      09-21-2021, 06:00 PM   #67
Blue By You
Blue By You's Avatar
631
Drives: 2017 LBB X5M F85
Thank you
Originally Posted by ///MCollection View Post
If you have the plastic pan in the kit it's the wrong kit and an expensive way of doing it. Just get the filter, gasket and ZF lifeguard 8 ( 7 litres to be safe) and keep your metal sump. Our metal sumps are the best thing BMW did for us!
Also only change the fluid and don't use a flushing machine, as far as I know ZF have not approved the use of a flushing machine so far.
I appreciate the insight on this!
      09-22-2021, 12:59 AM   #68
///MCollection
///MCollection's Avatar
United Kingdom
184
Drives: M2C X5M M4
2018 BMW M4  [0.00]
2019 BMW M2 Competi ...  [10.00]
2017 BMW X5M  [0.00]
It's no problem and it's kind of you to take the time to say. All of our information we share is a great resource so thank you for yours too
      09-22-2021, 02:15 AM   #69
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Hey, how big is they oil filter kit without the pan. Just trying to get one here, down under. And its a bit of a challenge, the stealers say its a order from Germany part and its like $420AUD(300USD). I tried ordering it from ecs and they want like $150US to ship it.
Is the package that the kit comes in massive? Does anyone have the dimensions on the kit? Is it worth trying a forward service, as in have ecs send it to shipitto and then have those guys fwd it to me.
      09-22-2021, 04:57 AM   #70
///MCollection
United Kingdom
184
Drives: M2C X5M M4
2018 BMW M4  [0.00]
2017 BMW X5M  [0.00]
On the f85 with metal sump just go to Bmw and get the filter element and gasket then go to a motor factor and get the lifeguard 8 fluid (7 litres) I would imagine the weight of the fluid is the issue and possibly some couriers won't transport oil limiting competitive delivery.
I'm sure in one of the beatbox posts I put the bmw numbers for parts.
      09-22-2021, 06:14 AM   #71
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
oh, no. Sorry just double checked, it's $100 USD just to ship the oil filter,gasket,ect. (24007855263)
The oil, i will get locally. But the repair kit, looks massively inflated for down under. Hence why i was wonder how big is the repair kit package, it's weight to try and get an estimate out of ShipItTo.
For the life guard 8, is there a specific model # we need? Because i found post to like 3 different ones, but all say LifeGuard 8. Different pics, numbers, ect.
ie.
https://www.ebay.com.au/itm/29432799...cAAOSwTrdhEzhS
References it as "749800"
https://www.ebay.com/itm/13251566117...cAAOSwJXxcWdZu
as S671090312
and this one has the same # as above but has a different style label?
https://www.ebay.com/itm/26527542018...kAAOSwv91hHoOk
Does any of that matter or are they all the same?
      09-22-2021, 08:07 AM   #72
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
I would recommend getting your filter kit from BMW Parts Now
Transmission Filter - BMW (24-00-7-855-263) costs $109 and includes Filter, Gasket, Oil Pan Bolts, and Fill and Drain Plug. I bought a similar kit, and it was a few dollars more. And I purchased the fluids from Pelican Parts.
https://www.bmwpartsnow.com/oem-part...bC12OC1nYXM%3D
https://www.pelicanparts.com/catalog...TRAUTO_pg1.htm
      09-22-2021, 08:20 AM   #73
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Im located in Australia (tiny Island, Middle of Known Where) and all of the bmw oems dont sent parts here.
So im left with like ecs/pelican/tuner(same company btw). And ecs wants 100usd to ship just the filter kit. Hence why im wondering how big is that kit (actual box), to try the shipment via fwd agency.
Onto the zf oil, i would like to get that locally, but as per those ebay links as examples, they show 3x different models or pics of what looks like the same lifeguard 8 oil. Hence that question, is there different versions of the lifeguard 8 oil.
      09-22-2021, 08:30 AM   #74
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
Now, I understand your dilemma..... The box is small, just slightly bigger than the filter.
The gasket is rubber, so it's folded up inside the box, along with the pan bolts and plugs.
I would say the box is no more than 34mm x 30mm
As far as the fluid, I purchased it from BMW, as I wanted to use what they recommend.
As their is to many choices available online.
SaNGRia986.00
      09-22-2021, 06:32 PM   #75
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Ok, will give thr shipitto a try for the filter kit. Otherwise if the shipping is going to cost $100USD+, might aswell pay the $300USD, for the one from the local stealers.
For the oil, I would rather by local but not BMW branded but ZF lifeguard 8. The bmw one is $100AUD/1L, from the local dealers
Are there different versions of the Lifeguard 8? As in, if you look at the ebay links, 2 of them have different model numbers (749800 vs S671090312) and they have different pictures.
So are there different versions of the ZF Lifeguard 8?
      09-22-2021, 07:48 PM   #76
Viper501
Viper501's Avatar
14
Drives: ‘20 MB GLE 350W4, ‘
FWIW I have to disagree based on my experience. The OEM gasket was shipped to me in a large box just a bit larger in length / width dimension than the pan. The gasket i received was metallic and not flexible. In fact it was sandwiched between two paper sheets to protect it during shipment. The filter and bolts are relatively small though.
      09-22-2021, 08:17 PM   #77
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
You are correct sir, I got this confused with my Mercedes filter kit as I did them each a week apart.
And after giving this some thought the gasket for the BMW was metal, and for my AMG it was rubber. And the box was larger to accommodate the filter.
So the box was as larger as the transmission oil pan.
So, I apologize for my mistake, if I confused anyone, as that wasn't my intention. 😔
      09-22-2021, 10:14 PM   #78
Viper501
Viper501's Avatar
14
I have difficulty with what I had for breakfast most times….
      09-23-2021, 12:32 AM   #79
///MCollection
United Kingdom
184
Drives: M2C X5M M4
2018 BMW M4  [0.00]
2017 BMW X5M  [0.00]
There is only one version of lifeguard 8, they changed the bottle design about 12 months ago though so this may be what your seeing.
Chilled363.50
      09-26-2021, 11:45 PM   #80
Abstracted
Abstracted's Avatar
39
Drives: 2016 X5M F85
Sorry to steer this back to the differential, but my 30 day return window is about to close on the Castrol Syntrax Limited Slip 75W-140
Should I keep it for the front and rear sides?
Or just keep it for the front, and get the OEM with carbon mod for the rear sides?
Or return it all?
2016 X5M F85 Mineral White
2011 Mercedes G55 AMG (sold)
2005 C6 Corvette (sold)
      09-27-2021, 05:16 AM   #81
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Yeah sorry, i diverted the chat abit.
Me personally, for my change, I am going all OEM on the Diffs and TC.
Without knowing what the carbon mod thing is, the $$ is not worth it to find out. Maybe it's something, maybe its not, but there is a reason why people say you must(really advised) to use the OEM for the TC.
      09-27-2021, 05:29 AM   #82
640ijims
Drives: 2018 X5M , 14%E2%80%99640i ver
2018 X5///M  [7.50]
2018 BMW  [0.00]
OEM recommended fluids are recommended for a reason
      09-27-2021, 01:12 PM   #83
///MCollection
United Kingdom
184
Drives: M2C X5M M4
2018 BMW M4  [0.00]
2017 BMW X5M  [0.00]
With a vehicle value like this and the diff and transfer box the price they are OEM is where my money would go.
      10-10-2021, 09:37 PM   #84
ferrarif1
Drives: F85, G05, E46M3
I had added some feedback to a thread a few years back about SAF Carbon Mod sources and since I am up to oil change 10, it's time to flush again.
SAF Carbon Mod is not a unique BMW fluid and can be sourced from a number of places in bottles with various manufacturer names. In BMW bottles, this is $120/l. Buy the GM branded bottle (GM part 92269208) and it's $32/l
SAF Carbon Mod sources and OE part numbers:
Mercedes: A0019895903
Porsche: 000.043.300.37 $46/l
GM/Holden: 92269208 $32/l
BMW: 83120445832 $120/l
Chrysler: 68083381AA $49/l
I pulled this data from ZF here: https://www.zf.dk/wp-content/uploads/te-ml_18.pdf
SaNGRia986.00
Chilled363.50
      10-10-2021, 10:17 PM   #85
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
I was able to find the GM one when i did my research Thank you for the input!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
ferrarif1320.00
      10-10-2021, 11:45 PM   #86
Abstracted
Abstracted's Avatar
39
If that's the case then Red Line 75W90 GL-5 GEAR OIL is compatible, because they list it as being compatible with:
Castrol SAF Carbon Mod
GM 92184900
Porsche 000 043 300 37
$18 @ https://www.fcpeuro.com/products/75w...uart-oil-57904
      10-11-2021, 07:21 AM   #87
ferrarif1
Originally Posted by Abstracted View Post
If that's the case, then Red Line 75W90 GL-5 GEAR OIL is compatible, because they list it as being compatible with:
GM 92184900
The part numbers I listed are genuine Castrol SAF Carbon Mod, not a compatible oil. There is nothing wrong with Red Line, but my experience is that if the OE manufacturer (ZF) specifies gear oil with a specific friction modifier, it's best to use the recommended additive pack. According to Red Line, their gear oil may be compatible, but it is not genuine 'Castrol SAF Carbon Mod' as specified by ZF and sold in various branded bottles from BMW, Porsche, GM, etc.
      10-11-2021, 02:54 PM   #88
Abstracted
Abstracted's Avatar
39
That's an excellent point. I'll be sticking with the Castrol.
