      02-08-2021, 09:58 AM   #1
Ghostx5m
Drives: BMW F85 X5M
Chassis Malfunction, Stop vehicle!
Hey everyone,
Question for you guys... I lowered my F85 X5M on the AC schnitzer springs along with the lowering links in the rear. After a month of driving on it, mostly when taking curves, I would get a "Chassis Malfunction" message.
I've also noticed in cold temperatures the error message comes up upon startup of the vehicle.
Any advice?
Thank you!
      02-08-2021, 10:31 AM   #2
Blewx5m
Drives: 2015 x5m
Originally Posted by Ghostx5m View Post
Hey everyone,
Any advice?
Thank you!
I'm going through this as we speak esp when it's cold out especially when I make left turns... I also notice I have a tiny leak in the driver side airbag... Im guessing that is the cause.. I will find out tomorrow when it's in the shop
      02-08-2021, 07:25 PM   #3
Klienfeld303
Klienfeld303's Avatar
Drives: 2018 x5 M
Hey everyone,
Any advice?
Thank you!
Happens to me often in cold weather when I'm in bear mountain twists and turns. I usually pull over somewhere safe and turn her off for a few and she resets. It happens also when I switch quickly to m1 mode while I'm driving.
Happens once also when she sat in place for two weeks while inward in Puerto Rico.
Hope this helps. I should change my air bags and check my compressor.
ACID.
      02-10-2021, 06:18 PM   #4
Blewx5m
Drives: 2015 x5m
Would like to report the chassis malfunction is gone.. It was due to a leak in my driver side airbag.. Hope this helps
*update* the message came back and it can be alot of different things that causes it but for me it was low power steering fluid
      01-16-2024, 12:44 PM   #5
///Motivated
Drives: 335i, i3
Bringing this back from the dead. I was also getting the "Chassis Malfunction: Stop Vehicle" warning message. It was generally showing up when it was cold outside. I checked my power steering fluid and it was quite low. Topped it off and it appears all good.
x5mMege12.50
