      08-30-2014, 12:32 PM   #1
02330ci
Drives: 2021 X5 M50i
2014 X5 50i Oil Consumption
Picked up X5 in May and roughly 2500k miles on it. Message came on stating it needs 2 quarts of oil.
Dealer topped it for free with no wail at all. No complaints there. Tech said nothing too unusual but to keep an eye on it. Something about the sensor being very sensitive but it did take 2 full quarts. Whatever that means.
Anything unusual about needing oil already or this is normal for the v8 engines?
      08-31-2014, 02:03 AM   #2
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
It's normal. I actually had mine pop up about 20 minutes away from the dealer after picking my truck up today. 3000 miles. Traffic in the opposite direction kept me from turning around.
My 550 was just as bad.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      08-31-2014, 07:48 PM   #3
42pilot
42pilot's Avatar
589
Drives: 2014 X5 35d MSport
For well made, high-performance engines, the rule of thumb is 1 qt used every 900 - 1200 miles. Short distance drives will use more as the engine has to heat cycle more up to tolerances. My 550i used about a qt every 5000 miles but mostly highway miles. Porsche will tell you 1 qt every 1200 miles - older models were more.
      08-31-2014, 10:07 PM   #4
BMWboy
There is No Chance Unless You Take One
BMWboy's Avatar
Drives: 2014 X5 50i M Sport
I had a 2009 750i, a 2011 750Li, and a 2013 M6 - they all needed a quart every 5,000 miles. But this made me realize my 2014 X5 50i M Sport made it to the 10,000 service without a quart?!? Now I'm worried!
RIP: 2013 M6 Convertible, 2011 750Li, 2009 750i, 2008 Mini Clubman - and more other makes and models than I can count!
      09-01-2014, 03:51 PM   #5
Nkbm82
Nkbm82's Avatar
74
Drives: 2018 BMW 750i
I'm at 9100 miles and mine hasn't needed any oil, it is asking for an oil change now so I'm taking it in tomorrow.
      09-02-2014, 07:29 PM   #6
NOVA99
Drives: 2021 M-B GLS 580
Oil Consumption is normal in 50i V8. My experience is 1 quart added every 10-12K miles. Several dealers confirmed this. Never cost me anything.
      09-03-2014, 01:18 AM   #7
HMN
HMN's Avatar
356
2014 BMW X5  [0.00]
BMWs do tend to use much oil to be honest. Rather interesting that I haven't changed my F15's oil yet but on my old E71 I used to change it quite frequently. At times even once a month.
      09-03-2014, 10:16 AM   #8
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
I need to understand oil consumption. My understanding is gaskets and seals and piston rings keep oil out of the pistons. Any oil missing must have seeped in and burned off (pollution, possible damage to emission system, catalytic converters, etc.), or leaked from a gasket.
After 35 years of driving BMW, Benz, Lexus, Volvo, Merkur (yes I had a Scorpio once, and no teasing allowed), Hyundai (first generation Excel, no jokes allowed) and even new red Scirocco (any jokes here and I will show up to your front door), the only times I had oil consumption was related to leaks. I still have a Lexus LX 470 with circa 200k miles and it has never required a top-up of oil. My current CLK500 and the R500 also lose nothing in their 10k service intervals. I had a 190e about 25 years ago that would lose about a quart every 3000 miles or so, due to a leak. Others were repaired for gasket leaks and oil loss stopped.
I am baffled that oil use can be justified, but as I am not a mechanic, I will defer to a good explanation as to what happens to the mysterious disappearing oil.
      09-03-2014, 09:31 PM   #9
42pilot
42pilot's Avatar
589
Great question and allow me to answer it based on my 12 years of building and designing hot rod turbo Porsche motors (only).
Porsche, BMW, Merc and other high-end car mfg build their motors out of alloys such as magnesium, aluminum, steel and so on. Each of these alloys are used in different areas in the motor. For example, Porsche used forged aluminum pistons inside nikasil aluminum cylinders. Each of these alloys have unique properties that work great in their designed roles, and have different expansion rates. Therefore, the parts need to be designed to work properly at operating temperature and it could mean that, as the engine comes up to temp, it allows oil to seep past (like rings) into the combustion chamber to be burned.
Additionally, Porsche designed their motors to use the smallest amount of oil in their cylinders. The rate was 1200 miles per quart, but what this does is adds additional lubricant where metal to metal is most aggressive. This is why a properly maintained Porsche boxer motor will easily last over 200,000 miles without needing an overhaul and will have very low leak-down values (healthy rings) thereby keeping power relatively high in an older motor.
When building a Porsche motor compared to a domestic motor, it takes about 3x longer due to the attention to tolerances and dry fitting parts such as heads, pistons, valve clearance, deck heights, main and cam bearing clearance, rings, etc. A difference of .0040 in these motors could mean the difference between properly running versus putting a hole in the top of your piston. If you need pics, let me know
BMW and Merc do the same, but with newer technology oils (synthetics), the need for oil use is lower - but it's still there.
My 1979 525hp/500 lb ft torque turbo Porsche used about a qt every 900 miles and during track events, used a quart a day. For your info, a Formula 1 car will use a couple of quarts each race for the same reason - the use of lubrication in the form of light-weight oils takes less horsepower to run the motor and it ensures the engine will last multiple races. They use a dry sump system.
Until recently, most American cars used iron and steel throughout their engines, therefore providing nearly identical expansion rates. Therefore oil usage is low on domestic production engines. That has changed over the past years to aluminum heads, blocks, pistons and so on, so I would imagine oil usage is up on some models.
A properly built, high quality motor will use oil and it will be burned in the combustion chamber.
DuSh2112.50
      09-04-2014, 09:45 AM   #10
MysticBlue
What viscosity oil does it call for? I'll pick up a couple liters to keep in the vehicle. Should be here any day now.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      09-04-2014, 12:31 PM   #11
MattBianco
MattBianco's Avatar
Thank you @42pilot for taking the time to explain at length. If I understand and have simplified this correctly, a small amount of oil burn (not loss/leak) is a byproduct of using better performing metal alloys for each specific component, which in aggregate produce more power/efficiency, but they expand and contract at different rates under temperatures due to the differences in their composition, and some oil enters the cylinders through the piston heads.
Until you correct me I deduce:
  • The oil burned produces slightly more emissions but still maintains their level low enough to comply with standards
  • The burned oil may actually help prolong the life of some components as it provides additional lubrications
  • The burned oil may reduce the life of some emission equipment (catalytic converter, for instance)
  • If one experiences this from the time the engine is young, it is indicative of the design byproduct. If one approaches this at over 50k miles / 80k km, then it is not due to design, but wear/tear/leaks/bad rings/other issues.
  • This is more likely to occur in high-performance engine that operate at higher pressures, with a high red line. And therefore, this should not occur in low pressure engines. And, diesels that have pressurized fuel/air mixtures but not have highly pressurized cylinders, have lower redlines, and rely on the fuel to deliver lubrication.
  • Keep a an extra liter/quart of the appropriate oil handy in the garage
Thank you again.
      09-04-2014, 03:31 PM   #12
42pilot
42pilot's Avatar
589
Thank you again.
The oil on the cylinder walls should not be scraped off completely by the rings, thereby seeping into the combustion chamber. The amount is very small and designed this way and where the majority of oil usage stems. You want the thinnest film of oil between piston rings and cylinders to extend the life of the motor.
Burned oil is useless. Oil in its liquid state not only lubricates, it also cools and cleans. I would bet each of our motors has piston squirters - that is, jets that spray oil on the under-side of our pistons thereby keeping them cool after the combustion stroke.
Normal oil usage in our cars will not shorten the life of emissions equipment, including O2 sensors and cats. Catalytic converters really don't start working until high temps - like 900 degrees. This will burn normal oil usage residue out of the honeycomb cat interior. The problem will occur when you have excessive oil usage - then you will have component failure.
Oil usage should be consistent through the life of the motor. A good BMW motor, properly maintained, should last +200,000 miles (this is mechanical parts, not electrical like sensors, injectors, starter, etc). When they wear out, oil usage will increase noticeably and you should perform a compression test or leak-down test on each cylinder.
Consistent high RPM will wear a motor out faster, but regardless of displacement of the motor, wear should be consistent under normal driving. A diesel motor operates under much higher compression ratios than gassers (pressure as you state). I think my 30d is 18:1 ratio where the gas version is probably 10:1 or 12:1. A diesel motor requires high pressure to ignite the air/fuel mixture since it does not use spark plugs. Since diesels provide much more torque than a gas motor, there is no need for higher rpm's to move the car down the street.
In my opinion, it is much more important to change the oil in a diesel more often than a gas motor. Diesels produce soot and have sulfur in the fuel. If you add sulfur and water (humidity), you get a mild acid. Additionally, soot is a carbon by-product and is abrasive - very fine, but still abrasive. I change the oil in my truck tractor and car every 5 - 7,000 miles (tractor every 100 hours). I WILL NOT extend the oil change per BMW's guidelines, but then again, I bought my 30d and did not lease it.
Fuel is not a lubricant. In fact, its one of the worst things you can put in your engine since it dissolves (or what is known as washing cylinders) oil from surfaces so you have metal to metal contact. This is a potential problem I had with the RaceChip. You can't just dump more fuel in a cylinder and expect more power without trade-offs. Any un-burned fuel will wash the oil off the cylinder walls and create higher heat, and accelerated wear. The fuel can even seep past the piston rings into the oil, and you will dilute the oil's lubrication properties and f-up your entire motor. That's an extreme case, but it happens.
Lastly, use the lightest weight oil BMW recommends. Heavy weight (high viscosity) oil robs power, does not increase lubrication and puts strain on the motor when first started from dead cold. I like 0w30 synthetic because it is like water when the motor starts (ensuring lubrication throughout the motor very quickly). This oil also creates a perfect thin film of oil between all rotating or reciprocating metal parts for the best lubrication versus power loss. Again, NASCAR and Formula 1 use a straight 5w or 0w oil for races. We need a little weight (the 30 in the 0w30) to our oil when we are at idle and need pressure and a consistent film of oil that 0W struggles to produce.
      02-27-2018, 05:47 PM   #13
Rlascano
Drives: X5 2014 x50i M package
Thank you again.
I am experiencing oil top off twice on my 40k 2014 x50l. Dont see anything leaking or wrong with the vehicle but i guess i shoukd not use the m mode since its whats making it consume more oil?
Rlascano ?
      02-27-2018, 08:15 PM   #14
DuSh
DuSh's Avatar
2113
Drives: F15 X5 50i
Just use it normally, no need to baby it. It's still direct injection and a good highway high-rpm drive will only help burn deposits on intake valves
Same goes for n55 guys I think
      02-28-2018, 09:07 AM   #15
redline9001
redline9001's Avatar
223
Drives: E92 M3, F15 X5, G14 F150
Formula1 has rules about oil usage and they can only burn .6 litre per race... more strict rules have been put into place over the last couple.years
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts
      02-28-2018, 09:29 AM   #16
puckybadger
Drives: 2024 X6 M60i LCI TBII/Tartufo
FWIW: 77000 miles on my N63TU, have never needed to add any oil. I drive 50-60 miles every day, 90% interstate. Oil and filter changed every 10K
DuSh2112.50
      02-28-2018, 11:18 AM   #17
sj22
Drives: 14 F15 50I
I need oil every 5000 miles or so again 40 miles daily, 90% inner city. So I guess there is a huge variation.
Also for those getting regular oil changes, you may get oil topped off at the dealer during the oil change, some dealers are proactive about it. Others don't care to check wiper fluid and oil status.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
      02-28-2018, 02:35 PM   #18
perry8912
Drives: bmw x5
To be honest, every 5000miles with 90% city driving, and only need 1qt of oil, that looks pretty good.
I wonder what mpg number have you got during your daily drive...
      02-28-2018, 06:43 PM   #19
DuSh
DuSh's Avatar
2113
Drives: F15 X5 50i
Wow, is that biggest yet mileage on 50i or someone has more? 77k miles is 123k km - not bad. I think the reason you avoided adding oil is that you drive mainly interstate and for long enough each way to properly heat up and burn deposits while having easy load and good cooling - that's like a vacation to engine
      03-01-2018, 09:35 AM   #20
puckybadger
And... I am averaging 22mpg & 42mph per engine status readout.
      03-01-2018, 12:16 PM   #21
Bodie217
Bodie217's Avatar
90
Drives: '10 135i, '14 WRX, '14 Sequoia
Another thing that helps with oil consumption is to not rev past 3k rpm and 50% throttle until the engine warms up to operating temperature. The tolerances between engine parts will be tighter when it warms up, which will help keep oil from passing between parts of your engine.
I haven't seen any mention of the PCV system, which is how you get oil in to your intake manifold. Everyone should be using a catch can system to prevent this.
-2010 BMW 135i - Titanium Silver - Procede v3/ETS 5" IC/AR Catless DP>N54mid>Berk Race/BMS OCC/VRSF Turbo Inlets & CP/SP rotors/Pagid RS29/APEX ARC8/Ohlins DFV/M3 Full Suspension and Bushings/Wavetrac LSD // 395rwhp/469rwtq on 91oct
-2014 Toyota Sequoia Platinum - Overlander
      03-01-2018, 06:01 PM   #22
onemark1
Drives: BMW X5 50i
I had a same issue recently on my 14 x5 50i. and finally I noticed it is oil leak. I can always find oil drops on the garage floor. In the end, BMW changed the oil tank and thanks for my extended warranty.
Search this Thread:
Advanced Search
