09-22-2017, 06:00 PM | #1 |
162
Rep 317
Open sunroof gives my ear drums a womp womp sound!
I've had this with other cars too. But with most cars usually the pop up spoiler in the front, when I open the sunroof breaks up the air, so it doesn't do it.
But this X5 does it every time more so at highway speeds. Unless I crack one of the rear windows which reduces the air pressure in the cabin when the sunroof is open. But this also tends to raise the wind noise with a window cracked open. A search here does not turn up much if others have found a solution. I could replicate this womp womp when we owned our Saabs by holding the sunroof spoiler down but it went away as soon as it popped back up. Problem seems to be this spoiler is made of some type of net material that allows the air to pass through it. Is this something the dealer can adjust or replace? Any other ideas
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White |
09-22-2017, 06:21 PM | #3 | |
162
Rep 317
Someone should tell "Heimlich" that this shouldn't be with a 65k car Maybe its that high gloss detailing I've given the paint causing it to be too aerodynamic and I should rough it up a bit
09-22-2017, 06:24 PM | #4 |
Self-Deprecating Narcissist
7266
Rep 6,561
your Q5 has this effect as well, i know from experience... price has nothing to do with it... all marques at various price points on various models do this. "rain guards" are the only way to stop this from happening but to me those are so gross and "ghetto" that i'd rather just tilt the sunroof.
Chadmatic660.50 |
09-22-2017, 07:42 PM | #5 | |
162
Rep 317
09-22-2017, 07:45 PM | #6 |
7266
Rep 6,561
i believe they have... having the hvac system on and operating at a desired temperature with fresh or filtered air is the solution in addition to aiding in increased efficiency and fuel savings.
09-22-2017, 08:15 PM | #7 | |
Rep 62
09-23-2017, 04:02 AM | #9 |
261
Rep 733
Aw c’mon!
Duct tape, carefully applied.
09-23-2017, 10:03 AM | #10 |
7266
Rep 6,561
A5 is a coupe and has a sunroof that does not open, only tilts. I had an S5 back in 2009 shortly after it debuted. Awesome car. The Q5 has this effect as well but not if you open the roof all the way same with the X5. If you click the sunroof switch once it will open to the point that the engineers thought was the most suitable. If you hold the switch it will open further. A feature I like on LR/RR products I own(ed) is the multi-stage opening windows. You click once and it opens slightly to a set point then if you click again it will go down automatically to the fullest opening.
09-23-2017, 10:03 AM | #11 | |
Rep 62
I'm still shopping for the perfect used X5 and will now be sure to open the roof the next time I take one out. |
09-23-2017, 01:07 PM | #13 | |
7266
Rep 6,561
^exactly. problem solved. air has several exits and isn't entering and exiting the same opening creating that effect. this is a nifty feature the LR/RR vehicles have and it's for several uses or at least has several uses for me.
https://www.audiworld.com/forums/q5-...-open-2792663/
09-23-2017, 08:55 PM | #14 |
Rep 255
Drives: 2021 M-B GLS 580
My X5 M-Sport does not buffet at all and I have had 3. Either wth the roof all the way open or just vented. 35, 75, 105, 125 mph...no buffeting. Wind noise of course.
2020 X5 M50i
2017 X5 50i M-Sport (Retired) 2013 X5 50i M-Sport (Retired) |
09-24-2017, 10:24 AM | #15 |
Rep 256
Drives: '17 F15 MSport
This issue isn’t limited to open sunroofs or a particular make/model of vehicle. It will happen when just one window is open to a certain point. Easiest solution is to just crack another window somewhere so air has another way out. Not that big of a deal, engineers can’t change physics.
http://blog.caranddriver.com/explain...ne-car-window/ Last edited by IndyJer; 09-24-2017 at 10:31 AM.. |
iconoclast7265.50 Chadmatic660.50 |
09-24-2017, 07:33 PM | #17 | |
162
Rep 317
Because you're tall . Did you know that taller people on average are more successful in life? So now you want us vertically challenged people to give up our sunroofs too. I did notice on my 1.5 hr highway drive back home last night as others have noted that if I only open the sunroof partially (kinda defeats a panoramic roof) once it goes back far enough for the spoiler (mines more of a bug catcher) to pop up then the air buffeting starts. I found out years ago with most of my older cars i had to crack a rear window, but that also serves to increase cabin wind noise. Looks like MB will have to solve it and then others will copy the fix! Last edited by expidia; 09-25-2017 at 06:14 AM.. |
09-25-2017, 09:07 AM | #19 | |
Rep 400
expidia161.50 |
09-25-2017, 09:19 AM | #20 |
7266
Rep 6,561
Audi offered sunroof delete for a very long time and then between 2010-2015 it was not an option but they have brought it back now on some of the new models. I agree that it should at least be an option for the customer to decide if they want one or not despite the fact that I love sun/moonroof and always use them.
09-26-2017, 09:30 AM | #21 |
Rep 62
I crack the rear windows just a tiny bit when that happens. Clears right up.
- Patrick |
iconoclast7265.50 expidia161.50 |
