      10-25-2021, 06:49 AM   #155
Blue By You
Blue By You's Avatar
631
Drives: 2017 LBB X5M F85
Transmission Service
Originally Posted by Chilled View Post
did you end up triggering "QMVH transmission oil change", because to me it looks like it only applies if you do the clutch pack sides.
Do any codes show up if I get my actual transmission serviced?
      10-25-2021, 08:21 AM   #156
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
I will do soon 🙌🏼
      10-25-2021, 07:59 PM   #157
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Depends on how badly you mess up. Impressively yes, you will get allot of error codes.
In short, no there should be no codes.
However there is a Transmission Adaptation reset bit, and then a driving process to combeite the adaptation. If you dont, you may be in for some hash shifts. Search around, there is a few good threads on this.
      10-26-2021, 04:26 PM   #158
Blue By You
631
Thank you
My indy shop is doing it. Just making sure the dealer won't see that the tranny has been serviced since it is a "sealed unit..."
      10-26-2021, 06:12 PM   #159
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Ahh, I'm not a 100 on this. I do remember reading that there was some sort of a counter that keeps track of how many times the Adaptation has been reset.
Now I don't remember if that was relating to the Transfer Case/ Diffs or the Transmission.
      10-31-2021, 02:36 PM   #160
SaNGRia
SaNGRia's Avatar
986
Update :
Had been 200 miles with 1.2L fluid on my rear diff with 0 issue and 0 leak while ALL hard drive condition. Cheers (35k mileage)
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      11-01-2021, 05:43 AM   #161
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
So I did my rear centre section and it also drained approx. 1.2L Colour wise, not as bad as the Transfer Case. I'm at 50Km(30ish mile).
Centre Section.
Also did the Transfer Case, and as everyone says the colour is awful.
I did some custom tooling . (cut most of a socket off, allen key and was able to fit a ratchet and a torque wrench in I did cut a bit too much off the socket tho.).
Also decided to stick borescope into the TC, and yep it really needs a drain plug. There looks like some baffle/sections that run the length of the TC that are internal. I was only able to get 600ML before giving up.
SaNGRia986.00
      11-01-2021, 04:55 PM   #162
SaNGRia
SaNGRia's Avatar
986
Centre Section.
Attachment 2732831
Attachment 2732832
Attachment 2732833
Attachment 2732835
Attachment 2732836
What did u use the get the TC fluid out? I have an electric suction unit which i will use for the TC. And is the fluid pump that goes on the top of the bottle is enough for the refill? And as i said before BMW procedure wrong about the fluid amount! Thank you for sharing!
, F85 ACC Retrofit
      11-01-2021, 06:47 PM   #163
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
I used a 1.5L Fluid Extractor to pull and fill. I was trying to use something small so that there isn't much waist in the hose/housing. I did end up adding a small plastics tube with a 180° bent steel tube to the end of the one that came with the 1.5L. This was to reach the bottom of the transfer case. Something similar to the hook on this one.
Fluid wise, I used the BMW OEM DFT1 1L "83222409710" and that was plenty. When I opened the fill/drain plug, it started to drip out slowly. So when i did the fill i topped up to the point when it started to just slightly drip and sealed it up.
1.5L Extractor. Not this one, but looks exactly like this.
https://www.amazon.com/Mityvac-MVA68.../dp/B0741G9P6R
Just FYI, with the nosel the way it is on this, you will NOT be able to get to the bottom of the TC pan. It wont turn 180°. You will need to add something that can be turned and face the bottom of the TC.
      11-01-2021, 09:40 PM   #164
SaNGRia
SaNGRia's Avatar
986
What do you think? I have this to extract the oil which i use for my jetski as well
And fill the TC back from the bottle
, F85 ACC Retrofit
      11-01-2021, 10:11 PM   #165
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Both should be fine. The pvc pipe should have plenty of flex, so it should be able bend downwards towards the bottom of the TC.
It took several attempts and repositioning to get the it that low. My 180° steal bend kept hitting those baffles, bottoming out on the top bit in pic one and then the flat bit pic2.
But by this point I already had just under 600ml out.
Next time ima try making a 90° bend pipe, and see if that can reach further in.
      11-01-2021, 11:48 PM   #166
SaNGRia
SaNGRia's Avatar
986
You are good
Special Pump : )
Torque :
, F85 ACC Retrofit
      11-02-2021, 12:03 AM   #167
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
I saw that hand pump, I feel sorry for anyone having to pump that out manually.
My next problem for the moment is trying to find some o-rings for the drain plugs. I decided to put in the Tuner Magnetic Plugs for the TC and drain of the diff. The replacement o-rings for them are like $3 each, that seems abit much for a 22mm oring.
The challenge is finding these are a decent price that are rated for 150C°
Plugs
https://www.ecstuning.com/b-turner-m...027030tms01~a/
Replacement o-ring.
https://www.ecstuning.com/b-turner-m.../2418t126~tms/
      11-02-2021, 12:05 AM   #168
SaNGRia
SaNGRia's Avatar
986
Plugs
Replacement o-ring.
I am gonna use the one time use plugs. They re identical to diff plugs right?
, F85 ACC Retrofit
      11-02-2021, 12:32 AM   #169
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Yep, front diff, rear diffs(all sections) and TC all share the same plugs.
I just thought it would be a good idea to add the magnetics ones in. I'm only using them on the drain ports for the diffs and fill for the TC. I didn't want to go with the ECS ones as they are aluminum and apparently allot of people are snapping them.
      11-02-2021, 02:53 PM   #170
SaNGRia
SaNGRia's Avatar
986
It is a good idea but never had any problem without them either
, F85 ACC Retrofit
      11-03-2021, 10:57 AM   #171
Franktea1$
Franktea1$'s Avatar
Drives: BMW e39 540 sport & BMW X5M
Originally Posted by Yuille36 View Post
I just did this a few months, your rear differential has three fill plugs and three drain plugs. The outside chambers use 75w140 and center section uses 75w90.
I would recommend purchasing ECS Tuning, magnetic drain plugs, you only need three. These same drain plugs work on the transfer case and front diff.
If your going to change your rear differential fluid, I recommend that you also change the front diff and your transfer case. I also wrote up a post of this already with photos.
Hi was wondering how the old fluid looked? When I have done these in the past the oil many times seemed like new.
Thanks,
Frank
      11-03-2021, 12:25 PM   #172
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
Thanks,
Frank
The oil that was removed looked good, as it's only function is to lubricate and cool the differential. But the oil does break down after of a lot years and miles.
      11-03-2021, 06:20 PM   #173
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Thanks,
Frank
As per above, i did mine at 50KM, and the TC looked pitch black. The photo with the LED light, is the new vs old for the TC. The 1.2L was the rear diff.
      12-14-2021, 09:51 AM   #174
MBoss_F86
MBoss_F86's Avatar
Drives: 2016 BMW X6M
I used Redline for my engine oil and I am very happy with it. So I decided to go with them for Diffs and TC as well for my X6M and C300. Much cheaper on OEM oils. My car has 47k miles now and I will do service at 50k
For F86/F85
Transfer case - https://www.redlineoil.com/mt-lv-70w75w
Front Diff - https://www.redlineoil.com/75w85-gl-5-gear-oil
Rear Diff(all 3 chambers) - https://www.redlineoil.com/75w90-gl-5-gear-oil - Technical rep said you can use this for outer and middle chambers since it is compatible with both SAF Carbon mod and SAF-XO.
      10-20-2022, 07:20 PM   #175
SaNGRia
SaNGRia's Avatar
986
5k miles later, my mid section bone dry and 0 issue. So putting 1.2L was correct and no harm! I havent replaced the outer or front diff yet and i am at 40k now. I just changed the TC fluid and it was off -13 degree in 2 years of drive with stock wheels. But that numbers might come from me not tightening the metal guard when i did my water pump replacement and caused brandnew front tires to be destroyed within 1k. Since then i havent done any calibration on the vehicle but considering that tray also tightens up the front subframe , that can cause misalignment on TC and i was getting vibration during that time.
Luckily problem solved after torquing them correctly. And after replacing the TC fluid with calibration, car feels great. Will change the front diff soon with the same oil i used for the rear mid
I was able to drain 600ml exact oil from the TC with electric pump.
, F85 ACC Retrofit
      01-11-2024, 10:00 PM   #176
sly1types
Drives: F80M3 and E46M3
When you guys did the rear diff, did you reset the adaptions? Can you use something other than ista?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104
E46 M3
F85 X5M
https://www.instagram.com/fastmacm3/
