      03-31-2021, 07:31 AM   #89
mrfochon
Drives: X5 F15 M package
I installed a carplay box and got rid of being dependent on BMW and career supported technology.
RTTI is really bad in NYC greater area.
      03-31-2021, 08:11 AM   #90
corduroy
Drives: '16 X5 xDrive40e (F15)
Originally Posted by Kewl X5 View Post
Has any done the Option—>Update BMW Assist and see if you get RTTI working again with Navigation?
Worked for me.
I've had my mmi for about a year now, it's great. But, at least for those of us with hybrids, the climatize function also gets the hybrid battery to a more optimal temperature.
      04-01-2021, 11:33 AM   #91
DJMOJO
DJMOJO's Avatar
Drives: 2011 N55 E90
2016 BMW X5 40e  [0.00]
2010 BMW 335i  [0.00]
Ill try the upgrade tonight and report my findings, hopefully they discount a 4g combox upgrade for those of us that want one. I have a F15 40e and like to cool off or heat the car up remotely or check the battery charge status, amongst other critical features.
2011 BMW 335i N55
Pure Stage 2 Turbo and Turbo Inlet. VRSF 7 inch HD Intercooler, Down Pipe, Charge Pipe and Turbo Outlet Pipe. Go Fast Bits DV+. Stage 2 Low Pressure Fuel Pump (Walbro 485high pressure/high volume version) MHD E85 Pro Tune (MOTIVE Motorsport). Black Market Parts Port Injection Kit (6 750CC Injectors) Split Second AIC-1, AFE Stage 2 Intake (Pro 5R Oil).
      04-01-2021, 11:46 AM   #92
Neuera09
Drives: 2016 X5 Xline with MPPK
I updated my car via connected drive and it appeared I have the service now. I drove 8 hrs from SoCal to NorCal and not once the system gave an updated traffic status. 👎
      04-01-2021, 11:50 AM   #93
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Do you have the latest map?
      04-01-2021, 11:53 AM   #94
Neuera09
I’ve got the 2020-2 update. I guess it's time to download 2021-1 and try to see if it works.
      04-02-2021, 08:05 AM   #95
BhamDavid
209
Drives: 2016 M3
I updated my M3 and wife’s X5 several times over the past few days. Still nothing works. I wrote the assist folks an email two days ago as indicated in the BMW instructions if the reset doesn’t work. So far: crickets.
I’ll post anything I find out.
      04-09-2021, 11:00 AM   #96
XxBBVTMxX
XxBBVTMxX's Avatar
I did my update 3 days algo and it did not work (RTTI). I left it alone. Today, it's working 👍🏽
      04-09-2021, 05:27 PM   #97
Kolianovskyi
87
Drives: BMW 650i
But, did you have that service payed/subscribed before you updated through the car menu?
      04-09-2021, 05:32 PM   #98
XxBBVTMxX
XxBBVTMxX's Avatar
No, I don't pay for RTTI nor am I subscribed. BMW is giving it complimentary so now I have it, due to the shutdown while they figure out the final word. I just hope it's not a... well, you took the complimentary service... 😅
      04-09-2021, 05:39 PM   #99
Kolianovskyi
87
Drives: BMW 650i
Ok. Thanks. Just tried to update mine. Nothing thus.
      04-09-2021, 07:28 PM   #100
RED_Y_
Drives: 2014 X5 3.5d
Yep did the update, nothing.
      04-09-2021, 08:44 PM   #101
XxBBVTMxX
XxBBVTMxX's Avatar
Yeah, mine literally took 3 days to start working. I didn't bother calling the BMW number. It's working like a charm today. I did also turn off the RTTI satellite receive option, waited a while, then turned it back on. Try that, but ultimately give it time and it should work.
Of course, not insulting anyone's intelligence, but I'm sure you'd have to have active subscription to one of their services for it to work. Like, if none of your features worked before, then I don't think this freebie will apply.
      04-10-2021, 12:12 PM   #102
RED_Y_
I used to purchase RTTI as well as I still have active remote services and tele services.
      04-10-2021, 01:27 PM   #103
XxBBVTMxX
XxBBVTMxX's Avatar
Then you should be good RED
      04-10-2021, 11:38 PM   #104
Kolianovskyi
87
Drives: BMW 650i
Same for me.
Tried with 2 cars. Nothing as of now.
      04-12-2021, 02:37 PM   #105
Kolianovskyi
87
Drives: BMW 650i
Sent a request to BMW today. Meanwhile, still nothing for both cars.
However, they published a new application today. It has a direct link to the store to buy new options))))) bitches. 😂
      04-12-2021, 04:08 PM   #106
RED_Y_
When I go to the store using Connected Drive in the car it just show the message with QR code that my services are no longer available.
      04-12-2021, 06:09 PM   #107
XxBBVTMxX
XxBBVTMxX's Avatar
I get the same thing. That the store is no longer supported in my vehicle and to go to the store.
      04-13-2021, 12:10 AM   #108
Kewl X5
Drives: X5
From your iDrive menu, go to Connected Drive, then press the "Option" button by your iDrive controller and select "Update BMW Assist"
After I did this, it took a day before RTTI and online search went back online.
      04-13-2021, 10:42 AM   #109
RED_Y_
Yep, did that like 10 times. Nothing.
      04-15-2021, 12:02 PM   #110
floop
Drives: 2020 X7 40i
I am highly annoyed with the discontinuation of ConnectedDrive services as I like to have RTTI, even though it doesn't seem to be as accurate or as timely as Google Maps. But I prefer to use the iDrive navigation rather than CarPlay through an MMI box because I like getting the turn-by-turn directions in the HUD.
It looks like we may be able to still receive traffic info into the head unit through TMC data that could be received from a SiriusXM subscription. These are the coding instructions I found on another forum:
TI_TMC = aktiv
TI_CA_TMC = aktiv
TI_TPEG = nicht_aktiv
TI_CA_TPEG = nicht_aktiv
TI_TMC_REGIONAL = aktiv
TI_TRAFFIC_INFOMAP = aktiv
NAVI_TRAFFIC_INFO_MAP = aktiv
Perhaps someone without an active ConnectedDrive subscription and with a SiriusXM subscription (with traffic) could try it out and see if it works. I don't want to set up a SiriusXM subscription just to test this one thing.
