      03-09-2020, 12:54 PM   #1
fastgoat
Drives: BMW m550i xdrive
Front Suspension Clunk
I did my forum digging and see this may be a lower control arm issue, but wanted to see if anyone has heard/experienced differently. This is for a 2015 X5 35i xdrive with 50K on the clock.
At very low speeds, the driver's side suspension is creaking and popping, particularly when the wheel is turned to the left. It'll also make similar noises going into and out of the driveway. I took the car to my mechanic who wasn't able to replicate the noise.
Is it possible this is related to the sway bar end links versus the lower control arms? Also, he tried driving it while wet outside, so not sure if that impacted his ability to replicate.
      03-09-2020, 04:02 PM   #2
possib1edoc
Drives: BMW X7
Took mine to an independent BMW mechanic shop today. They noticed the noise as well, however they couldn't find where the noise was coming from. They said the sway bar and control arm were normal.
I have a 2015 X5 35i drive with 115k miles.
      03-09-2020, 08:16 PM   #3
sj22
Drives: 14 F15 50I
Control arms and bushings.
      03-09-2020, 10:36 PM   #4
It’s the control arms.
      03-10-2020, 08:03 AM   #5
MoeTE87
OHIO STATE
MoeTE87's Avatar
721
Drives: 2021 BMW M340i
I had the same symptoms and they replaced both front lower control arms and did a Four Wheel alignment. Noise is gone.
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red
      03-10-2020, 11:13 AM   #6
fastgoat
I assumed as much. I'm curious if they weren't able to replicate because it was raining/wet, which may have acted as a lubricant for the bushings. Granted I drove the car today and the noise was gone...
      03-10-2020, 12:31 PM   #7
201
200
Drives: Bmws
You can try going in and out of a sloped driveway as thats one method bmw foremans use to determine control arm issues
      03-16-2020, 09:55 AM   #8
fastgoat
Quick update -- it's now been a week since I replaced the front sway bar end-links, and still no noise. I'm starting to think the wonderful Chicago potholes created a bit of damage. Here's crossing my fingers the noise doesn't come back...
      04-06-2024, 09:21 PM   #9
m4forum
85
Drives: M3
I just found this post as was looking for front suspension clunk noise.
Have tried to use a pry bar to identify the noise but w/o success.
After reading this post decided to remove the lower control arm (rearward) picture below.
Found out the ball join had a play. Potentially the grease dried out causing excessive wear. The whole assembly needs to be replaced. Hopefully will get it by end of the week.
Name:  Screenshot 2024-04-06 at 10.09.02 PM.png
https://drive.google.com/file/d/1s6q...usp=drive_link
      04-08-2024, 02:19 PM   #10
G0rdon
G0rdon's Avatar
Poland
5
Drives: BMW X5 F15
I'm currently struggling with the same issue - also a clunk from the front suspension - replaced the lower control arm (#13 on scheme) but the clunking is still there....
I've also replaced the bushing of the thrust arm (#10) but I'm affraid that was a mistake and I should replace the whole thrust arm - wondering if it could be the ball joint of the thrust arm...
      04-08-2024, 05:21 PM   #11
m4forum
85
Drives: M3
The most stressed ball joint on front suspension is the one on lower control arm which you have replaced.
There are other 2 ball joints ( steering wheel arm and the trust arm ). Small play can make noise buy is hard to identify w/o disconnecting from the hub.
Other source of clunk is sway bar link … easy to check and easy replacement. Check on that also.
      04-09-2024, 01:33 AM   #12
G0rdon
G0rdon's Avatar
Poland
5
Drives: BMW X5 F15
In short, let me tell what already have been replaced:
- front shock absorbers (right one was leaking).
-Thrust arm bushings
-Lower control arm
-Engine mounts (workshop confirmed one was "crushed")
-both steering rods + tie rod ends
-Sway bar links in the front and rear
In just one week got a appointment in another BMW specializing garage to check the suspension once again...
      04-10-2024, 11:08 PM   #13
m4forum
85
Drives: M3
today I replaced the lower control arm and sway bar links ... clunk is gone.
I more accurate way to identify clunk is to disconnect the ball joint from hub and confirm if there is play ... trying to do that with pry bar doesnt work. for Sway bar just disconnect one side and check for play.
This should be sufficient to diagnose your noise.
      04-11-2024, 02:25 PM   #14
Kzang
Kzang's Avatar
3243
Drives: 2015 X5 35i Msport SG
My 2015 rubber bushing on the control arm is showing signs of dry rot. So I guess i will be experiencing the clunky sound soon too.
What is everyone paying their mechanic for a replacement control arm so I know what to expect.
thanks
      04-11-2024, 10:47 PM   #15
m4forum
85
Drives: M3
The clunk was more related to the wear on ball joint and sway bar links. The replacement is pretty simple to be honest ... for control arm and sway bar links no more than 2-3 hrs ~ $400-500 and parts $300 ... total ~ $800.
      04-27-2024, 02:40 PM   #16
G0rdon
G0rdon's Avatar
Poland
5
Drives: BMW X5 F15
I've just replaced the whole thrust arms (Lemforder ones) and the clunk is still there ...
I must admit I'm loosing hope here...what now...top control arms(wishbones)? Strut mount? The steering rack was checked for the third time and there was no play...
      04-28-2024, 08:07 PM   #17
m4forum
85
Drives: M3
I believe you have replaced most of the bushing and ball joint .... can you describe what type of clunk noise and the condition?
      04-28-2024, 10:09 PM   #18
stocktree
Drives: x5
You check the arm bolts are tight? If not, the bushing will move around a bit and knock on the bolt.
      04-29-2024, 05:53 AM   #19
G0rdon
G0rdon's Avatar
Poland
5
Drives: BMW X5 F15
This clunk is almost like in this video:
(moment from 1:10 to 1:20), when author is showing his clunk.
@[stocktree] - yes, me and 2 top BMW garages were checking every single element in suspension and didn't found nothing suspicious...Every single bolts were checked (I was hoping maybe one of them will be loose...).
      04-29-2024, 04:18 PM   #20
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Try hitting or pushing/pulling where the inner and outer tie rods meet, I’ve been chasing a clunk/rattle for a while and I tried checking things and found my tie rod has play where the inner and outer meet.
      04-29-2024, 05:14 PM   #21
m4forum
85
Drives: M3
What I learnt from my experience on front suspension F15 X5 was that pry bar isnt the best option to find the problem unless the play in the suspension is substantial ... clunk can take place with small play.
The best option is to remove all arms and exam them for defects. I know it sounds a lot of work but this is the best option.
      04-30-2024, 01:40 AM   #22
G0rdon
G0rdon's Avatar
Poland
5
Drives: BMW X5 F15
Yes, I've checked those as well, and even the OE ones were in good shape, I've decided to replace them also with Lemforder ones.
True, finding a "dull" clunk in this suspension is really difficult.
Was hoping the new thrust arms and lower control arms will help, but installed new ones without any change...
Would the front drive shaft clunk on minor imperfections on the road?
