06-26-2016, 09:56 AM | #2509 |
Rep 7
Can someone tell me how to code the vent seats so the fans running at a higher speed. Also is it possible to increase the brightness of the trim lighting. I have read through pretty much all the pages and can't find an answer. Thank you in advance for any help.
06-26-2016, 10:03 AM | #2510 | |
Rep 3,990
For increasing brightness of the ambient lighting...not possible because they are already at 100%.
06-26-2016, 02:05 PM | #2511 | |
Rep 256
Drives: '17 F15 MSport
Front Seat Ventilation Temperature SM2 3008 SKL_TEMP_SOLL_ST1_KI I think temperature is misleading since the seats aren't cooled, but I do believe these settings adjust the fan speed for the ventilated seats. |
06-26-2016, 08:22 PM | #2512 | |
Rep 3,990
06-28-2016, 06:39 AM | #2514 |
Rep 40,752
PM sent.
06-29-2016, 03:39 PM | #2516 |
Rep 8,364
06-30-2016, 09:25 AM | #2517 |
Rep 16
06-30-2016, 10:33 AM | #2518 |
Rep 40,752
Read I-Step Current:
http://f30.bimmerpost.com/forums/sho...postcount=1403 Then Cross-Reference I-Step Current to ISTA/P version: https://mega.nz/#!41Rz2LwI!VIsVDE5JE...2Ee14wU5kVyfWI
06-30-2016, 11:53 AM | #2520 |
Rep 40,752
You can program car with E-Sys, although it is not as easy as using ISTA/P like dealer does, and there is always risk of bricking ECU(s) during process.
06-30-2016, 01:54 PM | #2521 |
Rep 24
06-30-2016, 02:44 PM | #2522 |
Rep 500
Welcome back!
06-30-2016, 09:23 PM | #2524 |
Rep 458
VO Question
I have 2 questions on VO coding. I have a Canadian version 2016 F15 and looking to understand VO coding a little more:
1) I see 2VB (tire pressure monitor) on US and UK X5s but not on canadian X5s. I have TPMS on my summer tires. if I add 2VB will I get tire pressures? 2) I notice 258 (run flat tires). If we change to non run-flats should we be removing this code? I was reading the other day that BMW codes the suspension based on the tire type. maybe the suspension would be stiffer if this code was removed. Has anyone tried this. Thanks for your help. |
06-30-2016, 10:06 PM | #2525 | |
Rep 47
Thanks again for your help. |
07-02-2016, 08:32 PM | #2527 | |
Rep 16
3020àTCM_STARTLOCK_BRAKE set to: nicht_aktiv 3020àTCM_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv |
07-02-2016, 08:35 PM | #2528 | |
Rep 458
Do I need to VO code a particular cafd Oreo I need to add anything else? Thanks. |
07-02-2016, 10:26 PM | #2529 |
Rep 592
Adding/deleting 2VB or anything in your FA doesn't do a thing until after you VO code the appropriate ECU folder. In the US, TPMS is under the HU_NBT folder/RDC_DRUCK_TEMP.
07-03-2016, 02:36 AM | #2530 |
Rep 480
Is it possible to activate sports mode when shifting the gearbox handle to M/S. Now I have to push the driving mode button (which is not always easy to find without looking), and switch the gearbox handle. What's the difference anyway? M/S changes the gearbox, but sports driving mode changes the gearbox and suspension right?
