09-06-2021, 01:28 PM | #45 |
Rep 1,340
Have to disagree with you, that's terrible advice IMO. This is not in the same category as "lifetime" fluids like transmission fluid that BMW dissuades from changing - you have the manufacturer ZF recommending replacing fluids at 60k miles. This is the rear differential service procedure if you choose to do it, and they explicitly warn not to remove the side chamber drain plugs. I don't know why they warn you, but ignoring the warning without understanding the reason behind it sounds risky.
///MCollection183.50 |
09-06-2021, 01:54 PM | #46 | |
Rep 1,016
This isn't some procedure that is difficult, anyone with simple tools can do. The penalty for not changing it, is possibly an expensive repair bill in the future. I'm trying to prevent expensive repairs in my future. So, we can agree to disagree, but anyone that knows me, understands that I'm into preventative maintenance.
Abstracted38.50 |
09-06-2021, 07:30 PM | #47 |
Rep 1,349
Well, BMW tells too many thing that would cause issues in the future. They dont believe Rod Bearings are issue on S65s and S85s so keeping them stock will eventually cause issue since they do get worn. Fluid change is not a bad practice since we all know that moving parts always uses the life span of the oil. Does not matter which oil but they will eventually loose their protective function after being used that is 110% truth!
Plus every oil has a life span not based on usage but shelf time. SO if you do not use your car for 2 years doesn't mean that oil any good. Fresh oil always good for any equipment that runs with it. So changing the outer fluid is a good thing not a bad thing. The discussion here should be which fluid to use not "not to change the fluid" which we already done that. That will be a much better and smarter discussion since the required part needs sort of oil that supports its technology so it wont cause any sort of issue down the road!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 09-06-2021 at 08:14 PM.. |
09-08-2021, 11:07 AM | #48 |
Rep 1,016
That's a simply question to answer, 75W-140 for outer and 75W-90 for the inner.
09-08-2021, 01:19 PM | #49 |
Rep 1,349
i have mentioned "we already done that" but thanks for the reconfirmation
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
09-08-2021, 05:44 PM | #50 |
Rep 1,016
Your welcome
09-13-2021, 07:26 PM | #51 | |
Rep 188
I show up with my Castrol Syntrax SAF-XJ 75w140 for the rear left and right, and my indy shop says that I should be using 75W-85 instead. Specifically this: https://www.bimmerworld.com/Fluids/D...120445832.html I had to back out of the service until it's clear what it needs.
2016 X5M F85 Mineral White
2011 Mercedes G55 AMG (sold) 2005 C6 Corvette (sold) |
09-13-2021, 10:25 PM | #52 | ||
Rep 1,340
09-14-2021, 01:36 AM | #53 |
Rep 188
Thank you!
What does Newtis recommend for the front diff?
09-14-2021, 07:37 AM | #54 |
Rep 1,340
Here you go:
09-14-2021, 01:55 PM | #55 |
Rep 188
(Part number 83222413511)Yep, that's the viscosity my shop recommended as well: 75w-85. And I'm assuming that this one doesn't have the carbon modifier. Questions: 1. Where did we get 75w-140 as the go-to for the front and rear sides? 2. Are there any aftermarket brands of 75w-85 that we can use for either the front or rear sides? Both BMW's 75w-85 runs $100 per liter!
09-14-2021, 03:48 PM | #56 |
Rep 271
nishfish87 documented maintenance list. You can find diff fluids here
https://docs.google.com/spreadsheets...htmlview#gid=0 https://f15.bimmerpost.com/forums/sh....php?t=1851701 |
09-14-2021, 04:09 PM | #57 | |
Rep 188
But according to my indy/bmwx5er/Newtis 75w140 is incorrect.
2011 Mercedes G55 AMG (sold) 2005 C6 Corvette (sold) Last edited by Abstracted; 09-14-2021 at 05:10 PM.. |
09-19-2021, 10:41 PM | #58 |
Rep 1,019
So has anyone found a suitable alternative to the BMW SAF Carbon Mod 75w85 (83120445832). By this I mean non BMW logo version, whilst staying in the 75w85 with what ever the carbon mod is.
Which 75W90 is everyone running in the center? |
Abstracted38.50 |
09-20-2021, 07:40 AM | #59 |
Rep 1,019
Was going to Edit, but figure enough time has passed to warrent a new post.
Is anyone able to comment on the PN# difference for the Synthetic Fluid. Just looking at 83222365987 (BMW synthetic OSP), but allot of sites bimmerworld, fcp euro all reference it as 07512293972 (SAF-XO GL-5). However in the notes it says that 972 was upto 2011 and 987 is for newer. Based on RealOEM and BimmerCat, 83222365987 should be the current #. So how do you get the current 987 without the older pre 2011 oil? *Edit* found this thread. https://www.e90post.com/forums/showthread.php?t=1442048 talks about this exact thing, with something along the lines of one been for bikes the other for cars at a higher price. Is this true? Having 3 different chambers with 2x different types of oil is not confusing enough. Why can BMW keep their part numbers in order. 1 Week into F85 life, it does get better? Last edited by Chilled; 09-20-2021 at 07:56 AM.. |
09-20-2021, 02:57 PM | #60 | ||
Rep 188
At this point I'm confident enough to use it. But for the rear sides, and the front diff, I'm still waiting for the thread veteran's input: Yuille36 nishfish87 Sophisticated Redneck I'd really like to know how the conclusion was made that 75w140 is OK, especially without a carbon mod. Quote:
09-20-2021, 06:27 PM | #61 | |
Rep 1,019
I'm surprised we don't have more info from the E70/71 guys, with 50k+ post change. Is this diff/ style used anywhere else M5 or ML/GL63? |
09-20-2021, 06:38 PM | #62 |
Rep 1,340
My $0.02: The increase in $$ by going to 75w85 (vs 75w140) is probably $50-$75, for a 50k mile service item. I would just spend the additional $ if you aren't brave enough to take the plunge with 75w140.
09-20-2021, 07:30 PM | #63 |
Rep 1,019
I don't have an issue with the $$ for a 50k interval. Its more a curiosity, as is there a better alternative or a non BMW logo version.
Ie, the ZF Transmission. There is a $$ difference between the BMW Logo and the ZF Lifeguard 8. So the question is why pay the extra for the same oil, just different package. Plus the availability/where to purchase of ZF vs OE. Last edited by Chilled; 09-20-2021 at 07:54 PM.. |
09-21-2021, 02:54 AM | #64 |
Rep 1,019
So i am going to ask a dumb question, with the ZF oil. Is there specific model# for the one we need.
Just looking for some Lifeguard 8, and have come across like 2x different model numbers, 3x different photos. Is this a regional thing? Castrol, Liqui, Redline, all seem to be the same across regions. ie. https://www.ebay.com.au/itm/29432799...cAAOSwTrdhEzhS References it as "749800" https://www.ebay.com/itm/13251566117...cAAOSwJXxcWdZu as S671090312 and this one has the same # as above but has a different style label? https://www.ebay.com/itm/26527542018...kAAOSwv91hHoOk Does any of that matter or are they all the same? |
09-21-2021, 08:54 AM | #65 |
Rep 1,233
Yikes...
I am really blown away by all of the information in this thread and other threads. To the point where I'm questioning whether a transmission service makes sense. Concerned about my indy's ability to flush and fill and recalibrate everything correctly, the plastic pan in the service kit voiding my warranty (because someone mentioned and showed pictures of the stock one being metal?), etc.
09-21-2021, 02:03 PM | #66 |
184
Rep 364
Drives: M2C X5M M4
If you have the plastic pan in the kit it's the wrong kit and an expensive way of doing it. Just get the filter, gasket and ZF lifeguard 8 ( 7 litres to be safe) and keep your metal sump. Our metal sumps are the best thing BMW did for us!
Also only change the fluid and don't use a flushing machine, as far as I know ZF have not approved the use of a flushing machine so far. |
