02-16-2017, 12:46 PM | #222 |
Rep 5,066
42pilot sold his X5 diesel and is probably no longer active on this forum and Trojan hasn't been on here for a long time as well. I would suggest setting your tune at default, run a tank of gas, then increase by one click on each tank letting the engine adjust to the tune until you are happy with the power level. There is a lot of information on here on the performance review for each settings.
P.S. Make sure to use high quality fuel or you may trigger CEL. Check these threads for more information: http://f15.bimmerpost.com/forums/sho...acechip+diesel http://f15.bimmerpost.com/forums/sho...acechip+diesel http://f15.bimmerpost.com/forums/sho...light=racechip
02-16-2017, 01:01 PM | #223 | |
Rep 25
I've got my Racechip Pro couple of weeks ago and already tried few different settings. It takes me about 2 weeks to burn a tank of gas ( damn diesel :-) ) so I thought to save some time and use other's experience of ideal setting for 35d |
02-16-2017, 01:04 PM | #224 |
Rep 5,066
Well I wouldn't skip or jump settings, the engine needs to acclimate to the new boost, for a smooth operation, I would just up the settings one at a time.
02-17-2017, 10:35 AM | #225 |
Rep 25
I contacted Racechip support and the settings they recommend were not "one at a time" at all.
After deafault E0 they suggested to try E2 and then B1 , where is the logic here ? Last edited by m12volt; 02-17-2017 at 10:43 AM.. |
02-17-2017, 11:27 AM | #226 | |
Rep 5,066
Hopefully, someone else with Diesel experience will chime in.
03-07-2017, 03:29 PM | #227 |
267
Rep 345
Drives: 2019 X5 40i M
have had mine for two years now. The biggest difference comes from 03. It does make the engine a bot louder. Second best setting is F3 which is much smoother but not as fun. This is for the 35d.
2019 X5 X40iM
03-09-2017, 09:57 AM | #228 |
Rep 246
Drives: 2015 BSM M4
Picking up a X5 35i shortly, so is Racechip better than JB4 stage 1? Not doing DPs or anything else crazy. Just want a little more HP over stock and easily removal. I have JB4 in stage3 for my M4 for last 25k miles so very familiar and happy with it. Just wanted to get opinions from the F15 owners.
03-09-2017, 11:55 AM | #229 | |
Rep 18,717
Power gain wise, both are about the same. Just the RaceChip Ultimate is as easy as opening up the box and change the dial. While the BMS Stage 1, you need to connect the USB cable, turn on your computer, and change the setting. Quality wise, RaceChip have weather proof casing and comes with dummy plug where you can just use it instead of removing the whole harness. Now, I just brought in a couple sets of the RaceChip Ultimate Connect, where it will allow you to change settings on the fly. If you want something simple and easy, this will be it. The difference between the regular Ultimate and the Ultimate connect: RaceChip Ultimate Connect setting are preset. Through the app, it will only allow you to change from preset setting of Efficiency, Sport, and Race. Although, you can ask for custom setting through them if you want more kick and they will supply you with a new firmware. Also, through the app, you can set it to bypass the module without using the dummy plug. Lastly, it has a warm-up timer which will automatically disable the RaceChip until the engine is up to its operating temperature. Oh, and it will update the firmware as needed via Bluetooth. In my opinion, the RaceChip Ultimate Connect is good for you who doesn't want to deal with testing each settings by yourself or have others driving your car (such as; valet, any family member who can't handle the power gain, or during service).
DarksideM4207.50 |
03-19-2017, 12:24 AM | #230 |
Rep 65
Is this true only for the RC ultimate, or does it also apply to the Pro2?
03-19-2017, 08:45 AM | #231 |
General of the Space Forces
171
Rep 721
Does anyone here have experience with the VR Tuned Gearbox Tuning for BMW? Says it allows for more torque, among other things.
https://www.vividracing.com/catalog/...150786098.html |
03-19-2017, 10:54 AM | #232 | |
Rep 18,717
03-19-2017, 11:20 AM | #233 |
Rep 137
Any one experienced issues with Charge pipe breaking off when running high boost. I had an X4 35i and after running JB+ for 1 month charge pipe blew off. Dont want this to happen to my X5.
2018 G30 540i
2011 M3 E92 |
03-19-2017, 11:33 AM | #234 | ||
Rep 65
One other question: do 03 and F3 mean S2=0;S1=3 and S2=F;S1=3? Or is it the other way around (S1=0/F;S2=3)? |
04-13-2017, 05:07 AM | #235 |
53
Rep 301
I recently installed RC Ultimate in my 2016 X5 35d with the default E0 setting and it does add some fun for sure. No issues with CEL or anything else. Going to try E2 next as that seems to be what is recommended here.
When you guys talk about O3, is that a zero or the letter O? Sorry haven't looked inside the RC yet so not sure what the dials look like...
2002 E46 M3 Convertible (MT) >> 2008 E92 M3 Coupe (DCT) >> 2020 F87 M2 Competition (MT)
04-13-2017, 07:01 PM | #236 |
53
Rep 301
Well just opened the RC Ultimate and went directly from E0 to 03. Holy f*** this thing is a rocket now.
Might dial it back to F3 as the power delivery is quite abrupt, but certainly fun launching from a stop light they way it is now. Think engine noise is a bit higher too as someone mentioned, but not to the point where it is bothersome. In theory S2 should only increase how far up into the RPM range the RC is effective, so one would think it shouldn't affect noise etc unless up in those higher RPMs?
04-26-2017, 11:28 AM | #237 | |
Rep 978
. . . . I have a 2014 BMW X3 35 (gasoline) and I have a Racechip Ultimate tune and it originally came with setting B1. But despite the above indicating for Performance level 2 I should increase S1 to 2, I have read in more than one place that we should NOT be adjusting the S1 dial, as it's only for diesel engines. So I reached out to Racechip directly in Germany, who confirmed: In petrol engines only dial S2 (Ultimate) has a function that's correct. Dial S1 can therefore permanently remain on "1". There unfortunately is a typing mistake in the current manual this is why dial S1 is also change on the third performance level. This mistake will be fixed with the next print of the manuals. For increasing the performance just increase dial S2 clockwise to higher positions: C, D, E etc. On a separate topic, has anyone here upgraded their firmware using the micro USB port that's on the circuit board? .
08 335 MT (RWD) | Cobb OTS E30 maps | AMS intercooler | AR DP's | K&N filter | KW V2's | M3 front control arms | Stoptech slotted rotors & Street Performance pads | Stoptech SS brake lines w/STR 600 fluid | PE mod
X3 35 with a few little mods |
04-27-2017, 11:16 AM | #239 | |
Rep 978
You can't do any update on the RaceChip by yourself. Only we remap RaceChips if necessary.
07-24-2017, 11:39 AM | #240 | |
Rep 137
Hi Mike,
Are you still running F3 ? Are you happy with it ? I've on E0 and thinking about going up a notch. I tried E2 but was not happy with it. I felt more power but the engine sounded rough. E0 has been trouble free and smooth. Is F3 smooth ? Quote:
07-24-2017, 05:39 PM | #241 |
324
Rep 312
I have been running E0 for about 6 weeks now and although the power was quite good, I have noticed a significant drop in fuel economy. I was getting 18mpg (combined). I spoke to Racechip and they have me trying EF now. Mine's a new X5 with about 1700 miles, so Maybe I'm yet to hit the break in period before I start to see 20+ mpg average I was hoping to see atleast 20 mpg.
2017 X5 xDrive35d Rare Jade Pearl (custom green), M performance parts.
Ice Age, Stone Age, Bronze Age..... now (h)igh (d)definition Age or hdAge |
07-24-2017, 06:20 PM | #242 | |
Rep 137
That's rather low. Although it is new and I would give it til at least 3000 to fully brake in. BTW I wouldn't run the racechip while it's still breaking in, but that's just my opinion.
What I have noticed is with the racechip I get on average 2 MPG better than stock. I've also found Chevron to run a slight better MPG than Shell. With Chevron, I'm usually in the 23 - 25 mpg combined. With more highway it easily goes up to 26+. I also don't drive it that hard all the time. Quote:
