02-28-2023, 05:48 PM | #1 |
Rep 18
Suspension components 90k miles
So I’m hearing weird noises inside the cabin when going through uneven surfaces and bumps sometimes. Nothing too loud. I have to turn of the radio to really hear it. I’m pretty sure is some suspension components whored out since my X5 is 90k miles. Now my question is, what component should be failing at this millage? I guess all depends on how you drive your car etc. But anything I should start with? Thanks
02-28-2023, 06:12 PM | #2 |
Rep 1,532
This would be a good place to start: https://www.fcpeuro.com/products/bmw...-31126864821kt
03-01-2023, 01:56 AM | #3 |
Rep 5,002
Agree with what vivek posted. Although, more than likely you don’t need the top ball joints. I don’t think those wear out too much.
I’d also say you’re due for shocks all around. Most cars shocks give up the meaningful part of their abilities around 75k miles. If you do those lower control arms and shocks you’ll have a very fresh feeling car again. You’ll be astounded the difference it makes in handling. You think you’re just hearing a few creaks but the amount of precision and comdfort you’re missing is huge. |
Johanian7.00 |
03-01-2023, 07:54 AM | #4 | |
Rep 52
03-01-2023, 10:17 AM | #5 |
Rep 660
If you are just chasing a noise, another option to try before going with suspension component refresh, is to start with swaybar bushings and end links. Both are cheap and DYI.
Not saying the others are wrong, especially considering the miles. Just depends what you are trying to achieve and how much do you want to invest. At that mileage most stock suspension and components are due some love. Last edited by Clifton; 03-01-2023 at 12:34 PM.. |
Johanian7.00 M302_imola842.50 |
03-01-2023, 10:22 AM | #6 |
Rep 1,532
For an all-around combination of price, performance and comfort I'd recommend Koni special active: http://findershop.koni.com/nl/en/cat...cl.-x5m-m-50-d
I've not personally used these but heard good things about them. I have used the Bilsteins available for the F15 on other platforms and I wouldn't recommend (ride too stiff). If only Koni made the yellow adjustables for our cars...
03-01-2023, 10:28 AM | #7 | |
Rep 660
I've used the B6s on an E36-M3 and they were definitely firm, but much more compliant than coilovers. |
03-01-2023, 12:33 PM | #8 | |
Rep 1,497
03-01-2023, 12:57 PM | #9 |
Rep 1,532
I believe they are either B6 or B8--they're yellow and B4's should be black. This is on an e30 with H&R springs (not sport or race--the 'touring' or whatever comfort one they offer). Compared side by side to my other e30 on ground control coilovers with Koni SA yellows...it's hard to explain. There is MUCH more suspension travel with the H&R springs, but until you hit the bumpstops the Koni/Eibach combo (these are very stiff linear coilover springs, not progressive springs like a standard lowering spring) is somehow more comfy than the Bilstein/H&R. For example you feel the painted lines more in the Bilstein car. You feel a pothole more in the car on coilovers.
Clifton221.50 |
03-01-2023, 03:09 PM | #10 | |
Rep 112
+1 to this. I have a 2015 X5d just over 100k miles, and have the same sound you do. I'm replacing all of this, plus the struts, when I find myself a weekend to do it. Also, you can save about $200 if you "downgrade" the LEM-3896001 and matching part for the other side with the Meyle HD versions. I've heard from people who had both in their hands that the Meyle's were more robust and appeared/felt closer to OE than the Lemforder for whatever reason, even though Lemforder should be the OEM. |
03-01-2023, 03:45 PM | #11 | |
Rep 1,532
03-01-2023, 04:56 PM | #12 | |
Rep 628
Every BMW, but especially the SUVs (the added weight), are due for a front suspension rebuild every 80-110k miles. Depending on the roads being driven on. Our F15 @ 103k is starting to show signs of thrust arm bushing wear and I'd bet other bushings/bearings are on the way out as well. I'll bite the bullet (like I always do) and do everything at one time for ~$1000 and not have to worry about it again for another 100k. The FCP kits are great for the lifetime warranty if you keep your cars for a long time. I've used it many times on suspension components. |
03-01-2023, 05:27 PM | #13 | |
Rep 1,497
OP, not sure if you're happy with your ride height, but you could go with a set of BC Racing coilovers for prob close to what you pay for the Bilstein's. Seems like a paid right at $1K for the coilovers. |
03-01-2023, 10:19 PM | #14 |
Rep 187
Drives: 2013 x5 m57
Why not take it to a independent or dealer and have them do a under car once over instead of asking random people on the internet what to throw money at?
You have almost 100k on a performance vehicle. Preventative maintenance would be to replace all bushings along with the struts due to mileage. Probably should do it sooner than later as the next thing after noises is usually tire wear. This is as bad as having a “powertrain malfunction” and asking what it could be. |
03-02-2023, 12:35 AM | #15 |
Rep 5,002
I used the bilstein b4’s. They’re just ok. Some uncontrolled damping going on. They don’t seem to know whether they are a sport of comfort shock and in the end they feel like they’re neither.
I would go straight to the Koni Reds (actives) that Vivek mentions above. I’ve never been steered wrong with a Koni. Bilstein HDs yellows used to be good. Back in the e30 days. These days they ride like dump trucks, to me. If and when Koni makes a yellow for the X5 I’ll be first in line… I’ve had all the ones mentioned above. Custom bilstein HDs are great if you have the coin ($3k+), but Koni yellows are 90% as good for a fraction of the cost. Koni Reds are very good for most applications. That’s my order of operations when I make a purchase. I’ll bet stock replacements are also good, but they’re double the cost for same-ish performance. Not my cup of tea. |
Vivek.1367.50 |
03-02-2023, 07:10 AM | #16 | |
Rep 51
Variante Alta94.00 |
03-02-2023, 09:41 AM | #17 |
Rep 270
I have a 2015 F15 35d with 100,000 miles. A few months back I started to hear a light clunk from the front driver’s side suspension over small bumps. The car was in yesterday for the 2nd EGR Cooler recall so I had the dealership look into that as well. It’s the control arm (Tension Strut P/N 31126851691/2). Ordered left and right ones from FCP and will install when the weather warms a little. The quote BMW provided includes the P/Ns for replacement nuts, collars and screws (see below, CDN $). FCP has a great video DIY for this repair - nice of them!
https://www.youtube.com/watch?v=dTe9ZtM-Weo |
03-02-2023, 10:13 AM | #18 |
Rep 5,002
$600 for those cheap ass arms that sometimes fail within 30k miles. BMW should be ashamed of themselves.
The value a new MacBook for this 20 yr old design made of 50 yr old materials. Laughable. |
03-02-2023, 12:37 PM | #19 | |
Rep 1,532
BTW I understand that the metal itself doesn't wear lol, I was more referring to hitting potholes, crawling over curbs, extra strap point if I'm stuck in snow/mud/etc. This is a truck to me, it's my ski/inclement weather car and I've had tow drivers do stupid shit like refuse to tow my e39 from the TOW HOOK and insisted on strapping to an aluminum control arm that has a big yellow sticker saying DO NOT TOW OR LASH...we couldn't reach an agreement and AAA had to send another driver. That's the kinda shit I just don't want to deal with on a vehicle that I see no specific benefit of aluminum arms. Variante Alta $600 is an insane price for those parts, holy shit. I would also do it myself if I got a quote like that; I'd bet an indy shop would do it for less than 50%.
03-02-2023, 12:59 PM | #20 | |
Insta~ f10_sapphire
158
Rep 412
I drove over a curb slow with back tire accidently. Next day later air suspension was out on that side. |
ciscorob15.50 |
03-02-2023, 05:25 PM | #21 | |
Rep 51
03-03-2023, 02:30 PM | #22 | |
Rep 628
My X5's, while not really "sports cars" are more of a family hauler vehicle that only really sees smooth pavement so the aluminum parts it came with are what I throw back on. But I don't seem to have the same problem with tow driver's you've had either. Now that you mention the problem with active steering arms being different, I'll have to see what ours requires by VIN. It's pretty well equipped but don't think it actively steers. Has adaptive suspension... |
Vivek.1367.50 |
