04-02-2024, 08:40 PM | #1 |
Drive Different
53
Rep 225
Advice: What Else to Replace with Valve Cover?
2016 35i 100k miles with valve cover gasket leak. Will replace entire cover. Should I replace plugs and coils? Thanks.
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002* *Gone |
04-03-2024, 08:34 AM | #2 |
Rep 5,015
04-03-2024, 10:47 AM | #3 |
153
Rep 354
Replacing Plugs is a wise move. I've only ever needed to replace a single coil in 140k miles - so, I would not do that, myself.
Clean the vanos solenoids and new o-rings. New valvetronic seal. New Crankcase Vent Pipe Hose. Oil Filter Housing Gaskets (OFHG) would be a good choice since you are in the area, too. |
04-03-2024, 03:55 PM | #4 | |
Rep 43
Valve cover repair
I did replace the coils and the spark plugs. FCP Euro has a Kit that includes both. Here's what I got from FCP Euro: 1. BMW Crankcase Vent Hose (BMW-11127584128) x 1 [$48.69] 2. BMW Valvetronic Actuator Seal Mounting Screw (BMW-11367609963) x 2 [$0.99x2] 3. BMW Engine Cover Ball Pin (BMW-11127593207) x 2 [$4.53x2] 4. BMW Valvetronic Actuator Seal (BMW-11377502022) x 1 [$12.37] 5. BMW Ignition Service Kit (KIT-12138616153KT5) [$195.48] 6. BMW N55 Valve Cover (BMW-11127570292) [$525.99] Total $793.57 Local BWM shop wanted $2055.96 for this repair. (only for the valve cover replacement, no idea how much the coil pack and spark plugs would cost) Watch this video if you are going to DIY it. https://www.youtube.com/watch?v=ctdCtvKC6dE Happy to answer any questions you have since it's still fresh in my memory. I still need to put the plastic covers back but the car started and runs fine
_______________________________________
07' 328i Coupe | 11' 335d | 16' X5 35i MSport Last edited by kanchis; 04-03-2024 at 03:57 PM.. Reason: missed a part |
04-04-2024, 11:10 AM | #5 | |
Rep 5,015
If you do open the system, it’s critical that you do the BMW recommended TSB for oil priming. Technically, you shouldn’t have any issues after that, but it doesn’t exactly give me warm fuzzies. |
04-04-2024, 11:55 AM | #6 | |
Rep 448
04-04-2024, 02:35 PM | #7 | |
153
Rep 354
Additionally, when doing oil filter changes, I immediately rev to 2k rpm and hold it there for ten seconds to guarantee a good prime off an empty filter housing start. |
04-04-2024, 10:26 PM | #8 |
Rep 5,015
The n55 has different oil passage ways in the engine vs say the n52 and n54. The n55 has serious issues self bleeding once the system has been opened. BMW wrote the TSB because of the bearing failures due to dealership work on the n55 specifically. Not some random report from an astranged do it yourself person. There’s a one way valve in the housing body, and this is what’s different than just a filter change. You’re draining the system once that one way valve is opened. It needs to be primed.
sukhk5272192.00 |
04-04-2024, 10:38 PM | #9 |
Rep 5,015
Oh, good call. I did this when I rebuilt my s54, but I’ll start doing it in this case too. Thanks!
