay I guess, ask OP.
08-03-2021, 07:44 PM | #77 | |||
Rep 178
02-01-2023, 09:37 AM | #78 |
175
Rep 303
So question, if i want RTTI and connected drive, etc....I need an ATM, does that mean one of the ID6 head units with the blue connector for the GPS will work?
I'm watching a few on ebay like this one or maybe this one with more accessories? Or do i need to still buy another item? I also see BimmerTech has an 'add on' of $499 for 'SiriusXM/HD radio', is there a component needed for that which i can tell if any of these head units come with? I use SXM a lot and dont like the idea of another $500 for that. Basically at the point where im ready to pull the trigger for my spring upgrade and want to ensure the swap i do has everything (ATM, SXM, GPS, etc etc....) |
02-01-2023, 01:38 PM | #79 | |
Rep 2,511
02-01-2023, 02:04 PM | #80 | |
175
Rep 303
02-05-2023, 05:49 AM | #81 | |
Rep 9
For my E70 CCC Andream has a CarPlay / Android Auto touchscreen, I’ve ordered here - as this is a screen replacement with no need for MMI box. https://www.android-car-dvd.com/coll...33378246754440 This is what I want just for F15 NBT, so I can at least use touch screen. Hopefully Andream will come out with an NBT version. |
02-05-2023, 03:17 PM | #82 |
Rep 234
Say I didn’t care about nbt evo and I just wanted CD and RTTI. Could I just purchase and install 84-10-6-836-777?
What’s the difference between ATM and TCB 4G?
02-05-2023, 03:58 PM | #83 |
Rep 2,511
I don't think NBT4 will work with ATM unit, there are differences in the hardware (old units use GPS antenna, new units use A-GPS to position the vehicle).
02-14-2023, 04:10 PM | #84 |
Rep 234
What I’m wondering is if I can just keep my existing NBT and use a 4G TCB instead of doing the entire EVO+ATM retrofit.
Variante Alta94.00 |
02-19-2023, 10:24 AM | #86 | |
Rep 175
can be install just only the touchscreen from NBT EVO to NBT ID 4.0 to x5 2016? |
