      10-20-2016, 09:50 AM   #1
X_and_M
Drives: X5M
Telescoping steering wheel malfunction
So all of a sudden my telescoping steering wheel function stopped working and is stuck in the entry/exit position closest to the gauge cluster. Tried turning the car on off and problem persisted this morning. Needless to say I am disappointed with this problem. I find having the steering wheel as close to my body as possible adds tremendously to driver comfort. Has anyone else experienced this issue? I'll be taking the car into the dealer this weekend.
Just hit 11k miles.
      10-20-2016, 10:28 AM   #2
onfireX5
Drives: F90M5,F85X5M
Mine died at 2300 miles. Will only go up and down. Seems common in regular X5's A switch burns out. I'll report mine at the next service. Long arms ftw.
      10-20-2016, 10:40 AM   #3
Alberta
Alberta's Avatar
2035
Drives: F90
This happened to mine once.
Never had that problem again.
      10-20-2016, 01:01 PM   #4
AlexLou1222
AlexLou1222's Avatar
Drives: 2015 X6M 2014 X1
Mine starting to have some weird noise when moving, but just 30% of the time so for now I just leave it be.
992 Turbo S
X7 M60
      10-20-2016, 02:10 PM   #5
fyim
fyim's Avatar
83
Drives: E92
Same here.
      10-20-2016, 02:31 PM   #6
Alberta
Alberta's Avatar
2035
Drives: F90
Same thing.
Strange noises when it goes back inside.
      10-20-2016, 03:08 PM   #7
Defib
Defib's Avatar
Drives: 2018 M5
My telescoping column died at around 4000 miles. It would still move up and down but not in and out. The dealer tried to reset it with no luck. The entire steering column had to be replaced.
      10-21-2016, 01:07 PM   #8
Alpine300zhp
Drives: 24 M4 Comp RWD
Just hit 11k miles.
Yeah. My x6 has done this twice and then before I can get it in the shop, it decides to start working again. ?
~ 24 M4 Comp
~ Prior BMW's - Too many to list here (27)
      10-21-2016, 01:09 PM   #9
Alpine300zhp
Mine is the opposite. When it acts up, it will go in and out, but not up and down. Weird.
~ 24 M4 Comp
      10-21-2016, 02:52 PM   #10
UrbanExtant
Drives: F82 M4 Comp Pack
This sounds eerily familiar.......
      12-14-2016, 11:09 AM   #11
tastelid
tastelid's Avatar
166
Drives: 2016 X5M
Originally Posted by Can-am View Post
Same thing.
This is now happening to mine. Smooth when it extends, rough when it collapses.
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S.
JMAN1111227.00
      12-15-2016, 11:16 AM   #12
eonflux
Drives: M3
Any way to stop the steering wheel from moving?
I don't need, nor want, it to move every time I get in/out of the X6M
      12-15-2016, 11:36 AM   #13
onfireX5
When it breaks, it stops that key off function. Yours will fix itself shortly.
      01-11-2017, 06:40 AM   #14
cmyx6go
cmyx6go's Avatar
15763
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Just happened to me this morning. Went down into position upon start but would not move out Started and stopped the engine a few times but still wont telescope.
A little over 10,000 miles.
      01-11-2017, 08:34 AM   #15
onfireX5
I just took mine in and they reprogrammed idrive. So far, so good.
      01-11-2017, 08:55 AM   #16
Alberta
Alberta's Avatar
2035
Drives: F90
Stopping the engine doesn't help.
You need to wait at least 5 minutes , after locking the doors for the electronics to go to sleep.
cmyx6go15762.50
      01-11-2017, 11:23 AM   #17
cmyx6go
cmyx6go's Avatar
15763
Thank you. Hopefully by the time I leave work it will be back to normal.
      01-11-2017, 01:04 PM   #18
Alberta
Alberta's Avatar
2035
Drives: F90
Chances are ... yes
This happened to me once.
      01-12-2017, 06:48 AM   #19
cmyx6go
cmyx6go's Avatar
15763
Chances are ... yes
No such luck I guess it's a trip to the dealer.
      01-12-2017, 12:04 PM   #20
TonySCV
Drives: '18 M2; '21 X6 M50i
You should be able for a coding shop to code it off.
I haven't done this myself yet, but the functions for the F10 are (these may be located elsewhere in the X5/6 modules e.g. FEM_BODY):
Easy Entry axis inclination active (normally active):
FRM > EINSTIEGSH_NG_AKTIV
Easy Entry axis length active:
FRM > EINSTIEGSH_LN_AKTIV
EASY ENTRY SEAT:
SM > EINAUSSTIEGSHILFE > Modus_FA_SLV
      01-21-2017, 06:01 AM   #21
cmyx6go
cmyx6go's Avatar
15763
I guess mine goes into the gremlin column. A week later, it telescopes again...
      01-21-2017, 05:10 PM   #22
Alpine300zhp
Yep. This is what they do.
~ 24 M4 Comp
