08-03-2014, 06:05 AM | #1 |
Rep 179
Roof Rails
Finally, i was able to add my vehicle to my profile so that I can track it.
Looking at the details, M Sport High-gloss Roof Rails Roof rails in Satin Aluminum Aerodynamic kit Shadowline exterior trim Sport automatic transmission with shift paddles Anthracite headliner M steering wheel Sport seats Multi-contour seats Adaptive M Suspension It states both "High-gloss Roof Rails" & "Roof rails in Satin Aluminum" under M Sport. I was told by the dealer that I will be getting black ones by default and that's what I told them when I ordered the car. Did anyone face this similar issue? |
08-03-2014, 07:09 AM | #2 |
Rep 1,887
I think he is probably correct in saying that the default is high gloss which is black. I know when we did my build, we didn't specify roof rails, and when he printed out the build, it had the high gloss listed. X50i M sport. I don't know why you would have both listed like that. But I would be cautiously optimistic that you will get high gloss black.
08-03-2014, 10:56 AM | #3 |
Rep 20
That's probably just the description of the package and not directly what your car is spec'd for. If you look at the ordering guide it says black rails are the default for the Sport Package but you can choose satin if you prefer.
What did you use to find your car online? VIN or Prod #? Mine is in production but still doesn't come up on website. |
08-03-2014, 11:22 AM | #4 |
Rep 58
When I ordered mine, the online system showed both. The order confirmation orifginally showed satin and I wanted black. I made that notation to my CA, and they came in black. Don't trust what is on hue he web page as it's likely just he generic package contents.
Make sure your CA knows what you want and you have that in writing/email. Then if it's wrong when you show up to pick it up you have documentation as to what you wanted. In the end, don't stress over it..it'll likely be right. |
08-03-2014, 11:52 AM | #5 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
I would not put much stock in the tracker for options. The tracker is notoriously wrong. Go off your build sheet because that is what you WILL get . My tracker was wrong the entire time I tracked both x5's I ordered yet they showed up at the dealer exactly how my build sheet stated
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
08-03-2014, 08:38 PM | #6 | |
Rep 179
08-03-2014, 08:40 PM | #7 |
Rep 179
Thanks guys.
I have my comments in writing and CA is aware of it. By the way, it also shows my seating as comfort seats and below it says Multicontour. |
