      01-31-2017, 04:01 PM   #45
stewy604
stewy604's Avatar
290
Originally Posted by lowlevelhell View Post
Kms??? Oh right...kilometers...that's what countries that didn't go the moon call miles.
Easy there lowlevel...don't make me drop some Trump jokes. That said, easy jokes come our way too for Trudeau...sigh.
2007 Suzuki GSX-R 750
deutsch1003946.50
neight0.00
      01-31-2017, 05:20 PM   #46
lowlevelhell
Herr Oberst
lowlevelhell's Avatar
244
Drives: '15 F15, '16 G12
Don't like Trudeau? We'll trade you...
deutsch1003946.50
      02-01-2017, 09:55 AM   #47
stewy604
stewy604's Avatar
290
Will you take Bieber too?
      02-01-2017, 06:59 PM   #48
lowlevelhell
Herr Oberst
244
Have any of you with the clogged cooler attempted to fix it yourself?
'15 X5 35d
'16 740i
      02-02-2017, 07:41 AM   #49
Amanda4461
Drives: 2015 X-5 Xdrive35d
EGR
2015 35-d w/40,000 miles on ExxonMobil diesel, required maintenance and every 5,000 miles oil changes. Very dirty oil filter each change, but no problems with EGR. I do drive 175 miles each day at 75mph for my work commute
Amanda
      02-02-2017, 07:50 AM   #50
lowlevelhell
Herr Oberst
244
Amanda
You don't need a new EGR...you need a new house!
'15 X5 35d
'16 740i
deutsch1003946.50
      04-05-2017, 06:57 PM   #51
bim_power
bim_power's Avatar
Drives: BMW
F15 n57n engine has 2 exhaust coolers, 1 on the intake and another right after the manifold. For the ones that had the exhaust cooler replaced, which one did BMW replace?
Did BMW do bunch of tests, clean the sot before determining the cooler needs replacing? This is my 3rd time in the shop with CEL in 2 weeks. 1st time, egr sensor replaced, 2nd time solenoid was 'cleaned'... really... now waiting on what BMW will do next... Apparently the shop is following procedures.
Thanks for your help!
MrTookies457.50
      04-05-2017, 11:30 PM   #52
Enrico 35d
Drives: 2014 x5 35d
For DPF cleaning or regeneration : run at 2-3000 rpm for 20-25 mins. These cars have passive regeneration or active if the ECU deems necessary due to higher exhaust back pressure. A proper freeway run in a lower gear usually works well done once a week. This will also make the EGR last longer.
While regenerating you will notice a drop in fuel mileage and burnt smells after stopping. Hope this helps.
deutsch1003946.50
      04-06-2017, 05:08 PM   #53
stewy604
stewy604's Avatar
290
101K on the odometer of my 35d. Since the original EGR issue I noted earlier, no problems to date. I drive mine "passionately" we'll say, with a good mix of city and highway. Short trips with little time operating at full temp could be contributing to some of your issues.
      04-06-2017, 09:08 PM   #54
bim_power
bim_power's Avatar
Drives: BMW
I agree. The stop/go feature probably does not help either on a diesel.
Update...X5 is still in the shop from the 3rd CEL in 2 weeks. Dealer is removing the exhaust cooler for inspection and has not made a determination to replace it.
      04-20-2017, 01:31 AM   #55
bim_power
bim_power's Avatar
Drives: BMW
F15 is back home after almost a month at BMW service.
Both coolers were replaced, EGR cleaned with all new vacuum lines. The bill was $3k to BMW NA.
neight0.00
      04-20-2017, 02:41 PM   #56
CMHX5
Drives: 2014 X5 Diesel
EGR Nightmare
I have a F15 X5D bought with CPO warranty. Prior to the CPO, the selling dealer had replaced the EGR Cooler and other parts. Since then I have had 3 CELs related to some EGR issue or another and the vehicle has been in the shop over 15 days. Once some sensor was replaced and second time the EGR cooler was replaced. Now, the CEL is on again with the vehicle in the shop with another EGR issue. May need one more EGR cooler. What a nightmare in less than a year of ownership! Do you all have any suggested course of action to take with the SA? I have to say that the dealership I am working with is courteous and helpful. Also, will the EGR components be covered by the CPO warranty? I have the original warranty for about another year yet, and 2 years of CPO after that.
      04-20-2017, 02:52 PM   #57
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
common issue with the M57 motors. My E70 still hasn't clogged yet. It comes down to driving longer distances to allow a proper DFP regen once a week. IIRC on the M57, BMW SIB has a prescribed minimum speed and time to drive to get the regen. I want to say you need to do at least 45 mph for 20 miles.
      10-22-2017, 11:20 PM   #58
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
Originally Posted by 42pilot View Post
Originally Posted by MattBianco View Post
I am trying to figure out why some go 100k miles and other 10k before getting this clogged. My guess as to what the factors may be:
• Fuel quality
• Driving pattern (short trips, long trips)
• Driving style
• Use of aftermarket piggy back chips
What else would cause this component to clog early?
BTW, lots of YouTubes on DYI cleaning of this component (on different BMW engines, but same concept).
You nailed it. The EGR to keep emissions in check gets clogged due to soot from the exhaust then sudden cooling from the engine coolant system - the fuel is not being burned completely just like gasoline cars running rich and leaving carbon in the exhaust. I removed the EGR from my pickup but that's not an option here. The only options are, high quality fuel, correct air fuel mixture, reduce time idling and turn down the fueling on the chip.
The EGR is not programmed to work full time however, and normally kicks in when the engine is at operating temperature. This is to reduce fouling. I haven't found an additive that improves the condition yet and you'll notice none of the additives mention EGR benefits.
Once you get the CEL stating EGR failure, it has to be replaced since nothing can un-clog it. People who will have better luck are those who drive longer distances so exhaust temps will stay high and soot will burn more completely. City driving, stop and go, will accelerate the problem. Gas engines see something similar with carbon fouling in the combustion chamber and exhaust valves, so no engine is immune to modern emissions controls.
Okay... so I just been trough the whole replacement deal with the EGR... EGR Valve and cooler replaced along with injector and another pressure valve behind the EGR Cooler... my check engine light is still coming back after not even 100miles... dealer says they need to replace the intake next... Could you not just either unplug the EGR Valve and code it in a way that it won't trigger into the memory or insert a piece of metal after the valve that will "plug" the line and won't let the gases recirculate, go back into the intake as soot it dirty? Or is there another flow sensor afterwards? What is the reason for you saying that it is not an option to remove it? If the valve no longer lets burned fuel gas recirculate... what does that do to the performance, fuel mileage... and will this potentially clog up the cat converter sooner?
I drive a lot of miles at 80k now after 22months... I am not planing on spending 10k every 2 years on repairs... especially where in Texas Diesel are Emission testing exempt....
I'm really trying to find a solution even if that's not optimal and means extra work...
      10-24-2017, 01:54 PM   #59
MrTookies
MrTookies's Avatar
Originally Posted by PlayTookies View Post
Okay... so I just been trough the whole replacement deal with the EGR... EGR Valve and cooler replaced along with injector and another pressure valve behind the EGR Cooler... my check engine light is still coming back after not even 100miles... dealer says they need to replace the intake next... Could you not just either unplug the EGR Valve and code it in a way that it won't trigger the memory or insert a piece of metal after the valve that will "plug" the line and won't let the gases recirculate, go back into the intake as soot it dirty? Or is there another flow sensor afterward? What is the reason for you saying that it is not an option to remove it? If the valve no longer lets burned fuel gas recirculate... what does that do to the performance, fuel mileage... and will this potentially clog up the cat converter sooner?
I drive a lot of miles at 80k now after 22months... I am not planning on spending 10k every 2 years on repairs... especially where in Texas Diesel are Emission testing exempt....
DPF SCR EGR delete possible?
      11-29-2017, 09:42 PM   #60
Diper
Diper's Avatar
Netherlands
47
Drives: BMW X5 F15 3.0d
Update 101.000km and the EGR cooler has a small leak. I've got extended warranty, so let's see how things work out
      12-31-2017, 12:51 PM   #61
BillK
Drives: 95 M3, 11 M3, 15 X5d, 20 X2
Our check engine light came on today. It’s a model year 2015 X5 d with 51,800 miles. My app tells me it’s the egr cooling that’s bad. Normally my wife does a lot of highway driving but not so much in the last few months. Luckily we got the extended warranty so I’m ok. I Carly for bmw let’s you run the dpf regen by the push of a button. It might be a good idea to do it more often, but I’ll wait and hear what the dealer says causes this problem
      12-31-2017, 04:31 PM   #62
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
I’m at 39600 miles and a CEL that the dealer says is a NOX sensor. We’ll see what else happens.
      03-23-2018, 11:51 PM   #63
MrTookies
MrTookies's Avatar
Bump...anybody?
kj71109188.50
      03-26-2018, 10:46 AM   #64
MrTookies
MrTookies's Avatar
Bump...anybody?
Saw this today... any thoughts?
      04-05-2020, 02:03 AM   #65
XxBBVTMxX
XxBBVTMxX's Avatar
My 2014 X5 35d has almost 77k and I have not experienced any of these problems.
I do practice not using the auto Start/Stop and I tend to leave the engine running and lock doors if I get out to make a quick purchases.
This has been working for me
      02-03-2021, 06:33 PM   #66
Safe Ben
Drives: x5
Had the same failure at 72k. Replacing sensor costs $480
