07-02-2021, 07:12 AM | #200 |
Rep 1,497
Very solid numbers! I need more on the e30 tune you made. Any fitment issues with the VRSF intercooler? You're about the only one I've seen on the forum running it. Did you happen to chart IAT's before and after the VRSF IC? Did the xhp tranny tune improve shifts significantly?
07-02-2021, 07:39 AM | #201 | |
Rep 96
Thanks! Its a custom tune I made using my stock file and flashed via MHD. About 18psi mid range and 16psi up top. I've been making maps using various fuel and mods since my x5 was stock. Ive made 93 maps , e30 maps, e50 maps, and full e85 maps. I've also recently tried the map switching via MHD and its pretty cool, you can switch maps while driving. XHP does shift quicker and it raises the trans tq limiters so I don't have to make the DME under report calculated tq to the trans. Drives like stock (slightly lower shift points) in comfort and economy modes. Worth it. Here's a draggy of my lower setting map , 16 psi flat. |
07-02-2021, 07:42 AM | #202 | |
Rep 96
Here's stock vs vrsf FMIC logs . 2nd gear to middle of 4th. Both start around 75* iat. Vrsf only rises 4* throughout the pull. Stock rises 31* Last edited by WOT808; 07-02-2021 at 08:29 AM.. |
07-02-2021, 03:30 PM | #203 |
Rep 1,497
^^^Very nice! I'd love to see a separate thread on the VRSF FMIC. I'm running BM3 stage 2 w/ ER catless downpipe, but haven't upgraded the FMIC yet. I like the price point of the VRSF FMIC.
07-02-2021, 03:39 PM | #204 |
Rep 96
07-04-2021, 02:42 PM | #205 |
Rep 1,497
I'm loving the tune and it's def making some power. No draggy or track times unfortunately. I've been spending most of my time tracking down a bad passenger side front control arm and having the some front axle repairs done. I did do some data logging once I flashed the BM3 stage 2 tune. Max peak psi for stock was 10. Max peak psi for BM3 stage 2 was 19. I'll try to get some draggy info shortly.
07-29-2021, 09:19 AM | #206 |
Rep 96
Finally got some dyno time.
N55 e30 file I created vs stock map. |
ggunn9160.00 M302_imola842.50 |
08-09-2021, 07:01 AM | #208 |
Rep 96
My quickest 1/4 and 1/8th draggy to date in the x5. Looks like I let out early ,I was running out of room. I'll try again when I get some time.
M302_imola842.50 |
09-29-2021, 07:25 AM | #209 |
Rep 96
F15 xdrive35i N55
DP, intake, vrsf Fmic, xhp, fx-180, e85 tune I made Weight with half tank and me (230) in it I'm really aiming for 3.xx stock turbo. What's the n55 f15/16 stock turbo record? Last edited by WOT808; 09-29-2021 at 07:36 AM.. |
jmack1231300.50 |
09-29-2021, 11:28 AM | #210 | |
Rep 942
Drives: 2016 BMW X5
10-01-2021, 11:28 AM | #213 |
Rep 96
M302_imola842.50 |
10-02-2021, 11:31 AM | #214 | |
Rep 90
Are you going to continue to push it? |
10-03-2021, 07:52 AM | #215 |
Rep 1,497
10-03-2021, 04:59 PM | #217 |
Rep 90
I think he lists his mods in each post. Assuming the FX-180 is the HPFP below.
FX-180: http://spoolperformance.us/index.php...&product_id=90 Also, I think that is only way you can run E85 (run out of fuel with the stock setup). |
M302_imola842.50 |
10-04-2021, 07:44 AM | #219 | |
Rep 96
I can run a little richer in the mid range now without any rail pressure drop, hpfp holds 2900 flat at all times pretty much. I recently installed an n20 TMAP sensor and have been dabbling with 22.x psi mid range. Seems to like it but I haven't been out to get some good times yet. |
Blackhawk87844.00 |
10-04-2021, 07:46 AM | #220 | |
Rep 96
Stock lpfp seems to do good on full e85 with the fx180 |
Blackhawk87844.00 |
