08-05-2023, 03:53 PM | #1 |
Rep 73
HELP! Hole in Coilpack/Spark Plug Cylinder Housing
So I was changing my valve cover today and pulled the coilpack furthest to the back. It was filled with oil. I went to clean out the coilpack housing and there is a V-shaped hole in the side. Wtf. This can't be normal right?
Car seemed slightly sluggish lately and smelled burning oil. Hence I decided to do the valve cover. But now I'm certain this was the real issue. Any ideas wtf happened? Afraid to ask what needs to be done to fix it... |
08-05-2023, 05:29 PM | #2 |
Rep 442
Wow. Someone has been in there doing something, but what??
Is that lower part worn too it looks? You can buy that aluminum piece separate. But I'd be concerned how it got like that. |
08-05-2023, 06:01 PM | #3 | |
Rep 73
Thats great its a seperate piece. Not sure how I would actually replace it tho.... I have seen absolutley nothing on this issue. Any idea where I can find a replacement piece? Or part number? |
08-05-2023, 06:08 PM | #4 |
Rep 442
Not sure what year your car is, but I think they are all the same. Or start over on realoem.com with your car year.
https://www.realoem.com/bmw/enUS/sho...diagId=11_4452 You'll also need the seal below it. Looks like only a couple bolts holding it. You'll need to pull your injectors I think. |
08-05-2023, 07:00 PM | #5 | |
Rep 73
Still... would like to know how the hell this happened. Hopefully its just a once in a blue moon type of thing... |
08-05-2023, 08:46 PM | #8 | |
Rep 73
I had my plugs done about 10k miles ago. Didnt have time to do it myself so took it to a shop. Haven't done any work on the car since. I just hope whatever made that hole is long gone. |
08-05-2023, 10:09 PM | #9 | |
Rep 442
If they didn't say anything about the hole, then most likely they caused it. |
08-05-2023, 11:38 PM | #10 |
Rep 73
Not the original owner. Didnt go to the dealer. Got the car fully stock at about 82k miles. Its a 2015 35i. Car was maintained very well. Plugs were never changed tho.
08-06-2023, 09:57 AM | #11 | ||
Rep 648
The coils can be a pita to remove. When they changed the plugs, somehow they broke one coil or plug and had to use tools to remove the rest. Damaged the insert and chose not to tell you. The damage is in a place where only a mechanic can cause it, so you can be sure someone effed up and didn't say anything. I'd be worried too, about having a piece of aluminum floating around in the engine, possibly blocking oil flow or interfering with moving parts. No way of seeing, unless you open up the engine. Though you have driven for 10k miles like this, so you might be OK. Definitely replace that insert and see if you can locate the missing chunk, when insert is out. Sad to say, but when it comes to mechanics you have to assume the worst and find another one, once you have an issue like this. If you take it back to the same place that likely caused the issue, (and indeed they were responsible for the damage) they now will look at you as a clueless "tool", unless you call them out on it. But you have no way of proving anything. Catch22 sort of.. Still, if it was me, I'd let them know what I found out, call them out on it. Any skilled mechanic would have seen the damage and told you about it, not just ignored it. Which leads me to believe this happened when they changed the plugs. If it is a bigger reputable shop with a manager/owner and several mechanics, talk to the manager, because he should know he has a shady mechanic. |
Monkeypoop39.00 Hop7464.50 |
08-06-2023, 04:50 PM | #12 | |
Rep 73
I didnt have an issue removing the newer ones plugs yesterday either. But removing the one from the damaged cyclinder was way too easy since it was flooded with oil. Also the seal seemed completely worn. The more I think about it, the more lucky I feel i didnt have an actual fire.... let alone a few misfires. I wonder if this was the source of the oil leak and not the valve cover? I dont know where exactly that hole leads to... |
08-11-2023, 06:43 PM | #13 |
Rep 73
Update: Finally got the spark plug recess. Of course there was no DIY on this but got it removed and put the new piece in pretty easily after removing the valve cover again. I tried to do it without pulling the injectors but #6 was blocking the last bolt to take out the recess. Ended up pulling both injectors just to make sure they are ok.
No sign of that big chunck that broke off. I agree that whoever caused it may have taken the piece out and just not said anything. Also, as pointed out before, there is a little wear on the piece below the recess. But decided to not mess with it and see how it holds up. But i did replace the gasket. Got the valve cover back on and everything seems snug. Wasnt able to torque the injectors yet. Apparently they are supposed to be torqued to a mere 2 nanometers?? I dont have a torque wrench that goes down to 2nm so will get that tomorrow, clean out the rest of the oil in the spark plug well and pull the plug to see if it needs replacing too. Hope to be up and running soon. (Sorry i didnt take better pics.... it looked like it was going to rain so had to hurry) |
08-11-2023, 08:23 PM | #15 | |
Rep 7,487
Did a little work on the pic to increase contrast and lighten the image a bit and the missing piece is right there…as they say…if it was a snake, it would have bit ‘cha.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-11-2023 at 08:29 PM.. |
08-11-2023, 08:49 PM | #16 |
Rep 73
Welllll..... F🤬ck me.
I guess if you cant laugh at yourself, who can you laugh at. 😂 I deserve it for rushing. And it didnt even rain. You guys are awesome for enhancing the pictures to look deeper than I did. Thank you. |
08-11-2023, 08:54 PM | #17 |
Rep 7,487
…the good thing is we know where the missing piece is…even if you have to redo things…its better than not knowing where it went and possibly causing more damage down the road.
Thanks for sharing the pics because if you hadn’t…it would still be a mystery. Hang in there.
Hop7464.50 |
