      03-20-2017, 02:38 PM   #155
Originally Posted by Rotzy View Post
Originally Posted by r33_RGSport View Post
What gas octane are you using?
You can't use other's setting as your target, as different car, different climate will give you different result.
Also another factor, TMAP sensor. I have seen a few cars including mine had faulty TMAP sensor from BMW.
93 octane. Always. I even drive around the station and make sure I use a pump where the last person also pumped 93. That way I don't get a hose full of lower octane fuel.
What did your car do when the sensor was bad?
Perhaps if/when it happens again, I should let it store the code, remove the RC and let the dealership sort it out?
I wish I had a definitive answer, as I'm starting to like the RC!
Originally Posted by Bigtop View Post
Sorry, misundertsood.
No problem. Thanks anyway!
It was F10 528 N20/N26, F10 535 N55, F30 335 N55.
PM for Everyday DEALS!!
      03-21-2017, 05:08 AM   #156
Rotzy
Rotzy's Avatar
Drives: 2016 F15, 2015 F83
What I was asking is how did you determine that you had a bad sensor. What were the symptoms?
2016 F15 X5 50i M-Sport
2015 F83 M4
      03-21-2017, 04:10 PM   #157
Ahh, symptoms, got Drivetrain Malfunctions when you do a sudden acceleration.
The TMAP went crazy on sudden spike of boost.
      03-26-2017, 01:40 AM   #158
K_i_m_i
Finland
83
Drives: BMW X5 F15 xDrive 30d M-sport
X5 30d xDrive 2014
Celtic Tuning via OBD
original 258 PS (254 hp), 560 Nm (413 lb/ft)
tuned 333 hp, 511 lb/ft - better than 40d
Acceleration etc. equals (at least) to 40d
Very happy.
      03-26-2017, 02:54 PM   #159
bioman
173
Drives: E30
How is everyday drive-ability with BMS stage 1 on a 50i?
      03-29-2017, 05:01 PM   #160
alphaod
alphaod's Avatar
After a whole year after removing my RaceChip tune before bring my car into service... I swore there was no real difference, so didn't bother reinstalling it....
Today after giving my motor some cleaning and since I had already removed the airbox and a bunch of stuff, I said hell with it and put the RCU back in.
And yeah there's a difference. No idea about BMS S1, but RaceChip Ultimate very driveable.
2015 BMW X5 xDrive50i
BMW CCA 509766
      04-10-2017, 07:50 PM   #161
Rotzy
Rotzy's Avatar
For all those looking for some dyno numbers on the RaceChip Ultimate for the 50i, here you go.
Two months ago, I took my 2016 X5 50i to the dyno for a baseline. The baseline run is in red below and was conducted on a Mustang dyno. I was initially unimpressed with the numbers (352HP, 390ft/lb). After some discussion with the shop owner, in which we talked about the differences between a Mustang and Dynojet dyno, he said that his numbers average 14% lower than a Dynojet. Once I applied the 14% correction, my numbers are right in line with what I am seeing in this post:
http://f15.bimmerpost.com/forums/sho....php?t=1174104
With that sorted out and my X5 verified as making the power it is supposed to, I installed a Race Chip Ultimate and set it to C. After about a month of driving, I went back to the dyno and was very pleased.
#1 Red = Baseline
#2 Green = RC Ultimate C
#3 Blue = RC Ultimate D
Setting C was impressive with an at the wheels gain of 48HP and 47ft/lb (55HP and 53ft/lb if you apply the 14% correction), while setting D was not as good overall. Even though D produced higher numbers, there was significantly less low end power and the delivery was not as smooth. In the end, I am sticking with C.
2015 F83 M4
r33_RGSport12971.00
      04-10-2017, 08:33 PM   #162
WJMSprtXDrive
WJMSprtXDrive's Avatar
Drives: F15 xDrive50i M-Sport
Great info. I'm planning to tune the xDrive50i also in a couple months. I'm going for a baseline dyno in a few weeks. Any stock vs tune 1/4 mile runs available for the F15 xDrive50i?
2011 E90 335i xDrive 6AT Performance Edition Package, M-Sport, TTFS Tune, VRSF 3.5" Catted DP, Active Autowerke CP, Turner Motorsport Strut Tower Brace, Hawk HP+, Bilstein B6, Alpina B3 TCU Flash, K&N ----
2014 F15 X5 xDrive50i M-Sport, RSE, 3rd Row
      08-16-2018, 02:52 PM   #163
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
Question
There are 4 MAP sensors on the 50i; which ones are the TMAP sensors? The ones on the intake manifold or the intercooler? Sorry if this has been discussed prior and I missed it. Trying to keep up
      08-16-2018, 03:01 PM   #164
On the intercooler.
      08-16-2018, 03:12 PM   #165
9mmkungfu
Thumbs up
On the intercooler.
Thank you for confirming! After some digging, I was able to find it in this post as well:
https://f15.bimmerpost.com/forums/sh...6&postcount=43
      10-09-2018, 03:47 PM   #166
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
It's been a while since this discussion started. I'm looking at buying a 2016 50i pretty soon. Have other/better tuning options come out? I have JB4 on my F30 and I'm happy with it but that's my first and only experience with a piggy back. Think I'd prefer a flash.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      10-09-2018, 05:26 PM   #167
Rotzy
Rotzy's Avatar
Flash tunes are the norm now and Bootmod3 (BM3) is the most common. Check out this thread:
https://f15.bimmerpost.com/forums/sh....php?t=1507189
2015 F83 M4
      10-09-2018, 10:05 PM   #168
RaceChip if you want something easy with quality and smooth performance.
      10-11-2018, 12:44 AM   #169
spyderdoc
Drives: 2018 X5 35d. 2016 Porsche GT4
I really like the Race Chip black GTS on my 2018 F15d. I keep it is "race mode" all the time. My performance is better and I get better fuel economy.
My only complaint is that I occasionally get a check engine light that pops up when I am accelerating onto a freeway. The error says low EGR pressure. Does not cause limp mode or any performance problems at all. I clear the code with the Foxwell, and carry on until it happens again....No such error codes when nailing it off the line...Just when merging onto a freeway for some reason.
Super easy to install. Very happy with the Race Chip.
However, once my warranty is up, I will likely do ABC delete and tune at some point in the future once the emissions systems start to wear out and fail.....
r33_RGSport12971.00
      10-17-2018, 01:12 PM   #170
OFFWHITEX5
Drives: WHITE BMW X5 35i AWD M-SPORT
Has anyone ever took 12-15 Hours road trips with racechip? What's the highest setting on RC Ultimate ran without CEL for 35i motor? It was kind of hard to keep track of what motor everyone was running.
Thanks in advance.
2ND X5 IN 6 MONTHS. LET THE MODS BEGIN AGAIN.
      10-17-2018, 01:29 PM   #171
Thanks in advance.
The longest I took was 4 hours trip.
While I was on different product and use it for 8 hours drive.
      10-17-2018, 02:57 PM   #172
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks in advance.
I've taken several 4 hour trips. Gonna be driving down to FL For my brothers wedding which will be about 10 hours although not sure what you think is gonna happen on an extended drive.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      10-18-2018, 10:24 PM   #173
duercos
duercos's Avatar
201
Drives: F36>F16>G30
1. 2018 f16 3.5
2. JB+, mppk, mpe, CP, drop-in afe.
3. Jb+ set to max boost
4. Did 2 runs 0-60 so far.
First one was with half tank of gas, warmer temp, no er CP. second one is almost 5 sec flat, however it was -1.16% slope and dragy marks it invalid. But I also got my trunk full at the moment, so should even out))
      10-28-2018, 02:52 PM   #174
OFFWHITEX5
Thanks for these replies guys. I just drove down here to South Carolina. At about 8-10 Hours into the trip, I got a code for air fuel or something like that. No performance interruptions or anything else. The code came out of nowhere. I reset it went away a little bit later. So far its fine. Just trying to see if I want to remove it for the trip back
      10-28-2018, 10:45 PM   #175
2euro
2euro's Avatar
Drives: 2015 X5 50iMSport
I see a lot of race chip. Anyone do a Dinantronics?
Are they more conservative as far as numbers? Or is it the price?
2015 BMW X5 50i MSport | Alpine White
      10-29-2018, 12:17 AM   #176
duercos
duercos's Avatar
201
Drives: F36>F16>G30
Did u have a racechip tuner installed?
