09-21-2016, 11:18 AM | #1 |
Rep 658
Drives: i7 xDrive60
Tire Problems
I'm running my X5M50D with 21" run flat tires. Yesterday I was on a business trip to Dalarna i Sweden and on my way home to Stockholm, driving on the cruise control at about 100-110 km/h, about 65 mph, I suddenly hear a lot of noise from the rear right tire. Its so bad I have to immediately stop the car. I walk around the car and I see nothing wrong. I check the right rear tire and it is damaged. A two feet long peace of the tire is loose and you can se the metal cord within the tire.
Even though the car does not indicate a flat tire I didn't dare drive it any further. I called BMW Hotline and the sent a tow truck and arrange for a rental Volvo at the nearest gas station. I talked to the place they towed the car to today and they have never seen anything like this before. Even though I had a run flat tire I hade to get the car towed and Im not getting it back until Friday. Still it could be worse. I'm flying to the US and Atlanta on Saturday for a week and my wife need our X5 while I'm gone. 4 new 21" tires are not sheep in Sweden, I tell you that. its more than USD 3000.
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30) |
09-21-2016, 11:19 AM | #2 |
Rep 658
Drives: i7 xDrive60
Tire
/Fredrik
09-21-2016, 11:21 AM | #3 |
Rep 658
Drives: i7 xDrive60
Tire
/Fredrik
09-21-2016, 04:00 PM | #5 |
Rep 493
If possible, please have this seriously checked and please post the results - it could be a rare type of puncture, like hitting sort of a fishing hook solidly embedded in the ground that pulled off a long rubber strip - or a tire manufacturing defect, or a premature tire shoulder wear due to a very wrong rear suspension adjustment.
Whatever happened, it did so at "Swedish speed" -at German speeds the outcome could have been catastrophic. |
09-21-2016, 05:20 PM | #6 |
Rep 83
How many kilometers on that set of tires?
2021 X3 M40i, 2021 X5 xDrive 4.0i
------------------------------------------------------------- 2016 X5 3.5i, 2017 X4 M40i, 2006 330i E90, 2004 X5 3.0i, 2000 528i MT, 1986 535is MT , 1985 528e MT, 1985 325e MT |
09-22-2016, 02:55 AM | #10 |
261
Rep 733
Definently have the tire manufacturers rep look at this. If this tire was NOT excessively worn on the inside edge than I have a uneasy feeling this is one of those rare tires that may have got by the QC checks at the factory.
Best of luck to you, sorry this happened.
09-22-2016, 03:16 AM | #11 | |
Rep 658
Drives: i7 xDrive60
/Fredrik
09-22-2016, 07:28 AM | #13 |
1150
Rep 2,426
Looks like you worn out the tire and due to the aggressive camber these cars have, the inside is more worn. Many summerr tires do not last that many miles.
Anyways I would measure your other tires. Make sure to do inside, middle, and outside threads. |
Kzang3238.50 |
09-22-2016, 07:55 AM | #14 |
Rep 289
35000km on a tire size and performace car / model like this its honestly pretty good.
all you can do is have proper geometry and chasis alignment done |
09-22-2016, 08:25 AM | #15 | |
Rep 5,066
Always inspect your tire wear and change tires accordingly.
09-22-2016, 10:36 AM | #17 |
1150
Rep 2,426
Also I would adjust the tire pressures a bit higher to combat this. Although doing so will make the ride slightly harsher, but overall should improve handling, durability, and mileage. I also had some problems with more wear on the inside (very little), so I increased cold pressures 4 psi over recommendation, seem to have helped me a bit, tires after 20000 miles now seem good wear overall. To combat harsher ride, consider non-runflat tires and a spare donut.
But if you have consistent issues, I would consider doing a wheel alignment as well, but adjusting tire pressures can remedy a lot of issues without introducing risk or additional cost. I would hate to see a fellow driver feel unsafe driving this beautiful beast of a car just because of this unexpected tire wear issue. Please do, however, report back how the other tire is looking so we have a better idea of the situation. |
09-23-2016, 05:28 AM | #18 |
Rep 658
Drives: i7 xDrive60
I picked up the car yesterday with 4 new tires. This was not an issue of more ware on the inside. The tire simply malfunctioned.
/Fredrik
09-23-2016, 08:04 AM | #19 |
Rep 681
09-23-2016, 08:57 AM | #20 |
1150
Rep 2,426
Oh damn. Well I hope they take care of you then!
