11-27-2021, 12:53 PM | #1 |
Rep 137
2016 X5- Spare key not working
I tried to verify our spare key fob for our '16 X5 was still working after sitting a drawer for 3 years, it was not. Its battery voltage was down to 2.4v so I replaced it. New battery measured 3.2 volts, spare key still does not work. By not work I mean I can't lock or unlock the car using either CA or buttons on the fob. Daily use key works fine. Do I need to re-sync the fob with the car, or something else to get it to work again? I found nothing in the manual that would help.
Thanks |
11-27-2021, 01:58 PM | #2 |
Rep 7,488
Does the remote that was in the drawer still start the vehicle? If yes, then make sure the battery is making good contact (reinstall it…or swap the battery from the working remote).
If it doesn’t start the vehicle…then follow the instructions from the owners manual…place the remote next to the little icon on the right side of the steering column.
11-27-2021, 02:48 PM | #3 | |
Rep 137
Battery in drawer remote is a new lithium that measures 3.2 volts. I wiped off the battery and cleaned the contacts on the remote. Still a no go. Jim |
11-28-2021, 06:29 AM | #4 | ||
Rep 493
Suggest you bring the key to a BMW SA, they have a desktop unit where they "read" the key, maybe they can tell how to fix it. |
11-28-2021, 07:56 AM | #5 |
Rep 137
Yea, I was hoping to avoid a 3 hr drive to the nearest dealership.
11-28-2021, 11:10 AM | #6 |
Rep 137
Progress. I have 3 new batteries for the fob, all of them read over 3.2volts, none of them work in the drawer fob. The battery in the working fob reads 3.0volts. I swapped batteries between the drawer fob and the working fob, and now the drawer fob works! I have no idea why none of the 3 new batteries work in either fob. The only working battery is the original one that came with the car when I bought it Nov 2015. The working battery is a Panasonic and the "-" terminal is slightly different in shape than the others. It has a ridge around the outside edge, the others, 2 Duracell 1 Energizer, are flat. I'm off to find a Panasonic battery.
11-28-2021, 11:57 AM | #7 | |
Rep 108
Don't ask how I know…: |
Tomcat_F15_STL149.50 ajob456.00 |
11-28-2021, 02:54 PM | #8 | |
Rep 493
11-28-2021, 10:01 PM | #9 |
Rep 11,136
I actually appreciate you starting this thread as my second fob is experiencing the exact same issue you are. Drawer fob either drains new battery very quickly, or doesn't work at all.
So if I am reading everything correctly, they are very sensitive to a particular battery? |
11-29-2021, 07:00 PM | #10 |
Rep 137
I couldn't find a Panasonic battery. I could only find another Duracell battery. The new Duracell battery had a different "-" contact than the first one I had. Annndddd it worked!!! Now both fobs are working correctly.
Based on my limited experience, it does look like the fobs are sensitive to battery manufactures. For the life of me I can't figure out why. I am also curious why the fob that I have used daily since I bought the car Nov 2015 the battery voltage was only down to 3.0 volts. But the fob that sat in the drawer, unused in 3 years, and rarely used before that, was down to 2.5 volts. New batteries read 3.2 volts. |
11-29-2021, 09:34 PM | #11 |
Rep 7,488
Just a tip: I change fobs at every DST (daylight saving time) change over. That way each remote wears equally and it gives me an idea of each remote battery’s health.
If that’s too often for anyone…a specific day could be adopted for fob switch-over like a birthday, holiday, or anniversary etc.
11-29-2021, 11:56 PM | #12 |
Rep 2,511
One little thing which gave me similar issue was the clear plastic sticker on the battery, tried few different batteries before I realized there is a sticker there.
11-30-2021, 08:00 AM | #13 |
Rep 137
I have read about others finding a clear plastic stickers on their batteries. I measured each battery before trying it and moved my lead around the face to make sure there was good contact everywhere.
The last set of batteries I bought for the fob were labeled that they has some nasty tasting stuff put on them to discourage kids from putting them in their mouth. First time I had seen something like that. I hope whatever it is doesn't cause an issue down the road with the fob. |
11-30-2021, 05:06 PM | #14 |
Rep 297
I used Energizer brand in both my fobs without any issues. Well one FOB will occasionally cause the "no key found" message or whatever that is but it still works?.
When I bought the car the dealer only had one original key but got a second made by a locksmith. I suspect it's that locksmith key that gives the message but to be honest I am not sure which key is the copy. |
11-30-2021, 05:58 PM | #15 | |
Rep 615
12-02-2021, 07:50 AM | #16 |
Rep 7
I had a similar issue as mentioned above using different brands of battery for my key fob. I went on Amazon and bought the 4 pack of Panasonic and my fob now works again . It does seem to make better contact than the other brands I tried . Hope this helps .
P111572.00 |
12-02-2021, 10:55 AM | #17 |
Rep 11,136
Panasonic it is, thank you!
08-13-2023, 09:20 AM | #18 |
Rep 1
The Key Fob Mystery!
Many thanks for posting this topic and threads! You've confirmed my frustration and revealed the 7% Solution!!!
Same experience with my 2 fobs (1 works other didn't). Both batteries tested the same power level. And yes, swapping the batteries the 2nd fob worked... any yet same battery make and lot (off brand). Then installed a new battery from the same off brand and lot, it worked.... I did take your advice in ordering the Panasonic for extra measure. All the best, Sam |
