05-24-2018, 01:32 AM | #1 |
Rep 674
"Check Engine Light" Not Lighting!
Im having such a weird problem. Recently, I noticed that my CEL light is not coming at all. I mean when the ignition is on without starting the engine I don't see the damn CEL light!
Any help is well appreciated. Its not the bulb because I had 6WB cluster retrofitted and I just tested with the original cluster, didn't work. I also checked the cluster fuses... : |
05-24-2018, 06:32 AM | #2 | |
Rep 998
It's designed to show CEL (and some other lights) when ignition is on, it should turn off as soon as you start. But to be safe check for codes with OBD-II scanner.
05-24-2018, 08:26 AM | #3 |
Rep 18,751
Do you have any mods in the car?
05-24-2018, 11:11 AM | #4 |
Rep 674
05-24-2018, 11:19 AM | #5 | |
Rep 18,751
But usually the CEL will turn on momentarily before you start the car.
05-24-2018, 11:20 AM | #6 | ||
Rep 674
Except the "CEL" that never comes on and its quite worrying because I have all those mods and if something went wrong I would have no Idea.. |
05-24-2018, 11:24 AM | #7 | ||
Rep 674
Before that I had a JB Stage One, do you think that had anything to do with this? |
05-24-2018, 11:53 AM | #8 |
Rep 998
Don't guess, just scan it for codes. MHB also has logging feature.
Better question, how do you like MHD? Also, how does it compare to JB? |
05-24-2018, 11:53 AM | #9 |
Rep 18,751
JB Stage One doesn't alter the ECU. So, it doesn't have anything to do with this.
05-24-2018, 01:27 PM | #10 | |
Rep 674
If that didn't work I will try hooking up ista+ and see what comes up. |
05-24-2018, 05:15 PM | #11 | |
Rep 567
The power delivery is super smooth and can't be compared to the JB unrefined turbo power surge! Also the features like "cold start noise reduction, max speed unlock and of course the infamous Burble settings comes quite handy" |
05-24-2018, 06:33 PM | #12 |
Rep 1,092
05-24-2018, 06:34 PM | #13 | |
Rep 674
Spend a little more and get ER, AR Catless or even better the catted one. Here are your options! https://www.x-ph.com/2011-535-1/ |
yewlock697.50 |
05-24-2018, 09:18 PM | #14 |
Rep 18,751
I have ER Hi-Flow cat in stock if you are interested.
05-24-2018, 09:26 PM | #15 |
Rep 1,092
I am still waiting for you opinion on HiFlo Catted downpipe. Have you test it in your car yet? I am worry about CEL which you say hit and miss. Am I sacrifice low and mid torque for gaining high end power?
Thanks. |
05-24-2018, 09:31 PM | #16 | |
Rep 18,751
I just PM you the details btw.
yewlock697.50 |
05-27-2018, 07:37 AM | #17 | |
Rep 159
sbinshihon684.50 |
