      07-17-2019, 10:57 AM   #67
mrfochon
Drives: X5 F15 M package
Originally Posted by sbinshihon View Post
Originally Posted by mrfochon View Post
My sales got upset when I told her will go with another GB
I tired to answer your PM twice, your inbox is full.
Manufacture is Joyeauto as far as I know. Its the same unit Bimmerretrofit sells under their name for $600. It supports IOS 13 and connects automatically in under 3 seconds. The reviews are excellent and the company have many videos on youtube.. check them out!
SAR 1,403.51 16% Off | Joyeauto WIFI Wireless Apple Carplay Retrofit 1 2 3 4 5 7 series X1 X3 X4 X5 X6 MINI NBT F10 F15 F16 F20 F30 F48 13-17 for BMW
https://s.click.aliexpress.com/e/csNblTZQ
Thank you.
I have been warmed by local friend that some of this units are not upgradable down the road. Which means either you will loose CarPlay when upgrading you iPhone or will not be able to upgrade your phone.
Can you double check with your sales person ?
Thank you
      07-17-2019, 01:01 PM   #68
Amsterdave
Drives: 2015 X5d-MS & 2018 BMW X3 30i
@sbinshihon you're the man! Thanks for taking the initiative on this!
I've just finished watching a bunch of Youtube videos by Joyeauto and walked away with one major question.... It looks like they make you select AUX before switching to Carplay... does that mean that you can't play for example Satellite radio while in Carplay mode, you can only stream??
Perhaps you can let us know once you receive yours! Thanks again!
      07-17-2019, 01:45 PM   #69
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Well, look what we got in the mail today!
      07-17-2019, 02:17 PM   #70
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
No time to waste..
      07-17-2019, 02:39 PM   #71
KCTiger
Drives: 2016 X5M
I was going to joke and ask if it was installed yet but you practically will have it installed by the time I hit send. Nice work!
      07-17-2019, 03:39 PM   #72
endo_r1
endo_r1's Avatar
Drives: 2016 BMW X5 35d
So tempted to get in on this gb
      07-17-2019, 04:06 PM   #73
mrfochon
And to add the WiFi antenna ..
      07-17-2019, 06:10 PM   #74
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
So I just finished Installing this unit.. It was quite handful. Moreover, I noticed two main problems after the installation... the backup camera doesn't come up when I put it on reverse! And I cant hear the caller when I make a call with CarPlay!! Very disappointed with those two things now, not sure if I did something wrong. I will have to ask support from Joyeauto. Will report if these issues get resolved.
      07-17-2019, 06:13 PM   #75
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Thank you.
Thank you
This one you can update with USB stick.
      07-17-2019, 06:14 PM   #76
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
You can listen to radio or any other source while the screen shows CarPlay.
      07-17-2019, 06:18 PM   #77
mrfochon
Thank you.
Thank you
Yes and how do you update ? Did you clarify with them that they will provide the update at no additional cost ?
      07-17-2019, 06:20 PM   #78
Amsterdave
Great! Keep us posted on the other two big issues you encountered!
      07-17-2019, 08:04 PM   #79
KCTiger
Drives: 2016 X5M
I thought there was a setting that selected between OEM rear camera and aftermarket. I could be totally wrong though.
      07-17-2019, 08:22 PM   #80
CatalinP
Drives: BMW X5 F15 2014 3.0xd
It's a dipswitch, see the diagram in one of the above photos...
      07-17-2019, 08:51 PM   #81
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
I believe that these units require an external mic.. did it come with one?
      07-17-2019, 09:09 PM   #82
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Yes, mic problem is solved. I had to turn off NBT Blutooth to be use CarPlay for calls.
      07-17-2019, 09:15 PM   #83
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Both problems are solved now.. after changing some switches on the device, back up camera works now perfectly. Calling through CarPlay requires NBT Bluetooth to be disconnected.
Also I asked the customer support about future updates, said that there will update so CarPlay will continue to work on this device!
      07-17-2019, 09:25 PM   #84
KCTiger
Drives: 2016 X5M
Why did I even act like I was going to refrain from getting in on this?!!
1. Guntherpdx
2. mrod81
3. -c-
4. eggyacid
5. DeeO
6. skoold2003
7. Amsterdave
8. Kakalika
9. LeftBank
10. Mrfochon
11. KCTiger
      07-17-2019, 11:12 PM   #85
Kakalika
Kakalika's Avatar
Drives: 2014 X5 35d M Sport
Why do we need the backup camera? The F15 already has cameras. Or are the stock cameras disabled when we add this carplay unit?
RUN FLAT TIRES? NEIN DANKE!
      07-17-2019, 11:16 PM   #86
-c-
-c-'s Avatar
Drives: bmw
Where did you hide the aux mic? Is it visible ? Is it behind the dash?
      07-18-2019, 05:02 AM   #87
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
This unit is not specific for the F15. Its for every NBT equipped car, even cars with 6.5 inch screen. So makes sense to have camera switches..
      07-18-2019, 05:06 AM   #88
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
I route it to steering column, not visible for the driver. Actually, I found you can still use Nbt blutooth with CarPlay so you can skip installing the external mic..
