02-07-2022, 12:32 PM | #23 | |
Rep 1,497
02-08-2022, 10:38 AM | #24 |
Rep 10,256
Joining this thread. Our family car is 2015 F15 X5, 7 years old and only 32K miles. The main battery is finally asking for a retirement package.
I bought OEM equivalent DieHard 8H battery. Plan to install and register shortly using Foxwell NT510. After installation ... - Any common error codes which can be avoided? - How to charge the battery? Idle the car for N minutes? All suggestions appreciated! |
02-08-2022, 10:42 AM | #25 | |
Rep 1,340
cfm56d7b5886.00 |
02-08-2022, 12:06 PM | #26 |
Rep 10,256
Thanks! I will clear all codes - there are at least 3 that Foxwell NT510 identified.
02-08-2022, 01:57 PM | #27 |
Rep 10,256
The battery was replaced. Now I need to register it.
Old battery: 105 Ah / 950 A. New battery: 95Ah / 900A. I am using Foxwell NT510 to register the new battery but it's asking for a supplier code. Any suggestions? |
02-08-2022, 02:01 PM | #28 | |
Rep 1,340
Edit: here's a thread about the same topic. https://www.bimmerfest.com/threads/d...ttery.1415395/ |
02-08-2022, 04:11 PM | #29 | |
Rep 7,489
When you swap in a new battery...you have to register it. If you swap in a new battery that has different specs than the old battery...then you need to CODE the new specs of the battery...then REGISTER the new battery. You need to CODE your charging system to change from a 105AH battery to a 95 AH battery. Once you've done that...then you can register the new battery. You can see two screen shots below...the 1st is the Bimmercode app where you CODE a new battery that has different specs than the one that was replaced. The 2nd pic is the Bimmerlink app where you register a new battery when it has been replaced (and coded if specs are different). If your scanner has the capability to CODE your new battery...and you don't see 95AH listed...then select the AH rating that is closest to the battery that was installed (in the scenario of the pics below...you would select 90AH instead of 105AH).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-08-2022 at 04:24 PM.. |
02-09-2022, 03:27 PM | #30 |
Rep 1,497
I'm assuming you didn't unlock the doors and pop the trunk and then wait to let the car go into sleep mode before disconnecting the old battery? I've heard not doing so will cause the 3 fault codes.
08-06-2023, 07:47 PM | #31 |
2013 E93 M3 MW/Fox and 2018 X5 M Sport
41
Rep 38
Drives: 2013 E93
I have a 2018 X5 with 44k on it. All of a sudden I’m getting the following warnings:
“Battery discharged.Start engine” and “Charge by driving for longer periods or use external charger. Functions requiring battery will be switched off.” After ignoring it for a day or two I also got a warning regarding the parking brake. I suspect that it’s the battery when I connected the battery charger to the jump start points under the hood, the charger shows 14.7 V with the car off and it wouldn’t charge the battery as it says it’s 100% full. I then discovered that I have the 2 battery setup in the trunk. I looked at the battery voltage at the terminals with the car off and got between 12.1 and 12.3 with the Auxiliary battery and Near 14.7 on the Main. Up to this point, the car started strong and only had a couple of weird things with the comfort access working/not working. I put the Auxiliary on a battery charger and then went for 2 half hour drives. When I went to start it, the car nearly did not start… I suspect the Auxiliary battery is going bad, but now am unsure… I also now have Bimmerlink, but there is no option to register the Auxiliary in case i buy a replacement Auxiliary. Any thoughts? |
08-06-2023, 09:38 PM | #32 |
41
Rep 38
Drives: 2013 E93
Just to add:
The sensor values from Bimmerlink screencapture are with the vehicle running. I’ve read all the posts regarding batteries and the battery discharged warning and still have the following questions… Which of the 2 batteries is responsible for the warnings… and starting (posts seems split as to what battery does what) And there should be no way that the large battery has 14.7V at the posts/terminals while off and at rest… Could the small Aux battery that is depleting be charging the big battery at rest??? Maybe both are shot but don’t want to replace both if one isn’t broke… |
08-06-2023, 09:41 PM | #33 |
Rep 442
The main battery is reading too high when off. Why? Not sure. Either it's getting overcharged, or maybe a fault with the battery to cause it to read so high.
Is there a date stamped on the battery posts? If they are original, I'd start out by replacing both batteries. |
08-07-2023, 01:27 AM | #34 |
Rep 5,002
Yeah you need to load test those batteries. See which one is wonky. Could be both.
These cars do weird things when the batteries start to go. The main battery was pretty reasonable, even at the dealer when I did mine. $250 and I installed it. Not sure what the aux will run you. |
08-07-2023, 10:09 AM | #35 | |
41
Rep 38
Drives: 2013 E93
Dealer wanted $330 (part) + 220 to register the main Battery when I called … didn’t mention anything about the Auxiliary battery… which is difficult to source here but did find a couple 3rd party sources for $300-330 CDN 😬. Getting both replaced at the Stealer is going to run me over 1k. That’s why I’m trying to be selective… |
08-07-2023, 10:25 AM | #36 | |
Rep 442
See this thread. https://f15.bimmerpost.com/forums/sh....php?t=1699570 |
08-07-2023, 12:15 PM | #37 | |
41
Rep 38
Drives: 2013 E93
As far as sourcing Here in Vancouver, Canada, sources are more limited. Rock Auto won’t ship here. I spent hours calling various sources for that hard to find LN1 battery. Just not sure if that’s the problem battery. I have confirmed both are original to the vehicle. With the Neg posts removed, they both read 12.5V after having charged the batteries… will try and drive it around for a bit then re check… |
08-07-2023, 02:36 PM | #38 |
Rep 7,489
If you're in a country other than the US market...AC Delco makes/sells the LN1 AGM battery...which probably means that you may be able to source one from a GM dealership. If you can't get one from Rock Auto...try your local GM dealership's parts department and inquire if they sell the LN1 AGM 50AH battery.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-07-2023 at 03:05 PM.. |
08-07-2023, 09:38 PM | #39 | |
Rep 5,002
If you have the time to save the $300 then go down the diagnosis path. If not, buy code reader, both batteries, and ride on for the foreseeable future. I’m surprised it failed this early. My OE battery went 90k miles and 9 years. Have you tried an independent. that would also save you the %30 or more I suspect |
08-08-2023, 10:47 AM | #40 | |
41
Rep 38
Drives: 2013 E93
I had it booked for service tomorrow as I have the extended warranty just to make sure all was well with the charging system et al but batteries are not covered. I spoke to them just now… and this Stealership says the batteries through the parts dep are: $412 main $650 Aux What a joke… I’m going out to buy the 3rd party batteries now.. |
08-10-2023, 04:54 PM | #41 |
41
Rep 38
Drives: 2013 E93
Wound up going to the Dealership to get a new main battery as the price was the same there as anywhere else (although the Auxiliary battery would have been 2-3X the price). Service guy was really nice and load tested the batteries for me and confirmed it was the main battery that needed replacement.
Replaced the battery myself and registered it. 2 days of driving later, no warning and no issues. |
08-10-2023, 04:57 PM | #42 |
41
Rep 38
Drives: 2013 E93
These are all the warning I got… and it was the main battery… not auxiliary
Hope it helps to diagnose a battery problem for someone… |
08-13-2023, 11:59 PM | #43 | |
Rep 5,002
