04-21-2023, 08:46 PM | #1 |
Rep 11
Brakes too sensitive for anyone???
Have a 2016 X5 35i and was wondering if anybody has had the issue of brakes being pretty sensitive but sort of in a bad way. If the brakes are cold and I step on them around 5-10mph, I feel like I'm going to eat the steering wheel. There is no happy medium. They get a little better after they warm up but still pretty sensitive. Also noticed when brake and then apply more pressure, the brake force seems to be too aggressive. Anyone else? I'm the second owner of this car, not sure if the last owner has done any brake fluid flush or replaced the rotors/pads. I looked at them the other weekend and there's a good amount of meat left of them. Rotors also looked good.
04-21-2023, 11:53 PM | #2 |
Rep 5,002
This is the way bmw has gone over the last decade. They’re touchy!
After I get out of my e46 I find myself bobble-heading around until I develop a light touch. |
04-23-2023, 11:55 PM | #4 |
Rep 188
Drives: BMW X5 and BMW 7 Series
I’ve had 6 BMW’s since 2014 and never had this issue.. Is it the Brake Pads and rotors?
Danyal.N55
04-24-2023, 09:42 AM | #6 |
Rep 660
Rwc0920 - Is it possible that you are not use to brake on BMWs or that you are new to your particular BMW?
If you switch between cars with an over boosted vacuum assisted brake pedal, or those with long pedal travel, or those needing their brake lines blead, you may find BMW brakes in general will feel a bit "touchy". If the grabbiness you described is accompanied by grinding noises, pulling the car to one side of the road, or high pitched screeching, then there may be a mechanical issue. Other than that, I think what you are describing is normal. Some pay extra for that level of initial brake bite or dial it out with different pad compounds as mentioned above. |
04-24-2023, 10:37 AM | #7 |
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Swap in ceramic pads. Initial bite is a little softer (I prefer it actually) and you get the added benefit of GREATLY reduced brake dust on your wheels. Win-Win
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
04-24-2023, 11:26 AM | #8 | |
Rep 5,002
I’ve been there, and wish I wouldn’t have been, le sigh. |
05-02-2023, 07:42 PM | #9 |
Rep 11
Thanks for all the input! Going to be swapping out for ceramic pads, new front rotors, and doing a brake fluid flush and see if there's a difference. Stay tuned
