03-24-2016, 12:19 AM | #2224 |
Rep 592
03-24-2016, 12:50 AM | #2225 |
Member
7
Rep 32
Drives: 2014 X5 M-Sport
Hi, managed to code everything I wanted except two items. I want the DRL's to stay at full brightness with the headlamps... I couldn't find the FLE module.
Also, I saw on another cheat sheet that it was possible to enable the fog lights with the welcome lights. Has anyone ever done this in this thread? If so, could you please show me how? Thank you guys. Coded for the first time today with no errors! Proud of my self ! |
03-24-2016, 01:13 AM | #2226 | |
Rep 592
I tried looking for the FLE module as well but didn't find it. I haven't tried it since. I haven't tried the LED foglight code either. Post your specific question and someone will chime in. |
03-24-2016, 01:20 AM | #2227 |
Member
7
Rep 32
Thank you! Hopefully someone will figure it out!
03-24-2016, 01:44 AM | #2228 |
Rep 1,181
The FLEs show up after you VO-code to remove 5AP and 8S4 if I'm not mistaken. The first one is for Anti-Dazzle while the second is for VLD. I have a pre-FLE car, but the equivalent for me are the LHM modules. They didn't show up until after I VO-coded.
so, depending on how important those last two features are to you, you can VO-code, but it'll wipe out everything you've just coded.
03-24-2016, 08:42 AM | #2229 | |
Member
7
Rep 32
03-24-2016, 08:19 PM | #2230 |
Member
7
Rep 32
Hi, Having trouble getting this code to work :
Unlock when STOP Engine : BDC_BODY 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK When I click to select active , there is only one option of not active. Any ideas ??? |
03-24-2016, 10:54 PM | #2231 |
Rep 1,181
Very strange. I recently coded it on, then off again since my wife didn't like it. Have you tried more than once, i.e. disconnect then re-start again?
03-24-2016, 11:02 PM | #2232 |
Member
7
Rep 32
Yes. No luck. I had vo coded the whole bcd body folder back to stock even.
03-25-2016, 11:02 AM | #2233 |
Rep 196
03-26-2016, 12:37 PM | #2235 |
Rep 40,756
PM sent.
03-27-2016, 12:46 AM | #2236 | |
Rep 8,364
But, cafd_000017be.caf.005_218_003, for example, has aktiv (werte=01) and nicht_aktiv (werte=00). Did you try changing just the werte value to 01? |
03-27-2016, 09:47 AM | #2237 |
Rep 592
Sorry for the delay in my response. Pls contact Shawn, you probably have to reinstall PSzData n Esys. After my visit to the dealer yesterday, I have to reinstall the same programs. Keep us posted.
03-27-2016, 09:53 AM | #2238 | |
Rep 40,756
03-27-2016, 01:23 PM | #2239 | ||
Member
7
Rep 32
03-28-2016, 08:11 AM | #2240 |
Rep 4
I am also having the same trouble:
"BDC_BODY 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK" shows only nicht_aktiv. Please let us know if you have any success after changing the werte value as this is one of favorite features. |
03-28-2016, 12:15 PM | #2241 | |
Member
7
Rep 32
03-28-2016, 04:51 PM | #2243 |
Rep 40,756
PM sent.
03-28-2016, 10:29 PM | #2244 | |
Rep 8,364
Some functions take over 30 minutes to work, but I am not sure about this one since this happens to one I have never had any interest. Driving can usually clear errors but I have not read that time spent driving will lock in newly coded functions. You might try turning off car and coming back to see if the coding worked. Also, specifically to this function, I think I remember reading that the doors must auto-lock while driving away in order to auto-unlock. This is similar to coding to fold mirrors; if door button is used to close them, then they will not auto-unfold with door unlock. |
