03-02-2020, 06:42 PM | #45 | |
Rep 2
I am not. I will be back home tomorrow and am hoping the fluid will still be on the ground so I can investigate. I am curious to see if there is any fluid under the vehicle at the airport as well. Thank you for the reply. |
02-26-2022, 09:47 AM | #46 | |
Rep 5
02-27-2022, 09:48 PM | #47 |
Rep 234
Haven't noticed anything different. I have almost 40k miles since. I just checked Newtis and they are recommending the Hypoid G1 or G3 for rear. I was given the orignal information by getbmwparts.com back in 2019. I will update the first post with this thread with the corrected information. I will likely just wait until 60k miles to replace with Hypoid G3 or maybe flush both at next oil change which will be in another 7k miles.
02-28-2022, 07:12 AM | #48 | |
Rep 5
02-28-2022, 04:32 PM | #49 |
Rep 234
08-22-2022, 01:30 PM | #50 |
Rep 49
So I am trying to get a bit of clarity because there is losts of back and forth. So I am posting this with my specific setup, sometimes it makes it easier for folks to find the info they are looking for this way, I believe I have a common setup. I have a 2017 X5 50i w/M-package(eye candy), standard rear diff(verified by no drain plugs, just fill plug), no active suspension. I want to put together a list of BMW recommended fluids and alternatives cheat sheet. Here is my start. If you are running something that I can add to the alternatives list or any other recommendations I will update this post.
Front: BMW - PN 83222413511 -- BMW G2 Hypoid differential Fluid 75w-85 GL-5 Alternatives: Redline 75W85 fully synth. GL-5 -- SKU: 50104 (1 qt) LiquiMoly GL5 75W-90 LiquiMoly -- PN 2048 (1 qt) Rear: BMW - PN 83222295532 -- BMW 75w-85 G1 GL-4 Rear Axle Gear Oil Alternatives:????? I have crossed referenced this list with multiple vendor websites that "verify" compatibility, but I think the forum can give yet another verification. If you have the same X5 setup, and running something different let us know. The price of BMW fluids is EXPENSIVE, the alternatives will give everyone a more budget friendly option.
2017 X5 Xdrive 50i M Sport
2015 M235i(for sale) 2007 335i e90(sold) Last edited by MiniMotoMan; 08-22-2022 at 02:34 PM.. |
11-10-2022, 11:55 PM | #51 |
Rep 5
Hi everyone, new to the site and appreciate all the information. I have a 2017 35d and am at 110K. I am going to change the transmission with the ZF kit from FCP Euro but also want to change other fluids while I'm at it. Can anyone comment if I am good with the following:
Rear Diff: Motul Gear 300 LS SAE 75W90 Front Diff: Red Line 75W85 GL High Performance Gear Oil Transfer Case: Red Line MT-LV Thanks! |
11-11-2022, 02:30 AM | #52 | |
Rep 5,007
11-11-2022, 10:46 PM | #53 | |
Rep 112
https://www.fcpeuro.com/products/bmw...ll-83222409710 |
12-01-2022, 02:43 PM | #54 |
Rep 28
Can anybody clarify if there are any acceptable alternatives for the rear differential oil now that BMW Hypoid Axle Oil G3 is the specified recommendation? This oil is really expensive right now (~$120 for 2X500mL).
I am going with Liquid Moly 75W90 GL-5 for the front diff. |
12-01-2022, 08:27 PM | #55 |
Rep 19
Had this done at BMW earlier this year and my service advisor thought the crazy price for the gear oil was a mistake (crazy expensive) so he marked it down to a more relative price. Made me laugh.
12-20-2022, 12:51 AM | #56 |
Rep 1,179
Does anyone who’s done this know if this kit has the right fluids?
https://www.fcpeuro.com/products/bmw...t1#description |
12-20-2022, 01:14 AM | #57 | |
Rep 5,007
I not, wrong kit |
12-20-2022, 01:26 AM | #58 |
Rep 1,179
12-20-2022, 02:02 PM | #59 |
Rep 234
12-20-2022, 02:57 PM | #60 | |
Rep 1,179
OK, I'm really confused now. You mention that you used the 83120445832 for your standard rear. The FCP euro site says that's for the outer chambers of the Adaptive suspension. It says that standard uses 83222413512.. So is that right? Edit: Nevermind, I just noticed that you updated the initial post |
12-20-2022, 09:36 PM | #61 |
Rep 5,007
Yeah, I just used redline GL—5 75w85 front and rear. There’s nothing special about the base, none DHP, non limited slip diffs. BMW specifies a rather asinine weight that’s as close as makes no real difference.
1 gallon of redline will do both diffs twice. Done and easy. |
12-20-2022, 10:34 PM | #62 | |
Rep 28
12-21-2022, 02:35 AM | #63 |
Rep 5,007
What worries me is the front diff holds practically no fluid so I’m prioritizing changing it often.
12-29-2022, 12:40 AM | #64 |
Rep 1,179
I've seen a couple of people mentioning not to fill until oil streams out. One YouTube video claims there's a service bulletin (for E70) saying to use 600ml. Does anyone know if there's any truth to that?
12-29-2022, 02:26 AM | #65 | |
Rep 1,024
On the //M, the centre sections takes about 1.2L, this is what came out of mine and the same as other //M owners. Now where it gets precise is on the clutch pack outer sections on the //M, where the specific amounts comes out and goes back in. Some people have done the same, fill till it drips out, but that's not recommended. That carbon mod stuff you were looking at is only for the //M diff outer clutch pack sections. Also on the //M the front and rear centre use the same oil. Can't remember the p/n but its not the G2/G3 stuff, its something older. Also if the non //M diff is like the //M, if you stick your head under there, the fill plug will have the oil type casted into the housing. So for the //M I see both the Carbon-Mod and the SAF-XO on the respective plugs. Last edited by Chilled; 12-29-2022 at 02:34 AM.. |
skoold2003791.00 |
12-29-2022, 11:41 AM | #66 | |
Rep 7,160
