05-13-2020, 06:50 AM | #23 | |
Rep 70
05-13-2020, 07:45 AM | #24 |
Rep 70
Reading some reviews on Honda / Acura - the hard race product seems to be pretty well known with good reviews - just unknown with BMW - agree there is some risk of trying a product that hasn't been widely tested or from a lesser known brand in these circles.
1norseman398.00 |
05-13-2020, 08:07 AM | #25 | ||
Rep 648
I'm thinking my decision will be based on if they care to reply or not... You are likely right about it being China made and all that, but no other options and I have been wanting to try one for a while, see if that improves certain handling characteristics I don't like.. Quote:
When it comes to installing it, I'm thinking it might be a DIY. But that depends on how hard it is to remove the rear swaybar, and if any other components needs to be removed in the process? Also, I wonder if baubaulu has any connection to this company? Would have been nice to see him post some more about the install etc. I might still order one and try it out, but I will wait and see if I hear back from Hardrace... |
05-13-2020, 11:15 AM | #26 | |
<3 Flat Four
217
Rep 754
edit: spoke with a friend in asia, the company is actually taiwanese, and they make decent quality products for a decent price. hes using their upper control arms on his F30 on the track, so thats a lil bit more reassuring. now how to get our hands on some bars is another question.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White Last edited by TOPEC; 05-13-2020 at 11:34 AM.. |
1norseman398.00 |
01-12-2021, 09:00 PM | #27 |
Rep 104
AleksRacing recently started selling the Hardrace rear sway bar.
https://www.aleksracing.com/hardrace...e71-bmw-x6-f16 He also sells Ultra Racing F15 chassis bars which includes F & R sway bars for F15 X5. https://www.aleksracing.com/ultrarac...-2013-2018-ur/ |
01-13-2021, 07:39 AM | #28 | |
Rep 92
01-17-2021, 03:15 PM | #29 |
Rep 104
I bought the Ultra Racing strut brace. I'd have to say it is very well made. Fit is spot on and it was straight swap for the OEM braces. All Ultra Racing braces come coated in gloss white. I prefer not having the aftermarket appearance and painted my strut brace black, which blends in quite nicely in the engine bay.
The strut brace definitely gives a noticeable improvement in handling. While not dramatic, I'd rather have the brace than to drive without it. |
01-31-2021, 05:15 AM | #30 |
Like No Other.
557
Rep 1,833
I came across Hardrace as well, and had the same issues trying to get in touch with them. However, it's the only brand that has aftermarket sways for my BMW F07 5GT, which is a pretty rare platform to modify.
Came across www.aleksracing.com recently and their customer support is pretty good. Fast emails and answered my questions. I'm going to place an order with them this week, hopefully it works out. If all is well, then will definitely recommend you guys reach out to Aleks to see about getting some sways for your X cars.
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT my work: http://www.instagram.com/CorsaAutoDesign |
02-01-2021, 09:28 PM | #31 | |
Rep 1,497
05-14-2022, 11:58 PM | #34 |
Rep 243
resurrecting this thread. Just placed an order for the hardrace rear and Ultra front sway bar. I'm on M adaptive with rear air and currently on a mission to eliminate or at least significantly reduce body roll. I will keep you all posted.
ps: can anyone guide me on the front sway bar installation, I know the rear is easily accessible and straight forward install, just hoping the front isn't a pita. |
E90325M475.00 |
06-23-2022, 03:54 PM | #36 | |
Rep 661
I've installed both front and rear sway bars about a month ago: To do the front, front bumper, radiator, intercooler, both front wheels, front inner well arch cover, underbelly pan, and the aluminum bracket for the brake ventilation will all need to come off first. Then just unbolt and guide it out, replace, bolt everything back on and you're set. Not an average replacement job, but not as hard as dismounting the engine or the transmission. The result is a dream handling ride, I'm loving mine, along with a H&R spring and Bilstein B6 struts.
06-24-2022, 10:50 PM | #37 | |
Rep 243
To me the rear alone was a good enough upgrade and the amount of work required to swap out the front just didn't seem like a task I wanted to take on. I will probably just change to poly bushings on the front and call it a day. Rear alone is well worth the investment, and it's an easy under 1 hr diy. |
sukhk5272168.00 |
06-25-2022, 01:40 PM | #38 | |
<3 Flat Four
217
Rep 754
06-25-2022, 10:22 PM | #39 |
Rep 243
As great as dhp is, imagine the bill for when its time to replace that leaking front active sway bar
02-06-2024, 10:47 AM | #40 |
Rep 178
This maybe a dumb question but are there options for sway bar links on air ride. Seems like they go bad more often then I would like since I air out when parked causing the ball joints go bad and make noise on bumps.
02-07-2024, 10:35 AM | #41 |
Rep 661
I've driven the X5 with DHP and I'll say that standard suspension fitted with the upgraded sway bars is still the way to go. DHP only stiffens cornering up a bit and it's also "lazy" in response. The upgraded sway bars will put the standard suspension at top spot in my opinion for suspension performance. It literally has an all-time minimal sway no matter how I go about a corner. And if you don't like how "plush" the standard springs/shocks go, you can go for a set of KONI active sport shocks and option at a set of Eibach springs to get that slight extra planted feel on the road. I'll say that standard suspension loses in competitiveness against the DHP in terms of spring/shocks, but the KONI active sport FSD will make it a worthy rivaling option.
