09-16-2018, 08:35 PM | #1 |
Rep 7,164
Lowered and now loss an airbag?!
Ok rerouting all of my posts out of the DIY thread as to not muddy it up with my issues. So hopefully this will help get some answers.
Well F my face. Finally got my eibachs on and my entire driver side is an inch lower than the passenger. The rear driver is slammed lol. Idk wtf happened here. My entire rear is also an inch lower than the respective front wheels as well. But that may just be the links. But idk why it would be so off. I made sure the springs were set in the rubber spacers all the way till it stopped both top and bottom. Just perplexing.
09-16-2018, 08:44 PM | #2 |
Rep 7,164
So long Story short I got some spacers for the rear and want to paint all my calipers and clean up all the rust in the rotors and calipers. So I needed to lift the rear and remove the wheels anyway. After doing so I found my driver side rear bag completely deflated which was causing it not to descend as low as the passenger side when I jacked up the rear.
I pulled the battery. Re attached and started the car to see if I could get it to fill with anything. No avail. Except for a ton of errors. My mistake for starting the car while jacked up lol. Clear as many as I could but still have a bunch so I gave up that venture. Decided to get on with my project. Sanded down with a wire brush all my rotor rust (there was a ton on the rears for some reason. So much that I couldn't get the rims off.) and sanded down the calipers and painted black to match the fronts. after it all dries for a few hours I'm going to attempt to reattach the rear wheels and start her up and see if she adjusts. I do remember noticing how slammed the rear was after sitting for two days while the front was up on jacks as I swapped springs, painted the calipers and rotors, and installed a new control arm. But after I put her all back together and started it up I watched the rears lift. Well at least the one side that I was standing next too. I just don't remember which side that was now. Thought it was the driver side which is the side in which the air bag is empty. Anyone know a way to force the pump to run so I can see if it's leaking somewhere? Does the engine have to be on, as it would be easier to listen for a leak without the exhaust and engine noise.
09-16-2018, 08:55 PM | #3 |
N00B
94
Rep 210
What are you using to clear codes, do you have bimmerlink or carly to check further into it? The diagnostics in both of those are pretty detailed. Wish I could help you more, good luck!
The owls are not what they seem!
09-16-2018, 09:34 PM | #4 | |
Rep 7,164
I'm more concerned why a single bag all the sudden has no air in it lol and if I can activate the pump without the wheels being on to see if there's a leak. Just want to know if I'll be taking my wife's car and driver her to work before I head in. Lol Also why aren't there any rear jack locations under the side skirts. Pretty stupid. Have I just missed where this is normal lol. I usually just jack the rear and front from the center vehicle points cuz it's easier but ya
09-16-2018, 11:50 PM | #5 |
Rep 7,164
Solved by detaching both rear links and fiddling with them to get the pump to fill the bag. To a bit of manipulation before I got it full. Sorry for not searching better. Simply couldn't find the correct words to search for.
Russmov1328.00 |
09-17-2018, 01:35 AM | #6 |
Rep 535
You are one brave soul!
Present: 2014 X5 50i
09-17-2018, 07:57 AM | #7 | |
Rep 1,343
Was it a sensor or something telling the bag it was already inflated? Either way, it's good you didn't need to replace it, or worse, take it to the dealership
09-17-2018, 08:11 AM | #8 | ||
Rep 7,164
I'm assuming I basically just gave it a kick in the nuts. However here is my new problem. Looks like I hit a wire or something. Or maybe a plug I didn't reseat although the only plugs I know were messed with were the pad sensor and wires that go to the front shocks. Anyone have any idea why my parking brake, pedestrian detection, cruiser control, and chassis stability is all out of wack???? All I did was swap springs and paint the rotors and calipers lol. Also note I've attempted to clear codes with BimmerLink and the car sat all night locked and still this this morning. Also can't change driving mode which isn't too surprising. But I hate the steering feel of comfort mode so I'd love to get this figured out lol
09-17-2018, 08:15 AM | #9 | |||
Rep 1,343
09-17-2018, 10:50 AM | #10 | ||||
Rep 7,164
09-17-2018, 12:01 PM | #11 |
Rep 7,164
So here are the codes that I can't clear. All seems to deal with vehicle level sensors which is odd.
So I have a confession. I did not disconnect the battery before installing the springs and links. Could this be the issue? I thought it might which is why I disconnected it last night but when I reconnected and started they were all still there. Any thoughts as to what I can do to clear these errors?
09-17-2018, 11:05 PM | #12 |
Rep 7,164
No love is starting to depress me lol. Anyone know where the parking brake wires are? I'm wondering if maybe I knicked one when I was grinding off the rust on the rotors and calipers.
09-17-2018, 11:10 PM | #13 |
Rep 535
If you have rheingold, I would start that and see if calculates a test plan for clearing out the errors. It will kind of walk you through it most of the times with sensor calibration.
09-18-2018, 07:42 AM | #14 |
Rep 7,164
I do not have rheingold. Is that a diagnostic SW that the dealers use?
09-18-2018, 04:48 PM | #15 | |
Rep 43
I'm no expert, but most of the codes look like it was pretty pissed about the bags being out of whack. I've noticed that when you piss off a BMW, there are often many fault codes that are triggered by the primary fault, but aren't necessarily or logically related. You should see the codes that are triggered by a tune. Parking brake gets triggered for that as well. If I were you, I'd clear with Rheingold and worry about if you nicked something if/when the codes return. Speaking of Rheingold...: https://www.e90post.com/forums/showthread.php?t=1220039
2014 X5 xDrive50i M-Sport ///
bootmod3 Stage II Tuned ARM Catless Downpipes |
09-18-2018, 07:30 PM | #16 | ||
Rep 7,164
Can you briefly explain what rheingold is too cuz I didn't see it mentioned in that link but VM3. I've also heard of people mentioned ISTA. Are they all the same thing? I remember people talking about needing ISTA for a bag replacement and brake fluid flush to activate the ABS. Is this all just the same program?
09-19-2018, 11:50 AM | #17 | |
Rep 43
The link mentioning V3 is referring to the 3rd version of the virtual machine which has Rheingold installed on it. If you don't have any experience with virtual machines, you may want some assistance in getting it set up. If that's that case, let me know and I'll do my best to assist!
09-19-2018, 05:38 PM | #18 | ||
Rep 7,164
09-21-2018, 10:48 AM | #19 | |
Rep 43
Sorry for the late response, I thought I subscribed to the thread. Subbed now!
09-21-2018, 03:28 PM | #20 | ||
Rep 7,164
09-22-2018, 11:08 AM | #21 |
Rep 7,164
And what I woke up to today lol. FML only this could happen to me. This time all air gone from driver side.
09-22-2018, 12:08 PM | #22 |
Rep 7,164
So it would appear my link rattled loose and disconnected. Got it hooked back up and got the bag to fill again.
Did some more investigating and found this beauty. I had a hunch this happened and it appears I was correct. $106 for a new one and will be here Tuesday. ABS sensor wire got cut.
