07-21-2017, 06:37 AM | #3565 |
Rep 40,310
Why do you bother with ICOM when there is no benefit or advantage over a $20 ENET Cable?
07-21-2017, 08:51 AM | #3566 |
Rep 96
Drives: 2010 335d, 2018 540d
07-21-2017, 08:57 AM | #3567 |
Rep 40,310
For updating (flashing) Modules in E-Series, ICOM is a Must. But for F-Series, it provides no benefit over ENET. I have both ICOM A1 and ICOM A2, and never even use them as their connections are overly complicated and there is zero derived benefit.
07-21-2017, 09:20 AM | #3568 | |
Rep 96
My real issue is not being able to use my ICOM on my E90. I have searched other forums for days and have posted help questions with no positive results. I was hoping that since assistance on this forum has been so exemplary, that someone here might be able to assist on the connection issue that I’m experiencing. |
07-21-2017, 10:23 AM | #3569 | |
Rep 40,310
And the answer to your question varies based on Software you are wanting to Connect with, but assuming it is any EDIBAS based application such as INPA, NCS Expert, WinKFP, etc., it would be as follows: Use EasyConnect Utility, and set it as follows: Type: REMOTE IP: 169.254.92.38 Mode: OBD_ab625 Check Icom lock checkbox. The set EDIABS.ini section as follows: [Configuration] ;================================================= ============================ Interface=REMOTE [TCP] ;================================================= ============================ RemoteHost=169.254.92.38 Port=6801 Then launch Software Application to connect to car.
07-21-2017, 01:12 PM | #3570 | |
Rep 96
Is there a more appropriate E-series forum I should continue this post on or can I PM you? I REALLY appreciate your assistance! |
07-21-2017, 01:21 PM | #3571 | |
Rep 40,310
Is your Firewall and Antivirus software all disabled?
07-21-2017, 05:02 PM | #3573 |
Rep 40,310
PM sent.
07-23-2017, 03:21 PM | #3574 |
Rep 210
Hi,
First off wanted to thank you guys, especially Shawn. What a guy! I tried some coding today on my 2017 X5m and found some of the cheat code descriptions to be missing or different from OP. Is there a new cheat sheet? |
07-29-2017, 12:03 PM | #3576 |
Rep 176
Hi All,
I have a 2016 F15, i set the auto unlock after driving to Nicht Aktiv, however, the car unlocks only the driver door once the engine is tuned off. I want to keep the doors locked, I don't want it to be unclocked automatically. Can someone tell me where i can change that. I have everything on the Unlock Doors when STOP engine inactive but still only the driver side unlock. Any help is greatly appreciated. |
07-29-2017, 08:14 PM | #3577 | |
Rep 8,364
07-29-2017, 08:32 PM | #3578 |
Rep 176
07-30-2017, 11:55 AM | #3580 |
Rep 40,310
PM sent.
07-30-2017, 03:17 PM | #3581 | |
Rep 8,364
Line 59/60. |
07-30-2017, 03:46 PM | #3582 | |
Rep 176
I have it as Not Active, but it still unlocks the driver door only when the engine turns off. I wonder if there is another area for the driver door. I want it to keep it locked at all times. Any help is greatly appreciated. |
07-31-2017, 07:42 PM | #3583 |
Rep 8,364
I do not know any other place. I would talk to dealership; it should be behaving as desired from factory.
08-03-2017, 05:48 PM | #3584 |
Rep 14
Hello. Appreciate everyone on their inputs for coding.
A newbie in coding here. Can't find HU_NBT folder? There's HU_NBT2 folder but no HU_NBT. Any help, please? is it the psdzdata file (using lite v62.1)? |
08-03-2017, 05:54 PM | #3585 |
Rep 40,310
Your car has newer NBT2 EVO (HU_NBT2) Head Unit instead of older NBT NEXT (HU_NBT) Head Unit. Code it instead.
08-03-2017, 06:01 PM | #3586 |
Rep 14
