11-19-2023, 12:39 AM | #23 |
JJR.95
26
Rep 8
Drives: F15 X5
A friend of mine has had this exact issue for months now and hasn’t been able to figure out a fix. He’s avoiding the dealership diagnostic fee because his AC still works but I’m going to send him this forum link. I love how helpful everyone is in Bimmerpost! You guys are the best!👍🏼
Cbozz688.50 |
12-04-2023, 08:42 PM | #24 | |
Rep 901
Cbozz688.50 |
02-04-2024, 01:45 PM | #25 | |
Rep 145
02-04-2024, 02:28 PM | #26 |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
you don't-- you need a few dollars to get it fixed! read a few posts before this one!
02-04-2024, 11:40 PM | #28 | |
Rep 901
02-05-2024, 08:25 PM | #29 | |
Rep 2,719
Drives: M3
When I was shopping they had it but I decided to get a red one. I like it. Looks oem red. Posted pic earlier in this thread..
musa423.00 |
02-06-2024, 04:42 PM | #30 | |
Rep 901
https://www.amazon.com/s?k=PLCC-4+SM...ref=nb_sb_noss |
02-06-2024, 08:28 PM | #31 |
Rep 736
I just ordered a pack of 5 green LEDs and will send them with my panel to Chris once I get them from Amazon. If anyone needs their LED fixed, you're welcome to use one of my LEDs that I'm sending to Chris.
Dinan CAI/Exhaust/Ignition Coils; BM3 Stage 1; xHP Stage 2; Sprint Booster; 22" Aristo Forged Sport 7 Split; KW V3s; 3D Rep Splitter/Side Skirts, Parsan Tuning Diffuser; Renegade Roof Spoiler; M Performance Kidney Grills/Fender Vents; iND Roundels/Trunk Emblem; CF Flat Bottom Steering Wheel; M Performance CF Steering Wheel Trim/Center Console/Shifter/Sport Pedals, Andream CarPlay; BlackVue DR750S Dash Cams
02-07-2024, 01:55 PM | #32 |
Rep 901
I decided to do-it-myself. Lots of how-to videos in youtube for SMD LED (Surface-Mount Device Light-Emitting Diodes) install. I like this one, making sure to get the polarity right and test before buttoning up. Use leaded soldering wire and the temperature should be somewhere around 560 Fahrenheit - too hot and you risk melting the LED itself. Can test the correct temp when removing the burned out LED:
EuroCarFan329.50 |
02-07-2024, 06:31 PM | #33 |
Rep 901
Polarity - The notch is positive and the rest are negative. If in doubt, with your Multimeter in Diode Mode, place the RED and Black probes on opposite leads of the LED. If it doesn't light, then switch the leads. When it lights, wherever the RED lead is your ANODE (+) and the BLACK lead would be your Cathode(-).
02-10-2024, 09:43 AM | #35 | |
Rep 2,719
Drives: M3
musa423.00 |
02-23-2024, 04:05 AM | #36 |
Rep 901
It turns out my case was a loose solder joint. The LED looked ok including the solder joints and I was curious why it wasn't working (testing using multimeter in diode test mode). I pressed the solder joints, heated them up and applied a little more solder. The LED started working.
EuroCarFan329.50 Cbozz688.50 |
02-23-2024, 11:53 PM | #37 |
Rep 7
This thread is of particular interest to me. I just got my X5M a couple of months ago and there are several LEDs out on my panel: 2 on each of the heated seat buttons, both "Auto" buttons, and something else that I'm not remembering right now. Also, the right turn signal indicator doesn't illuminate on the dashboard. I had to code it into the HUD so I could see when it's on.
What the heck is going on with LEDs in these cars? Is it worth learning to properly solder to fix this our is it easier to go the eBay route? Were these panels used in more than the X5 and X6 (that will help with searching). Thanks in advance! |
02-23-2024, 11:58 PM | #38 |
Rep 736
You can have it fixed or you can buy my old one.
I found a panel with ceramic control knobs so I sent mine to Chris to fix the A/C LED then I'm going to post it up on eBay.
02-24-2024, 12:14 AM | #39 | |
Rep 7
This account doesn't have enough posts, so I cannot PM yet. |
02-24-2024, 02:02 AM | #40 |
Rep 901
I think the issue is soldering quality of these panels. LEDs should last for years upon years. I was able to resolder my A/C LED. If you have to replace an LED, make sure the new one is of the same luminosity as factory otherwise it would look odd and off when some LEDs of the same color are brighter than others. I think the ultra-bright ones in Amazon are not a good choice for our panels.
The quality of stuff nowadays is quite wanting. No wonder the USA Odysseus Moon lander 'tipped over on touchdown' - we can't repeat what we did over 50 years ago. Last edited by musa; 02-24-2024 at 02:51 AM.. |
02-24-2024, 06:31 AM | #41 | |
Rep 7
02-24-2024, 11:00 AM | #42 |
Rep 736
Here's a pic of my replacement panel with the ceramic controls. It's the same as my original one except this one says FM/AM while the other says BAND.
02-24-2024, 03:44 PM | #43 | |
Rep 7
Here's mine. Note that the right heated seat is on but only two of the three indicators are on. Also note that it's in Auto mode but the "AUTO" lights both are not on. I'm interested in buying yours. Can you, a long-time forum member, PM me and I reply? (I know some forums work that way) Any other way that I can contact you? |
