09-28-2023, 01:20 PM | #89 |
142
Rep 352
I'm interested as well. Thanks!
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
09-28-2023, 11:02 PM | #90 | |
125
Rep 381
Drives: '23 AMG GLE53, '10 X6M
How you liking that turbo blanket |
10-24-2023, 06:06 PM | #91 | |
Rep 760
Drives: 2019 BMW X6M
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
mstgeer29.00 |
11-02-2023, 07:55 PM | #92 |
Rep 97
[QUOTE=Sophisticated Redneck;30525966]mstgeer, Autobacs, and MBoss_F86 - Will reach in a few weeks once I have solid testing of the new internal flap valve catch can. The BMW flap valve represents an interesting challenge as it has a very low opening and closing pressure and why many of the aftermarket one-way valves don't work so well or give drive train errors.
I have a particular valve design in mind that I believe will be superior to the original BMW. Real world testing in all scenarios (from stop and go traffic, to full blown back to back 1/4 mile runs and everything in between will be completed within the next 2-3 weeks. Sophisticated Redneck Any news to report? |
11-14-2023, 07:32 PM | #93 |
Rep 496
I just had to kind of do an emergency PCV delete on the passenger side on my 50i. I was pulling the valve out of the intake tube to measure what diameter hose I needed and the plastic elbow just broke apart in my hands 😳
To make it to the parts store I ghetto rigged it like the first two pics. Then got to Advance Auto and bought Dorman 90-062CD diff plug, 6’ of 3/4” ID heater hose, and an oil vent filter. Now the hose runs from the PCV valve to the bottom of the car with the filter to keep anything from going back up the hose and it’s basically what I was going to do anyways. No catch cans for this guy! 😂. |
11-15-2023, 08:09 PM | #94 | |
125
Rep 381
Take a look at Moroso 25900 https://www.moroso.com/crankcase-eva...n-system25900/ Obv don't need the oil separator that comes with the kit. On the mfg site there's a video that I think they say you can get 5 to 6 inches of vacuum which works out to approx 2-3 psi. Too much or not enough? Last edited by TTV8M; 11-15-2023 at 09:44 PM.. |
11-16-2023, 05:37 PM | #95 | |
Rep 1,036
For the valve, have you seen Levels design. Its not in the can tho. https://1evel.ru/product/level-perfo...mplekt-karbon/ Curious how it works. |
11-18-2023, 10:21 PM | #96 |
Rep 496
Sooo finished my PCV delete/reroute. Used a total of 12 feet of 3/4 ID heater hose, 2 of the Dorman 90-062CD diff plugs, two oil breather filters, and a couple zip ties. Total cost was about $65 after military discount at Advance Auto. Excited to not have oil vapors going into my intake now!
Trion_f8523.00 |
11-28-2023, 11:58 AM | #97 | |
Rep 496
11-29-2023, 02:04 PM | #98 |
Rep 41
12-09-2023, 07:21 PM | #99 |
Rep 1,036
So I wanted to be like all the cool kids, with their catch cans. After my pcv hose and intake boots failed I decided something needs to be done.
I was hoping to be done by down but life keeps find a way to add scope creep and delays. So decided to try the agile deployment thing and just send it. The main purpose of this setup was to test the PCV valve cover adapter and see if
So on bank 5-8 I am running my adapter, to a modified catch can. On bank 1-4 I am running the stock PCV hose, to the same style modified catch can. The end game is to be running AN12 where possible as the internal diameter of the hose and fittings the same as the factory hose. I know its overkill, and AN10 would be more than enough. The AN12 Valve cover adapter and the flapper valve connector (this is the temp style, better to come). Bolts up perfect, will see how it holds. The catch can, i JB welded in a aluminium pipe into the dirty side, so it runs past the baffle. Also added some stainless steel scourers. to both sides of the baffle. The clean (air intake) side pickup is via the bronze 40 micron filter. I wasn't sure where to mount the cans and did not want to mess with the fender support mounting bracket. So on one side i mounted to the -negative terminal and the other side I zip tied it to said fender mounting bracket. I did check for clearance with the bonnet. |
12-09-2023, 07:33 PM | #100 |
Rep 1,036
For those that did mess with the bolt for the fender mount.
12-10-2023, 01:10 PM | #101 | |
Rep 463
Chilled366.00 |
12-10-2023, 05:47 PM | #102 |
Rep 1,036
Cheers, Yeah I did see yours. Was going to do that, but then had a mild oh F** moment not knowing what would happen when I backed that bolt out.
Cheers. |
12-10-2023, 07:43 PM | #103 | |
Just me
23
Rep 80
That is a nice fitting valve cover adapter would definitely want one if i can get the AN10. Lets see how it holds up on your setup. Did it need any modifications before fitment? Also love how you isolated the clean air pipe away from the baffle filter. The stock flapper valves are best in ensuring constant flow are you thinking of changing them later as mentioned? |
12-11-2023, 06:01 AM | #105 | |
Rep 1,036
Designed them and had them made.
I am working on a custom catch can. The initial idea was just a can that would accept AN12 ORB fittings. Then I had more scope creep. I decided to get rid of the flapper valve. Got a design model up, but then more scope creep. The current issue I'm trying to guess/work out is the negative pressure bypass in the flapper valve. The OE flapper does not completely seal. It has a tiny 2mm-ish pinhole for air to rush back into engine. That is the issue, integrate both the flapper valve and pressure valve if the vacuum/suction from the engine was greater than X psi. It would open and work as that pinhole bypass. *EDIT* Oh yeah, no mods needed for fitment. It reuses the factory bolts and pattern. Last edited by Chilled; 12-11-2023 at 06:55 AM.. |
12-11-2023, 06:08 AM | #106 |
Rep 1,036
BTW, does anyone have a reliable source for AN fitting from AliExpress.
My local supplier didn't have any black AN12 hose ends, given the $$. I figured it worth trying AliExpress for both the hose end and a ORB to AN. Two different shops, and both sent absolute junk. The ORB turned out to be a double ended AN <-> AN male and I could not get the hose to go into the socket. I even tried placing the hose into the freeze for a couple of hours. I could live with the fact that the fact that the external dimensions are not to AN spec and a wrench would slip. But the hose has to go in. |
12-11-2023, 06:55 PM | #107 | |
Just me
23
Rep 80
AN fittings https://a.aliexpress.com/_mrvyG6k NPT thread to AN adapter (3/8 NPT male slides exactly into stock flapper valve 0.71in ) https://a.aliexpress.com/_mLYAHMk AN Hose https://a.aliexpress.com/_mK1M62c |
12-11-2023, 07:42 PM | #108 | |
Just me
23
Rep 80
In my case i tend to concentrate on how easy the valve would open and close and how fast the blow by gasses are routed out since im venting to air. |
12-12-2023, 08:25 PM | #109 |
Rep 1,036
It wouldn't be a high psi amount, maybe like 5-ish. Just enough so you are not sucking in the seals. Would that mean any significant performance boost, nope.
Its kinda on principle thing. If I'm going to all this effort, I kinda wanna see if I can improve on the current design. Or learn why the current design is the better approach. For me it's not a commercial thing, its more of an excuse to play with 3D Modeling so I'm not looking at $$ viability. But because I'm new to this, even basic sub component sourcing is a PITA. |
12-21-2023, 08:24 AM | #110 |
Rep 1,036
No real update on the adapter and cans. Only manged to do 200-ish KM no far no leaks and nothing in either can. Only about 20 of that was on a private mountain pass. The rest was burbs and freeway.
I did have a moment to mess the other scope creep and thoughts? This isn't final, would like to remove the silicone reducer. Haven't taken for drive yet. Too tight, not enough flex from intake to turbos? There is unfortunate some rubbing on the alternator, +cable and the back of the oil filler. The oil filler side was a massive PITA. Yes the top cover thing does go back on. |
