03-31-2024, 12:20 PM | #1 |
Rep 2
S63 multiple codes after replacing engine
Hi
Replaced engine due to heavy knocking from crankcase. Engine consumed oil. Everything went well during install. After replacing engine i have these codes stored. I have done the following: Checked ground-strap at VTG to chassie. I cant find any other main ground. It doesnt have groundstrap as e70 at front differential. checkes all grounds at injectors to block, and grounds from dme harness to cylinderhead ground-point. I have so far measured the cables to engine watertemp-sensor, radiatortemp outlet-sensor and turbo coolant pump. All is fine, no shorts, cables have normal resistance measured from dme-contacts to sensors. Double-checked harness that nothing has been damaged around engine/ frame/ chassie Wrote in injector-values in DME1,2. Even programmed both DME. All ECU are green in the ISTA-tree. Checked all fuses in front and back and also the mainfuses at battery. Tested both batteries and they pass test. Replaced ISM relay-module, no result. Checked if there is possible to mismatch contacts in the DME1,2. Cant really put them wrong Did also prime the oilways in ISTA and it cranks well. Filled coolant. Have not tried to start because of the faultcodes. maybe someone has had similar problems with s63/n63 when replacing engine and can point in the right direction. Have a nice day codes ------------ 101401 Throttle Valve , adaptation: Marginal conditions not met 101410 throttle valve, adaptation: boundary conditions not met, battery voltage too low 101411 throttle valve 2, adaptation: boundary conditions not met, battery voltage too low 109001 coolant temperature sensor signal short circuit to B+ 10a001 Temperature sensor at radiator outlet short circuit to B+ 133011 Valvetronic, supply voltage: Malfunction, secondary reaction, voltage supply 133104 Valvetronic relay, control: line break 135608 Valvetronic system: no movement identified 136208 Valvetronic 2 No Movement Detected 1f4a10 relay, ignition and injection systems,activation: line disconnection 20a504 turbocharger coolant pump, actuation: Line disconnection |
04-01-2024, 05:02 PM | #2 |
Rep 1,029
Don't have the same experience, so can only randomly suggest advice.
I don't have access to the wiring diagram at the moment, but that looks all to be front of engine and would bet that all those would be either on the same harness or split between the same two(DME1,DME2). I'll take it you tried reset the codes and these keep coming back? BTW, if you forgot an earth lead, thing would look way worse. |
04-01-2024, 06:02 PM | #3 |
Rep 2
Hi thanks for reply.
Yes tried reset/delete codes. Also programmed/coded both dme Cant clear them. I guess its something simple. Maybe a connector got mixed up between dme 1 and 2. I will check further. I found this post on another forum. Maybe two connectors are mixed up. https://www.bimmerfest.com/threads/r...-elec.1460785/ |
04-01-2024, 06:28 PM | #4 |
Rep 1,029
Yeah that guy is having allot more issue.
Here is the full thread. https://f15.bimmerpost.com/forums/sh....php?t=2064578 |
04-12-2024, 03:15 AM | #5 |
Rep 1
Thanks for the thread link, you made my day. Thanks all for the suggestions. I will surely keep it in my mind. I also would like to help you all by sharing the https://uktopwriters.com/review-ukwritings/ website link with you in which you can read reviews for online essay writing services. If you don't know how to find the best essay writer then you can visit the given link where you will easily choose it by reading reviews.
