06-16-2017, 08:55 PM | #3521 |
Rep 75
# of turn blinks
Is anybody could give an advice?
What is new code for to change number of turn blinks? This one doesn't work anymore: BDC_BODY 3068 Changing the # of Turn Signal Blinks werte=04 werte=02 BDC_BODY 3068 Changing the # of Turn Signal Blinks werte=04 werte=02 Thanks!
Maxipes |
06-16-2017, 11:19 PM | #3522 |
Rep 8,364
06-16-2017, 11:20 PM | #3523 | |
Rep 8,364
Sections are meaningless. Use cheat sheet in OP. |
06-19-2017, 12:55 AM | #3524 |
Rep 103
Hi guys
I found the code for updating the user interface for iDrive 5 to the one found on iDrive 6, no gesture control supported but everything else looks and works fine. For those interested, parameter HMI_ID_VERSION found in HU_NBT2 must be changed from ID5_plus_plus to ID_6_lite (pay attention to select "lite"). Many thank to the guys on the F30 forum where i found this information . Maybe it should be added to the OP if others find it useful. |
06-19-2017, 02:22 PM | #3525 | |
Rep 75
There are only small things will make me happy after all coding I perform with my e40 are: 1. Change soft turn signal from 3 to 5 blinks 2. Make trunk door closed from FOB and from driver's door knob 3. Disable "Goodbye" message on screen after engine stopped Any advice how to change these options would be greatly appreciated. |
06-19-2017, 02:46 PM | #3526 | |
Rep 674
PIA_DEFAULT_TIPPBLINKEN Change to 02 = 5 blinks! Other stuff should work from the Cheat Sheet as far as I know. For launcher codes hopefully other more experience members can explain more.. |
06-19-2017, 03:08 PM | #3527 | |
Rep 75
What module for change turn number of turn signal? Same as in sheet in beginning of this thread? BDC_BODY 3068?There is no HKFM n my ECU, I have HKFM2 and there is no commands for Close trunk via Keyfob/inside button
Maxipes |
06-19-2017, 04:55 PM | #3528 | |
Rep 674
My car has all the modules in the sheet, not sure why you don't have them.. If you want to learn how to use the luncher codes look at bottom of this thread. http://www.bimmerfest.com/forums/sho...d.php?t=983245 |
06-19-2017, 09:33 PM | #3529 | |
Rep 8,364
06-26-2017, 03:38 PM | #3531 |
Rep 40,650
PM sent.
06-27-2017, 02:42 PM | #3532 | |
Rep 450
I've just double checked this and this option is definitely not in BDC_BODY\3069 like it should be. I did read on another forum for a different F model BMW that this new option was only visible when using E-Sys 3.28, I am using E-Sys 3.27.1 and the latest data files as of yesterday. Last edited by NPickles; 06-28-2017 at 08:46 AM.. |
06-29-2017, 12:38 PM | #3533 | |
Rep 8,364
Mapping has nothing to do with E-sys or PSdZ version. You likely need to update E-sys Launcher past 2.6.x (current version 2.7.1) so that you can have updated mapping to find FDL. Fxx, Ixx, & Gxx Series Coding: (No Request) Latest Software Links |
06-29-2017, 03:37 PM | #3534 |
Rep 225
Received my cable today and decided to have a crack at doing some coding.
Just been outside sat in the car for the past hour following the guide and tutorials. I've managed to change a few things I wanted in the BDC_BODY section such as close windows and mirrors via key fob and door handle lights when in reverse. However, I'm having issues with the other sections e.g; Can't SCH_FBD, FCH_TOEHKI and TASTER_FBD in HKFM for trunk close via fob. My HU_NBT2 section looks like the below, all the folders have no names and are just named "." I understand the cheat sheet is a little out of date for the 2017 models, is there an updated guide anywhere else? or maybe I'm just clueless and looking in the wrong places? lol
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone |
06-29-2017, 09:20 PM | #3535 | |
Rep 8,364
Dots means you incorrectly configured E-sys Launcher. |
Jlu88360.00 |
06-29-2017, 11:41 PM | #3536 | |
Rep 225
I looked at the Launcher Cheats Codes you created, but wasn't how to sync all the Github coding into E-Sys, so I copy and pasted all the codes into a wordpad file, gave it a .xml file extension and dropped it into C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\FDLCodes and yes, nothing happened lol. Seem to be getting worse at using computers these days *sighs*
06-30-2017, 05:23 PM | #3537 | |
Rep 8,364
You got the right location. Open XML in internet explorer to make sure you copied correctly. Git can display in multiple forms. For latest premium launcher, you must select authors in configuration window. Then, first time you go to fdl editor, you need to check auto fetch and select refresh. |
07-06-2017, 01:23 AM | #3538 |
Rep 11
6WA combi - night mod off?
hello,
how to forbid my combi instrument (6WA) to switch to night mode pls? COMBI DIM_NACHT_EIN active non active own value if I put in my own value, like "FF" or if I set it to "non active" - it doesnt help and after restart my combi instrument switches back again from day to night mode. any help would be very appreciated ! |
07-06-2017, 06:02 PM | #3539 | |
Rep 8,364
aleksaleks5.50 |
07-06-2017, 09:03 PM | #3540 | |
Rep 225
Still wasn't able to figure out how to get the Launcher Cheat codes to work. However, I re-read the 1st page and realized I forgot to deselect Update "VCM after TAL execution" and "Update MSM after TAL execution". After I deselected those, all the folders were displaying correctly instead of displaying ".", so I just referenced the cheat sheet. Pretty happy with the changes, coded the following; Mirror folding via key fob Mirror folding via comfort access M startup splash screen Indicators display on HUD Removed iDrive disclaimer Removed camera disclaimer Handle lights on reverse Close windows via key fob Remember whether AC was on or off when car was shutdown Trunk close via key fob - this one I had to search for as it wasn't in the cheat sheet for the iDrive 5.0. Going to list the instructions below just in case anyone else is searching for it. You won't find "SCH_FBD", "SCH_TOEHKI" or "TASTER_FBD" in HKFM2. Instead you need to look for the below in HKFM2 instead; 300B HKL_REMOTECONTROLLIFTGATEBUTTON_BUTTON_TYPE change werte from 02 to 05 (allows remote button to both close and open the tail gate)
07-11-2017, 07:53 PM | #3541 |
Rep 6
Opasha,
Thanks for the great post! New to the forum and tried PM'ing for the download links but got an error that your inbox was full. When you get a chance could you PM the download links for the applications? Thanks! |
07-11-2017, 07:55 PM | #3542 |
Rep 40,650
PM sent.
