12-17-2020, 05:44 PM | #991 |
Rep 5,228
12-19-2020, 12:37 PM | #993 |
Rep 165
12-22-2020, 05:36 PM | #994 |
Rep 2,514
01-05-2021, 08:16 PM | #996 |
Rep 15
Hello Guys:
Newbie here, I had a license plate light go off on my 2015 X5 replaced the bad LED lamp but the car still shows license plate lamp malfunction the car had cut off power to the lamps now. I scanned it with OBD II scanner and found a fault code dtc 80486 tried using ISTA+ to scan and found the same error, I don't know, how I can can clean or reset reset the short-circuit lock-out in the Body Domain Controller (BDC). Thanks. |
01-06-2021, 08:06 AM | #998 |
Rep 15
01-06-2021, 08:34 PM | #999 | |
231
Rep 369
Current
01-07-2021, 01:57 PM | #1000 |
Rep 15
I have uploaded the ISTA troubleshooting instructions,
https://ibb.co/NycCWpy i'm stuck on step 3 as I cannot find a service function to reset the short circuit in BDC Any advice. Thanks. |
01-07-2021, 10:53 PM | #1001 |
Rep 15
I checked all fuses, all good
can anyone share the Body Domain Controlled wiring diagram, trying to trace the feed wire from the BDC to the back. need to know what Pin feeds the license plate lamps,. |
01-08-2021, 01:25 AM | #1002 |
Rep 1
Hello there,
My X5 25dX N47S1 vehicle has a 246B00 fault record. Usually when it is cold, the accelerator suddenly stops and there is no pedal response so that the idle does not rise. Does anyone have an idea? thanks in advance. |
01-13-2021, 01:41 PM | #1003 | |
Rep 2,649
02-28-2021, 10:41 AM | #1004 |
Rep 1
Car is super reliable .. and doing well. Just passed 62K.. any recommendations of things to look for. So far all it has needed was oil changes, air filters, brakes and tires.
03-02-2021, 08:54 PM | #1005 |
Rep 1
Hi Everyone
Newbie here. I have a 2015 X5 about 84k miles. No issues but I was wondering if anyone could share some thoughts on potential major issues with the car. I love the car and I am not really keen on selling it but toying with the idea of selling it off. Its 6 years old now. |
03-03-2021, 02:58 AM | #1006 |
Rep 117
6WB option - Digital Instrument cluster stopped working on me. First time i was in a cold climate around 0, -1 degrees Celsius cold started the car to move it closer (50 m) and shut it off again. Started it after 15-20 mins head up and instrument cluster didnt work I could only see the small section in the right section showing which gear im in. Nothing else worked.
Shut if off, waited 15 mins restarted and it started working again. It has done it 1 more time with higher temps and not cold started . Was around 5-6 degrees celsius. Same solution as above. Dealer said no codes were stored on that but quoted me initially around 2500 usd for a whole instrument cluster unit? not sure whats included in that tbh but reduced it to about 600-700 usd with some warranty claim. Anyone else experienced this and if yes what was your solution. Although ive mainly enjoyed the 6wb option if its prone to such failure its a let down. First time it happened was when i was 300miles away from home and the prospect of driving all that without knowing my speed was frustrating. |
03-03-2021, 08:54 AM | #1008 | |
147
Rep 334
Get / buy a battery tender/charger and turn your ignition into the ACC position and hook up to the terminals under the hood and let it charge up for 12 hours. Then I'd go from there. I had my vehicle in for some other repairs and I brought my HUD going dark and not working when turning the car on and off quickly. Dealership said theyd have to replace the whole 6WB to fix it. I've been keeping my 6 year old batteries charged up by hooking up the tender once a month and have not had any issues since. |
03-03-2021, 08:55 AM | #1009 | |
147
Rep 334
03-03-2021, 10:40 AM | #1010 | ||||
Rep 117
Battery hasnt been replaced as far as i know and its an 2015 car so still possible. No low battery warning however. |
03-16-2021, 01:30 PM | #1011 |
Rep 46
Picked up a 2016 X5 Sdrive MSport couple weeks ago. First issue: Sunroof leaking on passenger side after all the rain today.
I plan on running fishing line down the drain holes like I did with the old E70. Last edited by Jarhed1964; 03-16-2021 at 01:38 PM.. |
03-16-2021, 01:40 PM | #1012 |
Rep 46
Of course, the first thing I did to her (her new name is Gretchen) was to shed the chrome grill and replace with a black split-slat one.
