      02-17-2018, 10:28 AM   #1
baubaulu
baubaulu's Avatar
41
Drives: 2015 X5
What software do I need to code a car?
What software do I need to code a car?where to download
      02-17-2018, 11:53 AM   #2
CeeTeeX5
Bimmercode app if you want to do it the no brainer way. You’ll also need an obd2 BT or WiFi adapter
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      02-17-2018, 12:08 PM   #3
turboawd
1636
Drives: 2015 X5 35i
How about the carly app? I bought the module but haven't used it yet. Lol
      02-17-2018, 03:02 PM   #4
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
My phone has a usb-c port, is there an obd2 that will work with it? Or wifi adapter you suggest?
      02-17-2018, 08:09 PM   #5
neverdone
Drives: X5, 335, Ford Lightning, 63 me
What app to use with android? Or do both work?
      02-17-2018, 09:27 PM   #6
CeeTeeX5
Bimmercode is available for Android as well.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
      02-17-2018, 11:59 PM   #7
shezi01
Drives: BMX X5 35i
Android version has bimmercode and bimmerlink all in one.
      02-18-2018, 12:10 AM   #8
baubaulu
baubaulu's Avatar
41
Drives: 2015 X5
i had carly, but it can only provide high level configuration. For example, I would like to activate easy Entrance function But it does not show in the list.
      02-18-2018, 12:33 AM   #9
neverdone
Do you happen to know what Wi-Fi unit I need to use it with android?
      02-18-2018, 01:11 AM   #10
CatalinP
Drives: BMW X5 F15 2014 3.0xd
V-Gate.
      02-18-2018, 03:14 AM   #11
theove
Drives: X5 4.0E
Is it possible to change the ambient colors and patron with bimmercode?
      02-18-2018, 10:07 AM   #12
neverdone
Originally Posted by CatalinP View Post
V-Gate.
https://www.amazon.com/Vgate-Bluetooth-Scanner-TORQUE-ANDROID/dp/B0154KKF0U
This one?
      02-18-2018, 10:11 AM   #13
CeeTeeX5
https://www.amazon.com/dp/B01FU5MVI8..._pvAIAbQEQC4ZP
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
      02-18-2018, 10:13 AM   #14
CatalinP
On the bimmercode website there are links for the adapters.
http://bimmercodeapp.com/index.php#adapter
      02-18-2018, 10:23 AM   #15
neverdone
Those say for iOS
      02-18-2018, 10:55 AM   #16
CatalinP
All you need is a iOS or Android device and a Vgate iCar Pro Bluetooth 4.0 or Wi-Fi OBD adapter.
It works with both.
      02-18-2018, 11:00 AM   #17
neverdone
Probably better to get BT instead of Wi-Fi in case Wi-Fi signal isn't that good?
      02-18-2018, 11:04 AM   #18
CatalinP
Are you planning to code the car from inside the house or what?
      02-18-2018, 11:06 AM   #19
neverdone
My garage ya.
      02-18-2018, 11:07 AM   #20
CatalinP
Both bluetooth and Wi-Fi give at least 10m range, but you normally code the car sitting in the driver's seat, that is less than 2 meters between the adapter and the phone.
      02-18-2018, 01:32 PM   #21
euro-r
euro-r's Avatar
34
Drives: 17' BMW X5 | MSport | MPPK
It use Bluetooth or wifi so it doesn't matter if your phone is having a USB c port or not
      02-18-2018, 04:21 PM   #22
CeeTeeX5
it uses a wifi direct connection. You don't need to be connected to your home network.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
menelaos1226.00
