04-29-2016, 04:31 AM | #45 | |
Rep 455
That and, of course, put in whatever spacer is required to keep me from hearing that horrible "no I ain't wheel bearings but I sure sound like it" noise. I emailed one service dept and heard nothing back (I even included photos of the service order from the other thread documenting the issue), so I think it's time for a new service dept. I'll probably bring it in for both things. PITA...
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone |
04-29-2016, 08:13 AM | #46 | |
Rep 3,834
Apparently the squeal is cause by brake dust trapped between the pads and rotors (causing high frequency vibration, like how a violin makes sound), so sanding the edge allow it to catch less and let the dust out. Roughing the pads to reduce the vibration frequency that causes the squeal and for the pads to seat better.
04-29-2016, 04:23 PM | #47 |
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
If squeal is vibration caused by dust build up, aren't there sprays that work?
04-30-2016, 08:22 AM | #48 | |
Rep 3,834
05-13-2016, 06:10 AM | #49 |
Rep 455
Well, although the brake squeal isn't permanently eliminated by bedding in the brakes, I have noticed that I can at least make the noise go away for a few days by a few hard stomps on the pedal in succession. I know this technique has worked for other vehicles and I think it was mentioned above. I guess I'll just be driving around and periodically doing "ABS testing" every week or so...
05-13-2016, 09:05 AM | #50 | |
Rep 729
My car has been sneak up on you quiet ever since. My service advisor said that if enough people have their dealerships request this, BMW Warranty will most likely create a separate SIB for the M car brake squeal. Chamfering the brake pads apparently increases air flow between the pads and the rotors, as well, helping clear the fine brake dust that is one of the culprits in making the squeal. |
05-13-2016, 09:10 AM | #51 | |
Rep 455
05-13-2016, 09:14 AM | #52 | |
Rep 729
I'm fairly certain the acronym means Problem and Measures management Aftersales or in German: Problem und Mebnahmenmanagement Aftersales. What was done to my car is basically the same thing the JNoSol had done to his car, which seemed to work for him, as well. Last edited by UrbanExtant; 05-13-2016 at 09:25 AM.. |
05-13-2016, 10:14 AM | #53 |
Rep 3,834
I took it to the dealer, they sanded down the edge of the pads to let dust out and they machined the rotors. Added anti-squeal paste on the back of the pads. It's been 500miles and I'm squeal free for both the M5 and X5M.
05-13-2016, 11:35 AM | #54 |
Rep 2,245
Yup - im having this done at my 1200 mile service, already confirmed with them.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
05-13-2016, 11:51 AM | #55 |
Rep 3,834
I would like to replace the pads with Carbotech 1521. No dust and less noise.
05-13-2016, 12:47 PM | #56 |
Rep 2,245
Would just changing the pads also cure squeal? Or is it the rotors as well, hence you getting those machined.
05-13-2016, 01:15 PM | #57 |
Rep 3,834
Carbotech 1521 pads replacement should reduce noise and eliminate brake dust.
05-13-2016, 02:11 PM | #58 |
Rep 2,775
Drives: F95 X5MC
Just sent an email to my Service Advisor to see if I can get my X5M in to try to fix the annoying break squeal. Thanks to everyone who offered advice!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
05-13-2016, 02:23 PM | #59 |
Rep 455
Thanks all. I'm going to do this too. I'm tired of living with the noise. And having to do crazy braking scenarios routinely.
05-13-2016, 02:34 PM | #60 |
Rep 729
For those going in for the brake pad chamfering like JNoSol and I had done, also make sure they apply the anti-squeal paste, they did that to my car when they did the brake pads, and I believe they did it to his as well.
05-16-2016, 09:03 PM | #61 |
Rep 472
I understand the complaints but the performance level these vehicles are at could be considered at race car levels with power and the amount of weight it has to haul down. With brakes it's usually pretty much a given that serious performance will come with some sacrifices. The M brand is supposed to be the ultimate in performance for BMW. If it is a luxury car you want they make models more akin to it.
Not trying to lambaste you guys over it. Just saying... The cars at the track have high performance brakes as well and they all squeel like a garbage truck. It's pretty much how these things work. Want real serious track ready car? You should consider there are probably going to be sacrifices. Im surprised they have done as well as they have bringing as much luxury along with the performance level without very intolerable consequences. I have the same issue with my Range Rover Sport
18’ 540i XDrive M Sport
https://www.flickr.com/photos/mik3ymomo/ |
05-17-2016, 12:05 PM | #62 | |
Rep 2,775
Drives: F95 X5MC
05-17-2016, 12:46 PM | #63 | |
Rep 2,245
Of all my so called high performance vehicles (e46M3, Supercharged Range Rover sport, C63, F10 M5 and now my 911 GTS) I have heard nothing that compares to this so consistently - if it was intermittent, i could deal with it. Even on my M5, it wasn't all the time, and it would go away with some bedding or a wash.
05-17-2016, 12:48 PM | #64 |
Rep 2,245
Which dealership did it for you?
05-17-2016, 12:54 PM | #65 | |
Rep 3,834
I just emailed Carbotech on where to buy 1521 brake pads. Less dust and less squeal.
05-17-2016, 03:06 PM | #66 |
Rep 2,245
Let us know what you find out.
