      02-23-2018, 12:15 PM   #23
MochiEater
Drives: 2017 X5 40e
Originally Posted by baubaulu View Post
What software do I need to code a car?where to download
If you're comfortable using ENET cable and E-SYS here:
http://www.bimmerfest.com/forums/sho...d.php?t=983244
2018 330e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD), Active Blind Spot Detection, ACC Stop & Go, Parking Assistant, Side/Top Cameras, HUD, Comfort Access, 225/45R18 255/40R18 Pirelli Cinturato P7 + Winter Sotozero Serie II
      02-23-2018, 01:51 PM   #24
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
So just to be clear,
I purchase this https://www.amazon.com/dp/B01FU5MVI8..._pvAIAbQEQC4ZP from amazon, hook it up to the OBD outlet in the car. Then download this app on my iphone http://bimmercodeapp.com/index.php#adapter and I can pretty much code everything on that list?
      02-23-2018, 04:53 PM   #25
SCA
SCA's Avatar
Drives: Multiple BMWs
Yep...
      02-23-2018, 07:45 PM   #26
Kzang
Kzang's Avatar
3240
Yep...
One more question. I had my X5 coded the traditional way (with a laptop and cable). If I use this method to add on a few codes will it disable any existing codes? I'm not sure it's relevant question but was just curious if it overrides my current codes for some reason.
      02-23-2018, 08:59 PM   #27
CeeTeeX5
It shouldn't have any impact on any existing coding you've done unless you choose to change that existing coding.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      02-23-2018, 09:27 PM   #28
Kzang
Kzang's Avatar
3240
Thanks Bro!
      02-23-2018, 10:25 PM   #29
turboawd
1636
Drives: 2015 X5 35i
So this allows you to code for free after buying the obd plug? So carly is pretty much a rip off then?
      02-23-2018, 10:28 PM   #30
Kzang
Kzang's Avatar
3240
I am not 100% certain but I just ordered on amazon and will let you know when I receive it. I wanted to add a few things I didn't get to code before so for $20 bucks doesn't hurt to see.
      02-24-2018, 09:19 AM   #31
SCA
SCA's Avatar
You also have to purchase (unlock) the BimmerCode App. It is not free...
      02-25-2018, 10:23 AM   #32
perry8912
Drives: bmw x5
Unhappy
By using bimmercode, any one know how to disable the auto steering wheel movement (easy entry/exit) feature ?
Been trying to do it several times, but no success....
      02-25-2018, 10:57 AM   #33
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Why would you want to disable that?
      02-25-2018, 11:03 AM   #34
CeeTeeX5
Some people seem concerned it's going to burn out the motor that extends/retracts the wheel.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
      02-25-2018, 11:14 AM   #35
CatalinP
Drives: BMW X5 F15 2014 3.0xd
In BDC Body:
You have to set to AKTIV the following 2 lines:
BDC Body -- V_MAX_AKTIVER_EINSTIEG_AKTIV
BDC Body -- V_MAX_DEAKTIVIER_EINSTIEG_AKTIV
and the you have to check that
BDC Body -- V_MAX_AKTIVIERUNG_EINSTIEG
are set to WERT_01.
perry8912101.00
      02-25-2018, 12:43 PM   #36
perry8912
Drives: bmw x5
Originally Posted by CatalinP View Post
In BDC Body:
are set to WERT_01.
Thx, I ll give it a try tomorrow...will let you know
Edit, I tried this afternoon, and it actually worked...
      02-25-2018, 01:36 PM   #37
neverdone
I don't understand the point of having all these features in a car that are totally useful, just to disable them, especially this one. That's obviously just me though.
      02-25-2018, 01:50 PM   #38
CatalinP
You'll understand it when, out of warranty, you'll find out that you need to replace the whole steering column.
      02-25-2018, 02:02 PM   #39
neverdone
How often have you heard of this happening?
      02-25-2018, 05:01 PM   #40
Kzang
Kzang's Avatar
3240
Very often. It is a common issue. I've had it happen to me 4 times in 3 years. Column replaces twice.
      02-28-2018, 11:17 AM   #41
08whtx5
Drives: E93
Can anyone clarify if I enable the mirrors to fold on comfort lock that they open when unlocking or will they need to be manually activated?
      02-28-2018, 11:29 AM   #42
Mgm 05
Drives: ‘15 X5 35d; '24 i4 M50
They open automatically for me with either the fob or comfort unlock
      02-28-2018, 02:40 PM   #43
08whtx5
Drives: E93
Perfect! Thanks for the reply, now I anxiously wait for my Vgate tool to arrive
      03-02-2018, 01:44 PM   #44
smyles
Drives: '21 X5
If you already have a generic Bluetooth adapter, it may work with Bimmercode. In your phone BT settings just rename the adapter to V-LINK, and give it a try.
