      01-26-2015, 07:48 AM   #1
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Time Zone choice missing from Auto-Time
I have been moving from CT to ET over the course of the last two weeks. At no time did "Auto time set" work in terms of showing the correct time zone.
In each case, I had to deselect Auto time set so I could manually enter the correct time.
Apparently it is normal to be able to select the time zone, but I have no such setting.
Anyone know why I do not have this option? My build date is 11/14.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      01-26-2015, 09:04 AM   #2
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Not sure if you have seen this or use a different screen name for this forum.
http://www.bimmerfest.com/forums/sho...d.php?t=822425
      01-26-2015, 11:25 AM   #3
Xeno
Xeno's Avatar
315
I was part of that discussion but my issue has not been resolved
      01-26-2015, 11:51 AM   #4
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
You might need to resort to coding and VO Code HU_NBT.
      01-26-2015, 12:06 PM   #5
Xeno
Xeno's Avatar
315
I do not know how to paste the flicker photo link here (from bimmerfest) but the photos clearly show the option of selecting a time zone. Am I the only one without this or is there a deeper setting that I am missing?
      01-26-2015, 12:13 PM   #6
MattBianco
MattBianco's Avatar
Originally Posted by Xeno View Post
.....the flicker photo link here (from bimmerfest) but the photos clearly show the option of selecting a time zone. Am I the only one without this or is there a deeper setting that I am missing?
Here you go...I can grab the link easier as it comes from my post.
      01-26-2015, 12:27 PM   #7
Xeno
Xeno's Avatar
315
Thank you. I am using my iP waiting for my sister to have surgery and could not get copy/paste to work on your link
I called BMW Genius and was told to refresh using BMW assist and if that fails go to dealer
      02-03-2015, 11:21 AM   #8
Xeno
Xeno's Avatar
315
I am finally back home. I had to make a quick run to my BMW dealer and they had a 'genius' look at my system who was not able to resolve my issue.
Has anyone found a solution or are we still waiting on a software update?
      02-03-2015, 11:42 AM   #9
opasha
opasha's Avatar
1329
The only solution I mentioned that might help will be to code your car or let the dealer do the same procedure. It will resync your HU_NBT (iDrive).
      02-11-2015, 01:10 PM   #10
MattBianco
MattBianco's Avatar
Found this code. But this should work without coding.
ENABLE GPS SYNC FOR CLOCK
KOMBI -> 3000 -> Anzeige_Konfiguration -> GPS_UHR -> aktiv
      02-11-2015, 01:14 PM   #11
Xeno
Xeno's Avatar
315
Sorry, but how does one do this? I have not done any coding on my F15 and am unlikely to do so while it is so new so I am lost with such references.
      02-11-2015, 01:18 PM   #12
MattBianco
MattBianco's Avatar
That would require connecting with a member in your area who can do this, or opening the coding thread (the one with over 40k views started by opasha and at minimum getting the cable.
As I am no expert in coding myself, let's see if the experts opine favorably on the mentioned code in my prior post.
      02-11-2015, 02:37 PM   #13
opasha
opasha's Avatar
1329
Xeno, I'm pretty sure I sent you the coding software. You just need to buy yourself an ENET cable. I walk everyone through the coding process step by step slowly. No need to feel afraid .
Also, the code Niko showed above is supposed to be active by default. It activates your clock synchronization with the GPS as stated. If yours is deactivated for some reason, that could explain your issue.
UHR in german means WATCH. So that code means GPS_WATCH.
      02-11-2015, 02:42 PM   #14
Xeno
Xeno's Avatar
315
Ah the power of opasha! There were no email notifications of any other replies than Opasha!
I am taking my 2008 X5 in tomorrow morning and will ask my SA if they can remedy this small but annoying issue for me on the 2015 X5.
      02-11-2015, 02:45 PM   #15
opasha
opasha's Avatar
1329
All they will do is VO Code it in order to restore your KOMBI to factory settings. Hopefully that works. If not, keep me posted. You'll have a big smile on your face when you see the cool codes and features that are enabled (that should have been enabled by default since 70% of the cheet sheet is enabled by default in Europe).
      03-08-2015, 05:48 AM   #16
Xeno
Xeno's Avatar
315
This morning my X5 did auto-adjust to Daylight Savings time so I am just curious if this was true for others who like myself have trouble with auto-adjust when crossing time zones (and have not coded in a solution).
I am not yet willing to do any coding and this summer I will be driving from OK to CA which means two time zones coming and going.
      03-23-2015, 01:08 PM   #17
Magicmarker
Drives: 2020 M340i
I also travel frequently between time zones and my time does not auto-adjust when crossing the boundary. The time *did* automatically adjust for daylight savings.
today I had my SA check this and was told that BMW is aware of the issue, a fix is on the way. They gave non-specific info on when the fix would be available but I'd summarize it as "30 to 60 days".
I was advised to use the manual settings until the update is ready.
      03-23-2015, 01:59 PM   #18
Xeno
Xeno's Avatar
315
Are we being instructed to go to the BMW dealer in 30-60 days for a fix or will this particular issue be fixed wirelessly?
      03-23-2015, 02:42 PM   #19
Magicmarker
Drives: 2020 M340i
I was told "we will call you back when the update is available". Wireless update was not mentioned. I expect I will need to take the car in for the update.
      04-21-2015, 05:41 PM   #20
Xeno
Xeno's Avatar
315
My X5 was at the dealer to prep for an upcoming month of travel that involves moving across time zones. The SA did not seem to know how to solve my complaint since it could not be tested in OKC, but he did say that the "time zone setting" shown above is unique to those with EBT.
I am certain I misunderstood the SA because I thought he suggested that being connected by cable might make a difference as over against being connected from my iP via (ordinary) BT.
      04-21-2015, 07:00 PM   #21
MattBianco
MattBianco's Avatar
.... but he did say that the "time zone setting" shown above is unique to those with EBT.....
That just does not sound right. Why would they offer this option with EBT as it has nothing to do with a practical function they could charge for. Let's see those with no EBT and not coded chime in.
      04-22-2015, 08:52 AM   #22
Xeno
Xeno's Avatar
315
I have wanted the anti-dazzle configuration to be finalized before I think about coding my F15. So other than coding can others report if your clock automatically adjusts when crossing a time zone? If so, did this work from the start or did the dealer implement a fix or XXX?
