      09-17-2021, 04:49 PM   #1
stlb5
stlb5's Avatar
220
Drives: '19 M2C MT, '15 X5 Msport
Front Fender Removal?
I have a leaky washer fluid reservoir and need to remove the passenger front fender to get to it. I searched and can't find a DIY for an F15, only older models. Likely the same, but wanted to check on here before I started poking and prodding.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers)
2014 M235i MT, BSM, MPE, Dinan Springs (Sold)
      09-17-2021, 05:39 PM   #2
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Does this help?
Last edited by M_Bimmer; 09-17-2021 at 05:45 PM.. Reason: Load better resolution pictures
stlb5220.00
      09-17-2021, 05:42 PM   #3
stlb5
stlb5's Avatar
220
Originally Posted by M_Bimmer View Post
Does this help?
Very much so! Are those still available to the public anywhere or are they all subscription based?
      09-17-2021, 05:43 PM   #4
stlb5
stlb5's Avatar
220
Does this help?
Actually, is there a higher res version? It's a bit fuzzy to read.
      09-17-2021, 05:46 PM   #5
M_Bimmer
M_Bimmer's Avatar
583
Just redid the BMP's.....I'll provide the washer reservoir next...
      09-17-2021, 05:48 PM   #6
stlb5
stlb5's Avatar
220
Perfect! Thank you!
      09-17-2021, 05:52 PM   #7
M_Bimmer
M_Bimmer's Avatar
583
Here is the washer fluid reservoir.....
stlb5220.00
      11-13-2021, 11:26 AM   #8
stlb5
stlb5's Avatar
220
@M_Bimmer, I'm finally getting around to this project. Could the post the steps for the preliminary tasks too?
      11-13-2021, 04:37 PM   #9
M_Bimmer
M_Bimmer's Avatar
583
Let me know if you any more info.....cheers
      11-13-2021, 05:50 PM   #10
stlb5
stlb5's Avatar
220
Thank you again!
      11-14-2021, 01:14 PM   #11
c00lbeans
14
Drives: X5 40e
I had todo this couple weeks ago. It's annoying af. My sprayer motor was leaking. Had to do it twice to find the problem then Wait for new part. Just have to pop out rear 2/3 of the render trim. Then the wheel well covers. Then loosen side skirt. Then unscrew top and rear fender screws. The hardest part is the tabs on the fender trim. Everything else is pretty obvious and easy to find opening it up takes 30 minutes and putting it back takes about 15. Once you know how to do it.
      11-04-2023, 06:31 PM   #12
Matt2408
Drives: BMW X5 F15
Does this help?
Whats the software you used to show this? Was is emanuals? Currently in the process of rebuilding a x5 f15 and this would be really useful so trying to find a good one.
      11-05-2023, 09:23 AM   #13
RED_Y_
Drives: 2014 X5 3.5d
ISTA got all of this information.
      11-06-2023, 05:16 PM   #14
robbief00
Drives: 2016 F34, 2015 F15 M Sport
I tackled this job a few days ago and it was NOT fun! Took probably 3-4 hours of straight work not including all the breaks, finding tools, etc... Replacing the pump fixed the leak issue though.
I wasn't able to figure out how to get the side skirt off but was able to access the two bolts on the bottom of the fender using some flexible extensions.
      11-06-2023, 05:20 PM   #15
stlb5
stlb5's Avatar
220
Update to my situation. I was able to replace the pump without removing the quarter panel. I found a video on YouTube that was not in English, but they removed the trim under the doors, then undid the lower portion of the quarter panel and that provided enough room to swap the pump.
      11-15-2023, 10:59 AM   #16
Matt2408
Drives: BMW X5 F15
Yeah those bolts on the bottom, behind the side skirt took me like an hour. I was even trying to take the side skirt off, luckily like you, I just pulled it back and then extensions helped. Only difference is that i could have ripped the fender off because the whole front end is getting fixed after an accident.
      03-13-2024, 10:46 AM   #17
HokieCJ7
Drives: BMW Xdrive35d
Do you happen to have a link for that video? I looked for a while and cannot find it... Thanks!!
      03-13-2024, 01:12 PM   #18
stlb5
stlb5's Avatar
220
I can't find the one I originally watched, but this one walks through it.
