06-28-2022, 06:43 PM | #1 |
Rep 57
Drives: 2021 330i xDrive (M Sport)
Transmission fluid leaking after service?
Hi everyone. Wanted to get a second opinion before bringing back to the shop. My car ('15 xDrive x5 35i) at 100k miles and just got the transmission service per an indy shop's recommendation. This includes the new pan, filter, bolts, fluid, etc. The car ran fine without issues post pickup, but I noticed the following seemingly fluid leaking of some sort. It's yellowish, clear, and appears to be tranny fluid. Just wondering if it's something that was overfilled and the guy did not clean up completely, or an actual leak. Will bring the car back regardless, but wanted to see if you've experienced similar issue either before or after service. In the picture, the leak is from the passenger side. Thanks in advance!
Current Drive: 2021 G20 330i xDrive M Sport
Gone but not Forgotten: 2015 F15 X5 xDrive35i, 2011 E90 328i |
06-29-2022, 01:40 AM | #2 |
Insta~ f10_sapphire
158
Rep 412
I think it's an active leak because the belly cover is oily as well and if the shop overfilled it most likely that would have been removed while he serviced it and while changing the transmission pan. Go back to the shop and simply ask them. I wouldn't risk killing the trans by low fluids. I just had a catastrophic zf8 transmission failure on my f15 x5. My cars in the shop getting new trans installed and it's not a fun experience.
Insta ~ f10_shapphire
bavautosport43.00 |
06-29-2022, 06:46 AM | #3 | |
Rep 57
06-30-2022, 11:56 PM | #4 |
Insta~ f10_sapphire
158
Rep 412
keep us updated on the outcome.
07-01-2022, 01:30 PM | #5 |
Rep 57
Took the car back to the shop and showed them the photos I took. They put it on the lift immediately. Upon closer inspection they identified no leaks, citing that it was just some residual fluid that was overfilled by the procedure. Cleaned everything up again and I was on my way. Been checking everyday day and after every trip now without any further issue…Thanks everyone for your feedback. Happy driving!
07-01-2022, 04:20 PM | #6 |
Rep 628
Good to hear. From the photos and location being in close proximity to the fill plug, I was fairly sure it was a sloppy job of not cleaning after filling the trans.
They probably put everything back together before filling and so the tray held some fluid and spilled slowly later on. Sloppy, but it's a shop so they have production in mind rather than cleanliness much of the time. As long as they cleaned it and you have a warranty on the work I wouldn't hold it against them too much. |
bavautosport43.00 sukhk5272168.00 |
07-02-2022, 01:03 PM | #7 | |
Rep 10,256
bavautosport43.00 |
