11-19-2023, 08:55 PM | #1 |
Rep 176
Lane Departure, Cruise Control, Active Blind Spot Malfunction
Hello, I was hoping that someone on here has experienced the same or similar problems and can help point me in the right direction without just throwing money at parts. Here’s the story….one night last week i was driving home and as soon as i turned into the driveway, i received a Cruise Control malfunction. I thought i would check it the next morning, maybe just a glitch…..next morning i get in , as soon as i crank the car, cruise control malfunction warning, followed by lane departure failure. I drove down the road and then active blind spot malfunction. I turned on the cruise control and it worked fine. All the buttons on the steering wheel work fine. I went back to the house and hooked up to ISTA. Here are the codes I found:
ICM: 480004 lane departure (TLC) 48004A vibration actuator not ready 480143 LDM function operational readiness operation cruise control CAS 030490 steering wheel electronics (LRE) (LIN): missing LIN slave KAFAS 800A07 Actuator steering wheel defective I ordered a replacement vibration generator and installled it today….but no luck, all the same codes…after going through ISTA the other thing that was going up was the 030490…picture attached. The diagnosis was to replace the steering wheel module. Does anyone have any experience with this? |
11-21-2023, 07:00 PM | #2 |
Rep 270
Drives: 2015 X5d M Sport Metallic Whit
Hmmm…any luck with it going away on its own? Sounds a bit like an intermittent control unit failure but I’m no expert. I’d certainly allow for a full shut down of the car (locked) and you might find things get sorted out. It’s just a lot of stuff for an all of a sudden failure of a number of system components…highly unlikely.
11-21-2023, 10:38 PM | #4 | |
Rep 176
Thank you for the response |
11-22-2023, 08:57 AM | #5 |
Rep 445
Is the battery original? Battery date would be stamped on top of one of the battery posts.
11-22-2023, 02:20 PM | #6 |
Rep 4
I am in the process of diagnosing this exact problem. It appears to be related to a brief loss of contact in the LIN bus and/or the power supply to the Steering Wheel Control Module. Today, I removed the steering wheel airbag and wiring harness within the wheel. I noticed the connector contacts for the LIN bus were not shiny and cleaned them (next to yellow airbag connector in pic). After driving the car for a while, the number of fault warnings seemed to have decreased. I will next remove the clockswitch and clean the input contacts at the other end. Next I would check the clockswitch for continuous continuity. This might take some digging to resolve completely. BTW my batteries are all new.
Update — This did not work. I have ordered the steering wheel module. Fingers crossed. Last edited by MORX5d; 11-23-2023 at 07:27 AM.. Reason: Update |
03-28-2024, 10:12 AM | #7 |
Rep 196
Bumping this. I have the exact same problem as Brian Hinton with the 3 malfunctions in the same order on my 2018 440. Anyone got a solution - is it the battery?
03-30-2024, 04:05 PM | #8 |
Rep 4
I replaced the steering wheel module some time ago with a used unit from eBay. The symptoms immediately disappeared. However, after some time the same symptoms reappeared. It has progressively gotten worse and is now approaching similar frequency to my original problem. I have now ordered another steering wheel module and am awaiting shipment. I believe it to be this module as the warning generally occur during speed reductions and are not related to movement of the steering wheel (clock spring). It also seems to happen on days with higher humidity and not on dry days.
04-02-2024, 10:20 PM | #9 |
Rep 176
It is in the steering wheel switch cluster. It best to buy a new one because they come with a tab for the clock spring. You remove the tab wheel installing and you know that it’s in the right place.
04-07-2024, 06:53 PM | #10 |
Rep 4
From Ravina - weird thing happened to me. All 4 problems went away a few days ago. I’m assuming this means there’s a loose wire somewhere. Not sure if a scanner can diagnose this issue ?
Hi Ravina - unfortunately you will not get to the bottom of this with a code scanner. ISTA runs you through a diagnostic procedure to check wiring and then if that fails it suggests replacing the steering wheel module. As brianhinton77 suggests, this could also be in the clock spring. I am travelling for the next month but after that I expect to replace the module again and also once again inspect the wiring harness. Failing these steps I will have to investigate the clock spring. Note that each situation could be different. I am also convinced mine occurs mostly on high humidity days so try to keep an eye on the problem and humidity/weather. It’s a slow process to figure this out. Whether it’s a loose wire or failing module, from what I can see there is a brief loss of a communication signal on the Lin bus. It is now April 28/24 and I’ve gone a week without a cruise control/lane departure malfunction. After replacing the module for a second time and still getting the error, I had a closer look at the wiring harness. It seemed that some of the connectors did not provide a tight connection to the pins in the wheel sockets. Rather than install a new harness, I carefully applied some sideways pressure on the pins (battery disconnected) so that they would sit differently in the connector (more side friction). The poorest connection seemed to be the power connector with just two pins. |
Yesterday, 10:24 AM | #11 | |
Rep 196
Thank you MORX5d for your detailed commented. I think I have the same problem as my errors have now come back after working for a week. I’m not a mechanic so hopefully your procedure is relatively simple to do for a newbie.
