09-22-2016, 07:59 AM | #1 |
Rep 289
DOWNSHIFTING - manual downshifting yes or no?
I drive mostly in sport and use the paddles to change gears.
Whilist slowing down, cornering etc, or coming off highway I downshit manual so the gears "break" / helps slow down the car faster ..... this is being done on manual stick shift cars forever..... I have heard some rumors its not good for the modern automatic transmitions. Any validated intel on this? ** for the record, I do no go grazy on RPMS, or is done smoothly and all that. never go on hig revs on either upshit or downshift. so once again, QUESTION is: Ïs it safe to use flappy paddles to downshifting breaking useing engine.......... Last edited by pragueX5; 09-22-2016 at 08:57 AM.. |
09-22-2016, 08:23 AM | #2 |
Rep 5,066
Agreed... that I've always done this on a manual transmission, as I was "told" to downshift for faster stop and let the engine help slow down the car to save on the brake pads and also for rev matching... but I am not sure if this practice was good or bad... I've never had any transmission or engine issues as a result. In regards to the modern auto transmission I have no idea.
09-22-2016, 08:32 AM | #3 |
Rep 402
While I don't think the vehicle would let you downshift in a way that would be harmful (i.e. over revving the engine), I can't see why you would do this anyway. In my mind, it's far cheaper to replace brakes than a transmission.
It seems that the X5 uses coasting to regenerate the battery as well. By downshifting, you are not allowing the car to do the whole "Efficient Dynamics" thing. Also, I find the automatic transmission in the X5 to be one of the best I've ever driven. As someone who used to drive manual transmission cars, it's very rare that I find the X5 in the wrong gear during everyday driving. |
09-22-2016, 08:53 AM | #4 |
Rep 3,834
It's fine. X5s have slush box transmissions, nothing really wears during a downshift/engine brake. I've been doing that to many of my cars. One catch though, engine braking with these newer engines with low pressure piston rings allow oil to pass-through (oil burn). It's not harmful as the oil will just burn off, but if you have to top oil more often then that's the reason.
Engine braking technique has been used by experience drivers for years. From tracking to going down steep hills, this technique reduces brake heat and excessive brake wear or risk of brake fade during these events.
09-22-2016, 08:53 AM | #5 | |
Rep 289
thanks for your input but I have something else in mind.... its for the driving style, more agressive, downshifting before a turn is always the only way to make the turn fast and proper while driving agressive. nothing to do with costs. and I belive downshifting actualy is cost saving in terms of the Eco BS, as it allows the battery do recharge via alternator. coasting is somethine else |
09-22-2016, 08:55 AM | #6 | |
Rep 289
09-22-2016, 08:56 AM | #7 | |
Rep 289
PS> what is ""slush box tranny"? thnx |
09-22-2016, 08:57 AM | #8 | |
Rep 3,834
Slushbox = regular auto transmission using a torque converter, not a dual clutch or SMG.
09-22-2016, 09:48 AM | #9 |
Rep 211
I find downshifting with my 35D useless, there is next to no compression braking. My previous Acura MDX had tons which made it fun in the corners. It's one of the bigger disappointments in the X5 for me.
09-22-2016, 10:07 AM | #10 |
1150
Rep 2,426
That's how diesel engines work... there is little engine braking.
09-22-2016, 12:07 PM | #11 |
Rep 211
09-22-2016, 12:26 PM | #12 |
Rep 5,066
MPPK + RCU makes the 35i a beast IMO... Very nice low end torque as well
