09-04-2018, 09:02 AM | #155 | |
Rep 190
Drives: 2020
09-04-2018, 11:14 AM | #156 |
Rep 1,092
MPBK with solid disk doesn’t squeal.
09-04-2018, 01:20 PM | #157 |
114
Rep 346
yewlock - would you please expand a bit on the MPBK - do you have it installed? What has your experience with it been vis a vis braking performance? Cost?
I am still in break-in mileage and no squeal. If it does become an issue and the MPBK is the solution, I will go that way quickly as opposed to mucking around with short lived quasi-fixes and multiple trips to the dealer. BTW - what does PuMA stand for? |
09-04-2018, 02:37 PM | #158 |
Rep 1,152
Disappointing for over $100K car. My M6 GC did not squeal nearly as much as my X5M. Do we need to have a class action suit vs BMW to have them address this properly???
09-04-2018, 03:01 PM | #159 | |
Rep 1,092
09-04-2018, 03:02 PM | #160 |
Rep 2,775
Drives: F95 X5MC
Found this online:
PuMA is a worldwide BMW database of all reported problems and most with their appropriate fixes. I think the acronym means Problem and Measures Management Aftersales or in German: Problem und Mebnahmenmanagement Aftersales.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
09-04-2018, 04:32 PM | #161 |
114
Rep 346
I'm glad you gave me the English "version" first - Thanks.
09-04-2018, 06:10 PM | #162 |
114
Rep 346
Understood - but do you have the MPBK installed already? What I am trying to sort out is if there is a totally different BMW front brake package that we can try if the squeal develops.
Those of us with new X5M purchases have just paid out over $100,000 for this high performing vehicle and don't want to diminish our enjoyment over a squeal issue. I won't be happy if I have to pay for a non warranty squeal fix via the MPBK but I am not going to get myself sidetracked if that becomes an issue. On a side note I am well underway with specs and test drives on our next vehicle addition. Life is short - need to enjoy the views, smell the roses, drive the roads |
Bobby_Drake390.00 |
09-05-2018, 12:30 AM | #163 |
114
Rep 346
I just looked up the BMW MPBK on the BMW site and it is a two piece rotor, not a one piece. It has an aluminum hat riveted on.
Am I looking at the wrong part or missing something? |
09-05-2018, 06:58 AM | #164 |
Rep 209
^^ Well that does not sound like the OEM X5M brake system. For starters, the OEM discs are just cross-drilled, there are no grooves.
The hats are on radial pins, not rivets as described in the clip. Also, to my eye the OEM rear calipers look like sliding units, not fixed units - please feel free to correct me if I'm wrong. |
09-05-2018, 09:15 AM | #165 |
114
Rep 346
You referenced the MPBK as not squealing as it has a solid disk. When I looked up the MPBK on the BMW website is describes it as a two piece rotor.
The MPBK is not the OEM brake system. It is a BMW upgrade to the stock BMW X5 M brake as I understand it. I am wondering if you have not distinguished between the stock BMW X5M rotors and the BMW MPBK rotors? Where are you finding the MPBK with a solid disk? Last edited by Apple Corps; 09-05-2018 at 09:43 AM.. |
09-06-2018, 10:34 PM | #166 | |
Rep 7,160
The rear rotor and caliper is the same on the E70 M, X5 50i, and the F85. Whatever the PDF is above is not for the X5M. Those rotors are entirely tooooooo small! Lol Now instead of the MPBK rotor (which would fit the F85) you can upgrade to the M5 rotor. F85 and M5 (F10 I believe) share the same caliper but have different mounting points. Adapters can be made and are solid on eBay from Solid aluminum. Plus the M5 rotors are effing cheaper. But idk if they complain of any squealing or not.
09-06-2018, 10:37 PM | #167 | |
Rep 7,160
Look at those rotor sizes. This has got to be for a car or X1/2/3 or something. F85 rotors are 390/34 and 385/24.
09-07-2018, 09:55 AM | #168 |
114
Rep 346
Maverik259
If you look at the heading it is for a 2018 X5 M - that was a screen grab straight from the BMW site. I did not even notice the rotor size as I was focused on the rotor construction. That may be a site error but it reads as it reads. Skyracer referenced a BMW MPBK with a solid disk - that is what I was trying to sort. Based on your input there is no BMW MPBK for our F85 and the brake squeal solution vis a vis "newly designed" parts really does not exist? Good news is my X5 M is so new that a squeal has not reared its head and this may all be academic for late build owners. Bad news is maybe not. Last edited by Apple Corps; 09-07-2018 at 10:01 AM.. |
09-07-2018, 10:23 AM | #169 |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Don't hold your breath...my 6/21/18 production '18 X5M squeals with 850 miles on it! Perhaps it's climate-related? I see you're in CA, low humidity??, but out here in the Northeast it's been brutal!
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
09-07-2018, 10:50 AM | #170 |
114
Rep 346
Kief - I suspect I will be dealing with it at some point - that is why I have spent some time researching it in advance. If it develops I'd pay for an after market solution out of my own pocket before I would do the multiple trips to the dealer with wasted time and effort.
You are correct - Central Valley of CA is quite dry and hot. Our rain season will be arriving shortly and I won't be shocked if it develops. Rather surprised that a clear cut solution to the issue has not surfaced. |
09-07-2018, 02:21 PM | #171 | |
Rep 7,160
09-07-2018, 02:24 PM | #172 | |
Rep 7,160
Personally I think simply having a slot option would help with the squeal quite a bit. There is also a seller on eBay who is taking the blanks from the MPBK, cutting in slots And selling at a mark up.
09-07-2018, 03:04 PM | #173 |
114
Rep 346
Ouch - RB takes "isn't cheap" to a whole new level
$6,000 - $7,000 would take some serious thought as a solution. Two questions - have you experienced the really bad squeal issue and, if so, did you install the RB system and find it to really solve the squeal issue? Thanks... |
09-07-2018, 06:38 PM | #174 | |
Rep 209
That being said, I doubt that the cross drilling helps matters. Not all BMWs with fixed calipers are noisy: my wife's m240xi has them front and rear (no drilling or slotting on the discs) and it is nice and quiet. |
09-07-2018, 07:48 PM | #175 |
114
Rep 346
The more I try to dig into this the more having a spray bottle of P21S and the garden hose handy once a week is the "solution" - but I hope something better is available.
09-08-2018, 12:23 AM | #176 | |
Rep 7,160
