06-17-2019, 02:28 PM | #45 | |
Rep 7,160
08-14-2019, 03:23 PM | #46 |
Rep 29
Hi I wan to update my NBT installation in my F15 from 2014. I have the head unit but am looking for the ATM that will work in my country (Denmark) I know that need to use the vin from the ATM for the HU.
But can I use an ATM module from any EU country with active sim? And can I get it to work with a ATM from a different model and use the connected drive account from the donor ATM even when from different model? |
11-23-2019, 02:48 PM | #49 | |
Rep 1,826
Drives: BMW iX Xdrive40 MSport
Since then my car (which is still under 3rd party warranty) has gone to BMW for some work and they were able to diagnose it just fine :-)
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
11-23-2019, 06:54 PM | #50 | |
Rep 107
Drives: 2007 E92 335i/2014 F15 X5 35D
thanks |
11-28-2019, 12:34 PM | #51 |
Rep 535
Best is to flash/upgrade the unit with ATM vin selected, the other vin changing options dont work as well in my opinion. You will need ATM FA or make one using ATM vin with your car's other options listed.
Present: 2014 X5 50i
11-28-2019, 12:38 PM | #52 |
Rep 535
Although I probably could, I am very hesitant. Each step can be complicated and essentially the whole thing has been posted on several other forums and one thing wrong can ruin it all. It is also time consuming. What I want to avoid is people who are not ready to flash their units, start the process and then realize its a big mess because they cannot start their cars and something got messed up. If you have coded and flashed in e-sys, follow the thread and if you still have questions, I will be happy to answer.
11-28-2019, 12:39 PM | #53 | ||
Rep 29
11-30-2019, 12:55 AM | #54 | |
Rep 535
Code NBT Evo with your Car’s FA. Once successfully done, your car on connected drive in car will update to an X5 from the donor ATM-vin-car. Then the code might come. Took some trial and error. Also in my case the latest ios connecteddrive version worked after I created new username. PS: unless you flash the vin to evo (not just change with certs) connecteddrive will not work. Try sending code at this step too. Make sure same software version. |
11-30-2019, 07:08 AM | #55 | ||
Rep 29
09-10-2020, 11:17 PM | #56 |
122
Rep 359
Anyone knows if these units would work on F15 and F16 after coding?
https://www.ebay.com/itm/113400868051 |
09-10-2020, 11:34 PM | #57 | ||
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
09-11-2020, 08:50 AM | #58 | |
122
Rep 359
11-13-2020, 12:15 AM | #59 |
232
Rep 337
11-14-2020, 12:31 AM | #60 |
Rep 535
Yes. ATM vins cannot be changed. And ATM vin should match HU VIN if you want data from ATM. So best way is to put a filter and change the HU vin. Remember to flash the HU fully not just use the certs to change the vin.
DenBel232.00 |
03-06-2021, 06:50 AM | #61 |
Rep 16
Dears, I need advice
i have BMW F15 2015 with NBT from factory, I purchased NBT EVO and touch screen, from eBay and purchased ATM module white one from local market was removed from X5 F15 2018, it has valid contract, Also I purchased plug n play ATM retrofit wiring from eBay. when I started the installation process, I found that my car does not have TCB , it just has small box in the back and it has only two antenna wiring (Antenna control ECU 928708) now what is required to proceed with the ATM retrofit shall I buy another shark tale fin and attach it to the white ATM module that I have then put it some where in the trunk and make additional wiring all the way to the NBT EVO, if yes what would be the additional wiring required in addition to the wiring loom I purchased from eBay. |
03-06-2021, 08:47 AM | #62 | |
232
Rep 337
03-07-2021, 02:54 AM | #63 | |
Rep 16
03-07-2021, 12:05 PM | #64 | |
232
Rep 337
Image) it is attached to. If the module Is not there then check under the roof.. You can also run your vin on mdecoder.com to check if you have teleservices option Last edited by DenBel; 03-07-2021 at 12:10 PM.. |
03-08-2021, 02:51 PM | #65 | |
Rep 16
so definitely car has no TCB, can you advice please what would be the required wiring to retrofit the white ATM I purchased. |
03-08-2021, 03:13 PM | #66 | |
232
Rep 337
