      04-11-2018, 02:01 PM   #1
kiankur11
Drives: f31 335i Manual 2016 with MPPK
Unhappy X5 ambient lights not working !!!
Hi Guys I have 2014 x5 f15 and I recently discovered the ambient lights are not working on the all four doors . the only light what I can see is the lights on the dash.
Has anyone faced this issue ?? I tried reading on the net but no luck so far.
Any one knows how to fix the issue ???
      04-11-2018, 02:07 PM   #2
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Maybe you don’t have them fitted.
      04-11-2018, 02:23 PM   #3
It could be due to a break in the circuitry.
Example: while swapping door trim, I forgot to plug in the rear driver’s side ambient light. Later that night I noticed that only the driver’s door ambient lights are working. When I removed the driver’s side rear panel I immediately noticed that the plug wasn’t connected and plugged it in. All four doors worked as soon as I plugged that one in.
Or a fuse?
P111572.00
      04-11-2018, 02:23 PM   #4
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
First thing I would check are the fuse.
      04-12-2018, 05:44 AM   #5
kiankur11
Hi Buddy them came standard and they were working when I picked the car 2 years back ..
I dont drive in night much and I also have other cars so it was not noticed recently .
      04-12-2018, 05:46 AM   #6
CatalinP
Have you checked the iDrive settings?
      04-12-2018, 05:48 AM   #7
kiankur11
Or a fuse?
Thanks Violator,
I haven't opened anything the car is as standard as it is.
It just doesn't work .
if the fuse goes will the computer pick up on the issue ?
How do we check the fuse as it has many.... do we have specific fuse for ambient lighting ?
Any information will be helpful.
thank you so much ....
      04-12-2018, 05:53 AM   #8
+1
I believe you can enable/disable ambient lighting in iDrive, have you checked the lighting section for this possibility?
Otherwise, check your fuses as several of us have stated.
      07-17-2018, 09:14 PM   #9
jo2134
jo2134
jo2134's Avatar
Drives: 2021 X5 M Competition
Just did a 6WB retrofit and all of the ambient light is not working except for the lighting on the passengers side dash
The small strip of light on the drivers side past the cluster as well as the strips on all the doors does not illuminate.
I did notice one wire not plugged into anywhere after installing the new cluster but did not see where it could be plugged into.
Any thoughts?
Thank you
      07-18-2018, 07:51 PM   #10
sloanbj
Drives: 2015 Xdrive50i MSport
You don't really need ambient lighting. I would ignore it.
      07-18-2018, 07:56 PM   #11
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I don't think it's about needing it, it's just nice to have working properly if your car is equipped.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      07-18-2018, 11:50 PM   #12
teodorjelev
Bulgaria
585
Drives: Mercedes AMG GT 53 4-door
Hello.
I had the same problem!
I took her to the service shop!
Lighting is done in sequence!
If someone has a door problem is not light and the others doors!
All doors should be opened and the cables and plugs checked!
There they changed two plugs and a couple of cables and everything was fine!
However this is BMW, there is nothing surprising!
      07-19-2018, 07:36 AM   #13
jo2134
jo2134
jo2134's Avatar
Sorry but if I'm driving a brand new $76,000 car I would like for all of the features to work
In any case, I dont think its wiring in the door. At this point I believe a wire may have gotten unplugged during the cluster installation or it is a coding issue
2021 X5 M Competition Tanzanite Blue II/Black Full Merino with Midrand Beige
Past: 2019 M5 Competition Alpine White/Aragon Brown Full Merino Leather
2018 X5 35i M-Sport Space Gray / Mocha Nappa 20" 469M Wheels
2015 528xi Dark Graphite / Cinnamon Brown
2013 X5 50i Platinum Gray / Cinnamon Brown 20" Y-Spoke Wheels
Russmov1328.00
Kzang3240.00
      07-19-2018, 09:24 AM   #14
6spdcoupe
tends to get irritable
6spdcoupe's Avatar
Drives: 14 F15,18 M550,20 Highlander
Do you go under the driver side dash at all during your installation ? If that courtesy light is unplugged (or even loose) then you will loose half of your lighting.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile
      07-19-2018, 11:20 AM   #15
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
I had the same problem but it appears to have fixed itself: https://f15.bimmerpost.com/forums/sh...0#post23476900
      07-19-2018, 12:49 PM   #16
jo2134
jo2134
jo2134's Avatar
Thanks everyone for your responses.
I just solved the problem. When I was swapping out my original cluster it seems that one of the Ambient Lighting power cables got disconnected (I attached a photo showing it).
Popped it back in and now everything is working perfectly =)
Russmov1328.00
      07-19-2018, 01:04 PM   #17
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Glad you were able to figure it out! Bet you are relieved.
jo2134385.00
      07-19-2018, 01:36 PM   #18
jo2134
jo2134
jo2134's Avatar
Thanks man. Very relieved lol
Now need to find a way to code the extra colors (old method no longer works)
Russmov1328.00
      07-19-2018, 01:38 PM   #19
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I want to know this as well. Hope someone finds a way around it.
      10-13-2018, 05:23 PM   #20
speuk
Registered user
United Kingdom
78
Drives: G05 3.0d MSport / F23
2010 f07 SE GT  [0.00]
Hi, I have this exact same issue. Where is the connector in the photo located? The dealer has just replaced the passenger side microphone so I suspect they have disturbed a connector
      10-23-2018, 07:20 AM   #21
Kappy
Drives: 2008 BMW X5 SD
X5 ambient lights
I just purchased a 2008 X5 SD.
All the ambient light works except the passenger side.
Do these lights fail or is it just a case of maybe not connected, as I hant window tint fitted and they remove the trim to do that.
Cheers
Kappy
      10-23-2018, 07:24 AM   #22
6spdcoupe
6spdcoupe's Avatar
Cheers
Kappy
Odds are quite good that they did not reconnect after tinting.
